    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Still no proper BT sensor management with latest update .... :(
    Scheduled Pinned Locked Moved Suunto Race
    14 Posts 10 Posters 2.0k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Olaf GottschalkO Offline
      Olaf Gottschalk Bronze Member
      Re: What are the chances that proper Bluetooth accessory management is added to the Race?
      The trouble with the miserable BT sensor ā€œmanagementā€ is now getting really, really painful.
      My latest road bike has a built-in power meter - but it is only one-sided, so I still want to use my Wahoo Speedplay Dual side pedals.
      Now: how on earth do I deliberately select the correct sensor to pair?
      I see no way to make sure the right one is connected - neither does it SAY which one is connected nor do I get a choice.
      And now? What should I do?
      Mads Hintz-MadsenM DurriD 2 Replies Last reply Reply Quote 2
      • Mads Hintz-MadsenM Offline
        Mads Hintz-Madsen Silver Members @Olaf Gottschalk
        @Olaf-Gottschalk if you don’t plan on using the built-in power meter, can you then remove the battery or disable the integrated power meter?
        Or simply take the power meter pedals off the bike and move out of BT range from the bike (or wait until the integrated power meter goes to sleep) and then do the pairing with the watch. You anyway only need to do this once if you are only planning on using your power meter pedals.
        Ze StuartZ Olaf GottschalkO 2 Replies Last reply Reply Quote 2
        • Ze StuartZ Offline
          Ze Stuart Gold Members @Mads Hintz-Madsen
          @Mads-Hintz-Madsen spot-on technical solution, but @Olaf-Gottschalk’s point stands: the sensor management is abysmal.
          Olaf’s point about not being able to pick a sensor is the tip of the iceberg: Suunto’s lack support for how sensors are structured on a bike, specifically speed sensor on the front wheel, and either a discrete cadence sensor on the cranks, or cadence/speed from cranks/pedals is out of date (they believe you’ll have their bike pod, which combines speed and cadence, with two magnets that slip and don’t fit all bikes).
          Now, there’s that nice interview in Italian somewhere that says something big is coming for bikes this year (summer firmware?) so maybe cyclists will finally be able to use their Suunto like everyone else - even Apple Watch users - can, but for now, it’s really rather limited.
          https://zulusierra.co
          FunkyLarmaF I 2 Replies Last reply Reply Quote 8
          • FunkyLarmaF Offline
            FunkyLarma @Ze Stuart
            @Ze-Stuart think this is the article you mention: https://saketonemo.it/talking-about-suunto-with-suunto/
            We can only hope that being a triathlete Markus has more than one bike or power meter and can direct Suunto on how devices work in 2024.
            Personally I would also welcome an integration with other platforms if they can not implement. Let me import my Wahoo data like they have done recently with Xiaomi.
            Ze StuartZ ChrisAC 2 Replies Last reply Reply Quote 3
            • I Offline
              i5boi @Ze Stuart
              @Ze-Stuart my SRAM AXS Force d2 does power & cadence just fine although I do wish power was both sided. I guess it’s just an average as the axs is dual sided, not the one crank arm method.
              Do we think dual sided power will come in a future update? This would address any of my cycling needs as I don’t need the always on maps for navigation.
                Ze Stuart Gold Members @FunkyLarma
                @FunkyLarma that’s the article, agree on all points.
                • DurriD Offline
                  Durri @Olaf Gottschalk
                  @Olaf-Gottschalk no problem for me, I have a Wahoo cadence sensor and a Polar H10āœŒļø
                  Suunto Race Titanium, Suunto 9 Baro Titanium, Polar V800, Vostok Anchar Europe Titanium, Hoka One One, Focus Atlas 6.8, Rose Pro SL, Giant Roam 2
                  Olaf GottschalkO 1 Reply Last reply Reply Quote 0
                  • L Offline
                    Likarnik Gold Members
                    How to know where does cadence data come from? I have Suunto bike pod for many years now and also Favero dual sided power meter. I had cadence via bike pod before, but when I went on vacation an rented a bike, I took my pedals with me. And I had cadence data for all my rides with PM. Does PM override bike pod cadence? I’m thinking about ditching my bike pod…
                    Mads Hintz-MadsenM 1 Reply Last reply Reply Quote 0
                      Mads Hintz-Madsen Silver Members @Likarnik
                      @Likarnik the Assioma pedals provide cadence data to the Suunto watch along with the power data as you noticed. So I think that you can safely ditch Suunto’s bike pod.
                      Regarding which cadence data gets recorded by the watch if you have both power meter pedals and the bike pod paired, I have no idea.
                      • ChrisAC Offline
                        ChrisA Platinum Member @FunkyLarma
                        @FunkyLarma said in Still no proper BT sensor management with latest update .... šŸ˜ž:
                        Getting more such integrations is something I really think could Suunto set apart from other companies. I would love to see integration of e.g. Oura’s sleepdata from their rings, so you could just wear the ring at night and not the watch (besides the fact, that they’re both located in Finland šŸ˜…)
                        Currently Race I
                        • seanvkS Offline
                          seanvk
                          There have been a lot of requests for support for multiple sensors with better management. I have no idea when they will ever support this but it is really disappointing.
                          https://forum.suunto.com/topic/6188/can-i-connect-multiple-sensors?_=1712202347230
                          Suunto Vertical Titanium
                          Suunto 9 Peak Pro Forest Green
                          Suunto 9 Peak Moss Gray
                            Olaf Gottschalk Bronze Member @Mads Hintz-Madsen
                            @Mads-Hintz-Madsen no, I have to do this over and over again as I already have to unpair and pair again when using the Kickr bike.
                            And no - removing the battery is not an option as I want both meters to work in order to compare them by recording one with an app and one with the Race.
                            This whole situation is a mess and totally unworthy of the otherwise good hardware of the Race.
                            Brad_OlwinB 1 Reply Last reply Reply Quote 2
                              Olaf Gottschalk Bronze Member @Durri
                              @Durri you did understand my post? If you only have ONE sensor per type, of course you don’t have a problem.
                              My setup:
                              Kickr bike (power, cadence & speed)
                              Bike 1 with Wahoo Speedplay power meters, Bontrager Speed&Cadence sensor
                              Bike 2 with SRAM Axis power meter and Wahoo speed sensor
                              Now, how do you technically ā€œmanageā€ these sensors?
                              Even worse: when I forget to unpair&pair again at home and my GF is already on her Kickr setup, I cannot pair my bike as there already is more than one sensor in the room sending information and because you do not see which one the Race connects to, you are f***ed.
                              • Brad_OlwinB Offline
                                Brad_Olwin Moderator @Olaf Gottschalk
                                @Olaf-Gottschalk As others have said, this has been an issue raised several times. I used to bike race but no longer, I had three bikes and this would be a real issue for me as well. We can only hope that it is something in progress. I understand your frustration.
                                Vector/T6c/Vertical 2 Ti
                                With your input, this post could be even better šŸ’—
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
