    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    No information from Suunto Vertical watch when changing direction during navigation
    Scheduled Pinned Locked Moved Suunto Vertical
    21 Posts 9 Posters 1.9k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • N Offline
      neverhood
      What I am doing wrong.
      I have a problem with navigation on this watch. I walk with poles because I have back problems. When I set myself up for example for Nordic Walking and choose to follow a set route, I have a problem when navigating. When I come to a turn about 95-96m before I get the information from the watch that there will be a turn, but not at the point of the turn. What could be wrong with the navigation settings? Is it possible to change this somehow? It’s a problem for me because I’ve already happened to get lost a few times and because of my back problems I’m in pain afterwards because I’m making up a lot of ground. I would be very grateful for your help.
      Peter
      GiPFELKiNDG Brad_OlwinB 2 Replies Last reply Reply Quote 2
      • GiPFELKiNDG Online
        GiPFELKiND Silver Members @neverhood
        @neverhood that is the way this route navigation works on a suunto watch 😂😜🤷🏼 sorry. 100m before the Turn it give a beep and Vibration, you have to look when the 100m ends. Cause after your Turn the next Turn info in the future comes… 🙄 That is how it works. Not specially good - but a navigation like this is better than a watch without navigation. But if you follow your track you see on the map when you have to Turn.
        If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
        • MiniForkliftM Offline
          MiniForklift Platinum Member
          You aren’t doing anything wrong, I think Suunto have always had it set like this. I don’t personally have any issues with it and I actually find it better being notified 100m before rather than when I arrive at the turn. It gives me time to scroll through the map screen if I’m not already on it, and if I’m running on trails or it’s unclear which turn/path I should be taking I just zoom right in to make sure I stay on route 👍
          SV Titanium Solar Forest
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @neverhood
            @neverhood I turn off turn by turn as I do not need to be notified. I can look at the watch and see the direction I need to go. I do not like having the constant vibration for turns when out on the trails.
            Vector/T6c/Vertical 2 Ti
            MiniForkliftM enriqueescomsE 2 Replies Last reply Reply Quote 1
              MiniForklift Platinum Member @Brad_Olwin
              @Brad_Olwin said in No information from Suunto Vertical watch when changing direction during navigation:
              This is what I do to, I don’t have it enabled as I find the alerts distracting and even more so if I’m running in a town or city with numerous turns
              • R Offline
                Redbird
                , je ne suis pas le seul à ne pas adhérer avec ce guidage comme telle. Je me sert de la navigation principalement à vélo, j’ai vraiment du mal à suivre un itinéraire "étape par étape " comme il est présenté actuellement. Je n’ai pas toujours la possibilité d’avoir le regard sur le poignet ( montre ) soit pour cause de trafic !! ou encore une descente rapide à vélo, une route ou chemin dégradés mais aussi des manches longue sur les bras en plein hiver donc écran pas lisible directement !!. Un affichage comme il est proposé actuellement 100m avant le carrefour avec une durée de 3 secondes puis plus rien est inapproprié pour une bonne navigation !!! quand je suis dans un carrefour ma vue est en direction de la trajectoire du vélo et non sur l’écran de ma montre pour m’indiquer un changement de direction qui arrivera que bien plus tard !! cela est une question de sécurité et de bon sens pour une pratique à bicyclette … Je suggère à Suunto d’avertir comme actuellement le changement de direction 100m avant mais de laisser l’affichage " étape par étape " jusqu’à la fin ( du changement de direction ou sortie du virage ). Et ainsi avoir la possibilité de visionner en temps réel la direction à suivre avec une vraie certitude !! et sans devoir basculer à chaque fois sur l’écran ( petit poucet ) pour voir si je suis bien sur l’itinéraire .
                Si vous êtes de mon avis faite le savoir ou remonter afin qu’une mise à jour change cela. Merci d’avance …
                J’ai déjà posséder une montre d’une autre marque qui fessait cela très bien et nul besoin d’avoir une cartographie pour bien se diriger.
                Pour toutes les autres fonctions de la montre je suis vraiment satisfait, je remercie encore Suunto, vraiment un très beau produit avec une finition exemplaire et très élégante au poignet Merci
                TieutieuT 1 Reply Last reply Reply Quote 0
                • TieutieuT Offline
                  Tieutieu Platinum Member @Redbird
                  @Redbird : many times discussed. Almost everybody agree that the way it actually works is not the best.
                  For now it has not evolved.
                  I also use navigation a lot, for biking, hiking.
                  Since I use maps with the vertical, I don’t use turn by turn alerts anymore, but I also would be please to see improvements with the way it works.
                  the most annoying thing to me is especially the fact that the second alert (which tells the next point) is precisely « hiding map » at the turning point.
                  I’d rather have a first alert « y » meters before the turn, and a second « x » seconds (based on speed, so distance would be different depending on which activity you’re practicing) before the turning point, and then have the map displayed when arriving to turn.
                  The next turn alert could also be displayed few meter after turning point.
