    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Green/yellow lights keep coming on
    3 Posts 2 Posters 873 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • David YoungD Offline
      David Young Bronze Member
      Something I did recently has triggered this. It’s either the hard reset I did to fix a sync problem, or the latest update.
      What happens is that the green/yellow lights on the back of the watch arbitrarily turn themselves on and then stay on for maybe a minute.
      Previously I never saw the lights unless I was navigating through the options from the normal watch screen to the altitude/temperature screen.
      I understand that the lights have something to do with heart rate monitoring. I have never used my watch to monitor my HR and have never even explored the HR options.
      I don’t particularly mind the lights coming on except that I assume they must be draining some power from the battery.
      Is there anything I can do to stop my watch turning on its green/yellow lights for no reason?
      freeheelerF 1 Reply Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @David Young
        @David-Young
        no, if you scroll thru the menu to the alti screen you’ll pass HR screen and this triggers HR measuring and hence activates the LEDs.
        they only light up when you scroll thru the menu. if you saw the LEDs lighting up randomly you might have 24/7 HR active and you can toggle it off in the settings.
        living sideways
        David YoungD 1 Reply Last reply Reply Quote 1
          David Young Bronze Member @freeheeler
          @freeheeler Yes, that was on. I’ve turned it off.
          The setting is found at Settings > Activity > Daily HR
          Thanks for your help.
          David.
          • First post
            Last post
          Suunto Terms | Privacy Policy
