    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Erratic pace variation and workout distance strongly wrong
    Scheduled Pinned Locked Moved Suunto Vertical
    6 Posts 3 Posters 680 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Gilles D.G Offline
      Gilles D.
      Hello everyone!
      I posted recently a similar topic with a S9B, but I have the same kind of issue with a Vertical.
      I have a very recent case to submit and seek for help: this morning I ran the Paris marathon, and I was very disappointed by the watch. It was almost useless, except for the timer. I wanted to use the Suunto plus feature like the race pacer, but it is completely useless when the length calculated by the watch is not correct. As you can see in my screenshots, there are 2 things that are weird :
      • the total distance is 39.9 km vs 42.2 km, so 2.3 km missing!!
      • the pace variation is insane, and does not match the pace I had (you can check the 5 km pace which was measured by the organization, I was quite constant till km 25, after it was more difficult 😅).
        Every time I have an issue with distance, I observe at the same time the pace variation is going crazy.
      Link of my race: https://www.strava.com/activities/11125193637/overview
      hKztm1N8L3REcBaZWahA1us9KrV07yvRd-PD4kcJP6U-945x2048.jpg Capture d’écran 2024-04-07 à 18.54.23.png Capture d’écran 2024-04-07 à 18.54.07.png
      Do you know where it comes from ? This is my set up :
      Vertical used with Stryd foot pod in auto calibrate mode (so it should use the GPS for calculating distance, and not the pod)
      Vertical Software = 2.33.12
      Serial Number = 241010000231
      Model Number = OW222
      Hardware = 3137E2
      Assisted GPS = 2024-04-07T00:00:00
      GPS = v00.144
      Touch = C1.10.6
      Bluetooth = 3.0.32
      PPG Version = 0.4.38
      WLAN = V000044
      Thanks for your help and any lead is welcome 😊.
      • MiniForkliftM Offline
        MiniForklift Platinum Member
        I’m not sure what’s happening but just wanted to jump in and say great running, that’s an awesome time. Well done!
        SV Titanium Solar Forest
        Gilles D.G 1 Reply Last reply Reply Quote 0
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Gilles D.
          @Gilles-D If the Stryd was paired as a footpod all distance and pace will come from Stryd and not the watch. Auto-calibrate does not default to the watch and Stryd recommends not to auto calibrate with Suunto watches. Only if the Stryd is paired as a powerpod will the distance and pace come from the watch.
          Vector/T6c/Vertical 2 Ti
          Gilles D.G 1 Reply Last reply Reply Quote 3
            Gilles D. @MiniForklift
            @MiniForklift thank you!
              Gilles D. @Brad_Olwin
              @Brad_Olwin thanks a lot!! I was the one who post a similar issue with S9B, and the root cause is actually the same. So nothing to do with GPS and watch quality, rather a wrong configuration / understanding with a 3rd party device like Stry from my end! I think I am gonna drop the Stryd, since the Vertical has an embedded power calculator…
              Have a nice day, topic is closed 🙂
                @Gilles-D In testing prior to releasing the Stryd a number of us tested Suunto power vs Stryd. They were very close. That was with the Wind version and I do not know if newer versions are different. Suunto power is a little less sensitive for me as I notice that the max on very hard intervals is a bit lower with Suunto but averages were very close.
                • First post
                  Last post
                Suunto Terms | Privacy Policy