                  Or, like you said, having indications as an overlay on map would be awesome.
                  Suunto’s devices at home :
                  Vertical titanium solar
                  Suunto Race S
                  S9pp titanium sand
                  Suunto Wing & Spark
                  S9B titanium Ambassador edition, A3P, X6
                  1 Reply Last reply Reply Quote 4
                  • N Offline
                    neverhood
                    Thank you for your answers.
                    I’ve only used car navigation so far and it’s probably habits I need to get rid of.
                    I have one more question. When I create a route in the Suunto app on my watch, I don’t get any notifications. Is there something I need to do?
                    Fortunately, I use plotaroute and then I have notifications, but it is annoying that the Suunto app does not export notifications after synchronising the route with the watch.
                    Mff73M Brad_OlwinB 2 Replies Last reply Reply Quote 0
                    • Mff73M Offline
                      Mff73 @neverhood
                      @neverhood
                      The problem is not really the syncing of turns from outside sources to Suuntoapp and the watch, it is the way the watch is managing the notifications : at a turn, there is a special point with indication that there is something to notify. And the watch is warning 100m before it, and nothing else, and then it is focused on the next turn.
                      Whatever you can do with plotaroute or komoot or any other routes, if the watch mechanisms are not changed, it will stay the same.
                      SSU (retired), SV1, SV2
                      Wife : S9PP
                      SA: Always the latest beta :)
                      Android + Galaxy S205G
                        @neverhood You need to turn on turn by turn, it is not on by default, when creating a route.
                        AudaxjoeA 1 Reply Last reply Reply Quote 0
                        • AudaxjoeA Online
                          Audaxjoe @Brad_Olwin
                          I’ve never created a route on Suunto App but via Kamoot turn by turn is the default. Strange it is the opposite 🤷🏻‍♂️
                          I also turn the turn by turn off.
                          Suunto Vertical
                          Suunto 9 BARO
                          Garmin Fenix 3, 5
                          Suunto Vector
                          • TieutieuT Offline
                            Tieutieu Platinum Member @Audaxjoe
                            @Audaxjoe you should try native route creation with SA ! 😊
                            I’ve tried komoot a few times. SA is so much easy to me ! (Except maybe if you are using existing routes in komoot).
                            Suunto Race S
                            S9pp titanium sand
                            Suunto Wing & Spark
                            AudaxjoeA 1 Reply Last reply Reply Quote 1
                            • AudaxjoeA Online
                              Audaxjoe @Tieutieu
                              @Tieutieu said in No information from Suunto Vertical watch when changing direction during navigation:
                              I think the issue is activity. My main need for a route is cycling, normally in the range of 150-200k. SA isn’t the easiest on a phone for these distances! Or not in my experience anyway 🤣 It could be user error…
                              Suunto Vertical
                              Suunto 9 BARO
                              Garmin Fenix 3, 5
                              Suunto Vector
                              TieutieuT Brad_OlwinB 2 Replies Last reply Reply Quote 1
                              • TieutieuT Offline
                                @Audaxjoe so for you need I can understand why you use komoot ! (Even if SA works well also for cycling to me 😊 )
                                Suunto Race S
                                S9pp titanium sand
                                Suunto Wing & Spark
                                  Brad_Olwin Moderator @Audaxjoe
                                  @Audaxjoe Use a tablet or computer.
                                  MiniForkliftM 1 Reply Last reply Reply Quote 1
                                    How do you get the SA on your computer? Probably a stupid question but oh well 😊
                                    Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                      Brad_Olwin Moderator @MiniForklift
                                      @MiniForklift On my Mac SA runs great. On Windows 11 I believe Android apps also run.
                                      • enriqueescomsE Offline
                                        enriqueescoms @Brad_Olwin
                                        @Brad_Olwin I do the same as you, I also turn off turn-by-turn, but I understand that this is not a solution to what the colleague is asking.
                                        In the end, as the turn-by-turn works in such an unhelpful way, it ends up being a useless feature. It’s a pity.
                                        Suunto 9 Peak Pro (all black version)
                                        Suunto Race S (gravel gray)
                                        TieutieuT Brad_OlwinB 2 Replies Last reply Reply Quote 2
                                        • TieutieuT Offline
                                          Tieutieu Platinum Member @enriqueescoms
                                          @enriqueescoms when I had no maps (with A3p, S9b…), first there was no turn by turn. When it arrived on S9B, I used it but with the same limitation than now.
                                          With the SV and maps, If find it less usefull.
                                          When I still use it, I often remove most turning points, only to keep the key ones on my way (complex crossings for examples…). But I only use it as a warning for map looking !
                                          Suunto Race S
                                          S9pp titanium sand
                                          Suunto Wing & Spark
                                          enriqueescomsE 1 Reply Last reply Reply Quote 2
                                            enriqueescoms @Tieutieu
                                            @Tieutieu Yes, I do much the same. Maybe if the turn-by-turn worked differently I would use it more. Maybe, I don’t know.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
