    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Issue with Suunto Vertical Barometric Pressure Display
    Scheduled Pinned Locked Moved Suunto Vertical
    12 Posts 5 Posters 1.3k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ali malekzadehA Offline
      ali malekzadeh
      the barometric pressure display only shows values above 1000 mbar, photo is attached. I am concerned whether this indicates a malfunction or if there is a setting that needs adjustment.
      sartoricS ali malekzadehA Matija SM 3 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @ali malekzadeh
        @ali-malekzadeh
        how do you know it’s wrong?
        Do you have any checkvalue ?
        Did you try auto adjust?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.10.7 beta
          ali malekzadeh @ali malekzadeh
          @ali-malekzadeh
          yes, i did auto-adjust altitude plus in every workout it gets adjusted automatically.
          GiPFELKiNDG 1 Reply Last reply Reply Quote 0
          • GiPFELKiNDG Online
            GiPFELKiND Silver Members @ali malekzadeh
            @ali-malekzadeh Check the values from your wearher Station… Online for example. For every place you can read there the actual barometric pressure
            If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
            ali malekzadehA 1 Reply Last reply Reply Quote 1
            • Matija SM Offline
              Matija S Bronze Member @ali malekzadeh
              @ali-malekzadeh I am not shure what exactly concerns you, but lets try to figure out. Are you concerned the baro value is too high for that altitude?
              ali malekzadehA 1 Reply Last reply Reply Quote 0
                ali malekzadeh @GiPFELKiND
                @GiPFELKiND in my phone’s barometer it is around 842.38 mbar
                  ali malekzadeh @Matija S
                  @Matija-S yes , i think is not correct, in my phone’s barometer it is around 842.38 mbar while suunto showing 1015 mbar
                  TieutieuT Matija SM 2 Replies Last reply Reply Quote 0
                  • TieutieuT Offline
                    Tieutieu Platinum Member @ali malekzadeh
                    @ali-malekzadeh 842hpa is beyond the lowest ever recorded pressure.
                    If your phone has a real barometric sensor, trust your Suunto
                    If he has not, trust your Suunto.
                    Check wiki page for pressure.
                    1013hpa/mbar is the normal pressure.
                    Suunto’s devices at home :
                    Vertical titanium solar
                    Suunto Race S
                    S9pp titanium sand
                    Suunto Wing & Spark
                    S9B titanium Ambassador edition, A3P, X6
                    Matija SM 1 Reply Last reply Reply Quote 0
                    • Matija SM Offline
                      @ali-malekzadeh the reason is that Suunto is reading QNH pressure (which is your local pressure converted to sea level). You see it says QNH next to the value. Its a value used by airplanes to get altitude, since they use altitude above sea level. You can compare it to your closest airport (just google your local airport ICAO code and word “metar”). You will find Metar to be a text weather at the airport with QNH at the end of the reading (for example Q1015 in your case) Reading from your watch should be close to QNH reported by the airport.
                      Since you seem to be high above sea level, QNH will be much higher than your local pressure.
                      If you need help with obtaining that info, just send me a private mesaage with your closest airport name and I will help you find the data
                      ali malekzadehA 1 Reply Last reply Reply Quote 6
                      • Matija SM Offline
                        Matija S Bronze Member @Tieutieu
                        @Tieutieu his phone is correct,
                        His suunto is also correct, they just use different reference systems (QNH/QFE)
                        TieutieuT 1 Reply Last reply Reply Quote 3
                        • TieutieuT Offline
                          Tieutieu Platinum Member @Matija S
                          @Matija-S ok thanks for the detailled explanations you’ve given.
                          (I was right anyway => he can trust his Suunto !! 😊 😊 )
                          Suunto Race S
                          S9pp titanium sand
                          Suunto Wing & Spark
                            @Matija-S thank you for the prompt reply ,
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
