    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Altimeter recordings while running
    Scheduled Pinned Locked Moved Suunto Vertical
    86 Posts 18 Posters 22.6k Views 17 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      Mauerwegler @Łukasz Szmigiel
      @Łukasz-Szmigiel said in Altimeter recordings while running:
      All Suunto watches from S-series that have barometer have FusedAlti (S9B onwards).
      SSU too:
      Vertical All Black
      Spartan Ultra Stealth Ti (with Polar H10 or Suunto Smart Sensor)
      Vector
      iOS Suunto App (beta)
      • Tadas LingeT Offline
        Tadas Linge @Mff73
        @Mff73 hello, not exactly. What i see, that watch fresh after hard reset is showing really good results, but then whith each use it is getting worse.
        Mff73M 1 Reply Last reply Reply Quote 0
        • Mff73M Online
          Mff73 @Tadas Linge
          @Tadas-Linge
          Worse? average dif from 2m to 7m? 🤔.
          SSU (retired), SV1, SV2
          Wife : S9PP
          SA: Always the latest beta :)
          Android + Galaxy S205G
          Tadas LingeT 1 Reply Last reply Reply Quote 1
            Tadas Linge @Mff73
            @Mff73 hello. Yes, so this is just average, but you also need to see point by point, because in the first run there is no deviation above 10, then in second one already one such deviations and in third one there are qoote few 12s and 13s… Dont you think it is tendency? Of course i will continue fill this table, but this is what i see now.
            I 1 Reply Last reply Reply Quote 0
            • I Offline
              Iceman1 @Tadas Linge
              @Tadas-Linge I have tried a couple of times to set the elevation far off from the real elevation. Then I let fusedalti correct everything. When I have one this I have a nice elevation graph in the end, starting and ending within1 meter or so.
              When I dont adjust, and the elevation from the start is within 10-15 meters off from the real elevation, then that difference is kept, and is not touched by fusedalti.
              I understand 10-15 m is not much, but it is very noticable on flat runs.
              isaziI Tadas LingeT 2 Replies Last reply Reply Quote 1
              • isaziI Offline
                isazi Moderator @Iceman1
                @Iceman1 because the GPS vertical error is large-ish, calibration is only performed if deviation is substantial. If the deviation is within GPS error, the watch cannot know which one between altimeter and GPS is correct (tie-breaking with only 2 sensors is kinda impossible).
                Blog: isazi's home
                I 1 Reply Last reply Reply Quote 1
                • I Offline
                  Iceman1 @isazi
                  @isazi yes I have understood this is the way it works. I just posted a possible way to “trick” the watch, If you like.
                  Instead of graphs like this starting at -7 m and ending at 5m
                  I get graph like this starting at 7 m and ending at 8m
                  Redbeard_rangerR 1 Reply Last reply Reply Quote 3
                  • Redbeard_rangerR Offline
                    Redbeard_ranger @Iceman1
                    @Iceman1 Very interesting trick, How much do you off set the altitude by incorrectly? like 1000m?
                    Mff73M I 2 Replies Last reply Reply Quote 0
                    • Mff73M Online
                      Mff73 @Redbeard_ranger
                      @Redbeard_ranger
                      with 1000m dif, you will for sure see the job of fusedalti 🙂
                      @Iceman1
                      second graph looks better, but it is also another day, so, maybe, this second day could have been better, even without the altitude offset trick.
                      But it opens the door to check “longer” and see. If with big initial offset, fusedalti is able to catch a “better” altitude fix than just letting it alone, it would be interesting to know. Probably this situation is already tested, but i will personnaly try
                      Wife : S9PP
                      • I Offline
                        Iceman1 @Mff73
                        @Mff73 You are correct that its not really possible to compare different days. It would be interesting If somebody with two watches could try to test them parallell 🤔
                        • I Offline
                          Iceman1 @Redbeard_ranger
                          @Redbeard_ranger I have just set it around 50-60 m off.
                            Tadas Linge @Iceman1
                            @Iceman1 hello, actually this is what i was thinking to do but never done… we are out with family for long weekend so i have done couple of runs in different location. first thing what i have done i set up my actual elevation…:D and one day was beautiful day so readings of altimeter was really good. next day after the run i had +22meters at the finish which was the same point for start. so i have checked barometer and it had huge drop, so it kinda explains, but still i expect that watch evaluates such things during GPS activity. So my wife was going for the run same day, i have checked her Forerunner 255 and her altimeter was off +40 meters before run, because she does not care about it and never adjust. when she came back and i have checked her altitude graph and deviation was 2 meters for the start and finish point… this is what i was getting when were using Fenix 7x, never had to think about calibration or anything, watch was doing everything during GPS activity. with basically no deviation, therefore now it is getting more and more annoying…
                              @Iceman1 Hello, today i have tried this trick. instead of 45m i have manually entered 160meters, but watch did not corrected anything:
                              I Dimitrios KanellopoulosD surfboomerangS 4 Replies Last reply Reply Quote 0
                              • I Offline
                                @Tadas-Linge So your real elevation at at start and finish is 45 meter? Thats not good at all!
                                Tadas LingeT 1 Reply Last reply Reply Quote 0
                                  Dimitrios Kanellopoulos Community Manager @Tadas Linge
                                  @Tadas-Linge is your starting elevation 45?
                                  Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                                    @Tadas-Linge and the start to end diff is like 5-10m if you are bothered by this idk what to say
                                    I Tadas LingeT 2 Replies Last reply Reply Quote 0
                                    • I Offline
                                      Iceman1 @Dimitrios Kanellopoulos
                                      @Dimitrios-Kanellopoulos but 120 meters off is ok? I wouldnt be happy with that…
                                        @Iceman1 yes
                                          Tadas Linge @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos yes, but watch did not corrected deviation of in altitude of 120m. Today already delivered watch to support for check
                                          • surfboomerangS Offline
                                            surfboomerang @Tadas Linge
                                            @Tadas-Linge said in Altimeter recordings while running:
                                            If I remember correctly fusedalti doesn’t correct your altitude when you manually changed it before the activity. Read it somewhere on this forum.
                                            Suunto Vertical Titanium Solar
                                            OnePlus Nord 4
                                            pilleusP Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
