screen stuck after solar charging
sometimes when the watch is direct to sun about one minute and charging my screen touch stuck…or dont work corectly sometimes work with huge delays or the lock screen dont work or the backlight open itself…
sometimes not.
i solve the problem by soft reset, but its the second time with that issue.
everthing else works perfect.anyone notice same problem?
thanks! -
@gerasimos Got same problem. After some minutes on total sun, it’s have problem with brightness mode. Its dark and starts to be brighter after some sec. Like delay with changing brighness after “wake up” by button press just like You. But i never needed to reset watch. I call it “deep sleep” mode. Watch need coffee after sun bath.
@Tami999 I hope this stuck is permanently, and when we go out to record activity with enough and strong sun we will not have reliability issues with stucks, delays, record ect…
also its difficult to test it an be sure because sun its not the same everyday day or to strong, it’s a bit hypothetical
Register Login
