    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Swiping left/right to access mulitple attached widgets?
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    44 Posts 19 Posters 12.5k Views 18 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      jw cou Silver Members @Brad_Olwin
      Thanks for setting up the votes! It’s great proof of how difficult it is for companies to operate a change that most will like, while keeping everyone happy
      • F Offline
        fv4500 Bronze Member
        For me, the consistency of the UI with the physical buttons is a fantastic feature. I don’t use the touch screen at all, and after some weeks with the new UI I’m riding again that wave of the “muscle memory” for my most used “workflows”. And I love it. So, I understand that if there’s no physical left button, there’s no left swipe. Could it be there? Sure… but I feel that this would break that consistency. Not judging the design choice by Suunto nor the convenience for some users of having that left swipe: that’s simply how I use my watch. 😅
        Ars VitaeA 1 Reply Last reply Reply Quote 2
        • Ars VitaeA Offline
          Ars Vitae Silver Members @fv4500
          @fv4500 The middle button is used to move horizontally. This was the same before, and it is the same now, to get to a single pinned widget. Scrolling across the display is faster and simply incomparably more convenient than the buttons, but it does not work in contact with water and a gloved hand. It is therefore important to keep the buttons fully functional in all conditions. This is how I understand the idea of the watch designers.
          • Łukasz SzmigielŁ Offline
            Łukasz Szmigiel
            The only thing that bothers me with the new UI is being unable to quickly jump to watchface by holding the middle button.
            Somehow it gets back only to mini-widgets and requires another press and hold to get to watchface. It works as before in settings though.
            S9PP 2.50.28
            Mads Hintz-MadsenM Ars VitaeA 2 Replies Last reply Reply Quote 2
            • Mads Hintz-MadsenM Offline
              Mads Hintz-Madsen Silver Members @Łukasz Szmigiel
              @Łukasz-Szmigiel I find that two quick presses on the bottom right button to get back to the watch face from a widget is just as fast or maybe even quicker than a long press on the middle button.
              Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                Ars Vitae Silver Members @Łukasz Szmigiel
                @Łukasz-Szmigiel You are right, for example, when we are in the settings in whatever function by holding down the middle button you can see how it jumps back through each menu step of the interface.
                1 Reply Last reply Reply Quote 3
                  Łukasz Szmigiel @Mads Hintz-Madsen
                  @Mads-Hintz-Madsen which watch are you referring to?
                  S9PP 2.50.28
                  Mads Hintz-MadsenM 1 Reply Last reply Reply Quote 0
                    @Łukasz-Szmigiel Good catch! I’m talking about the Race which I believe has the same UI as 9PP after the recent updates.
                    Is the two quick presses on the bottom button not a viable option for returning to the main watch face on the 9PP?
                      @Mads-Hintz-Madsen nope. Controls are different between Race and Vertical / 9PP.
                      Bottom button in 9PP just scrolls down.
                      S9PP 2.50.28
                      Mads Hintz-MadsenM 1 Reply Last reply Reply Quote 2
                        @Łukasz-Szmigiel
                        Ah, yeah. Makes sense due to the lack of a crown in Vertical/9PP.
                        • F Offline
                          false Silver Members
                          Any ideas on how to UNPIN a widget?
                          Brad_OlwinB 1 Reply Last reply Reply Quote 1
                          • Brad_OlwinB Offline
                            Brad_Olwin Moderator @false
                            @false Pin a different widget.
                            Vector/T6c/Vertical 2 Ti
                            F 1 Reply Last reply Reply Quote 1
                            • F Offline
                              false Silver Members @Brad_Olwin
                              @Brad_Olwin Do you think this is good UX?😢
                              Mads Hintz-MadsenM Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                Mads Hintz-Madsen Silver Members @false
                                @false said in Swiping left/right to access mulitple attached widgets?:
                                What do you mean? You pin a favorite widget until you have a new favorite and pin that instead. What’s bad about that?
                                • F Offline
                                  false Silver Members @Mads Hintz-Madsen
                                  @Mads-Hintz-Madsen By default this position on the right is empty. So I see pin/unpin scenario just the same as on/off. Now you have to have your favourite widget but what if you don’t have one? Moreover all of the widgets are on your fingertips on the bottom screen where you can put your favourite widget on the top of the list
                                  As far as I remember, on the previous software I was able to switch off all the widgets and leave with watch face only. It was really good
                                  • Cassie KimC Offline
                                    Cassie Kim
                                    Hi I’m from Korea!
                                    This update is absolutely terrible…I can’t focus on work-out even! I didn’t know what’s going on until I found this posting, so I reset my Suunto 9 pro… multiple times!
                                    Please let us just use swiping left and right to access mutiple widgets!
                                    ? 1 Reply Last reply Reply Quote 1
                                      @false I prefer this UX over the prior one. I have asked for left to right swipe for one additional widget when testing this UX. So, different from your request, which I understand. If you want a widget you can simply vertical scroll. I get your logic and having no favorite ought to be a choice. Not sure this will get traction but I will mention it.
                                      F alschmidA 2 Replies Last reply Reply Quote 0
                                      • ? Offline
                                        A Former User @Cassie Kim
                                        @Cassie-Kim There is a poll on the forum and the majority prefer the new UI/UX for now.
                                        • F Offline
                                          @Brad_Olwin said in Swiping left/right to access mulitple attached widgets?:
                                          It will be great. Thanks
                                          • alschmidA Offline
                                            alschmid @Brad_Olwin
                                            @Brad_Olwin. The question “Swiping left/right” for the widgets VS. the “new UX” apparently has stirred up some fuzz here on the forum. However, being new here, I find the discussion on this productive question took a rather destructive turn. What was missed, is the actual substance of the matter.
                                            Therefore, I’d like to subsequently report on my recent experience. I do so in the hope that we could take up again the discussion in a more constructive way and maybe find a solution forward.
                                            Just activated my Suunto Vertical, apparently with the “old UI” on it (whatever version). Much like described on (the still current) “HOW CAN I CUSTOMIZE THE WIDGETS OF MY SUUNTO WATCH?”, I could scroll through my widgets. Fairly intuitive, I found, also because one could scroll through the widget screens by swiping or the middle-button and getting a good grasp of the state of an athlete’s internal and external conditions.
                                            It seems that the firmware on my watch was updated over night (to 2.33.12). This forced me to pin a widget, resulting in a different UX. The change came quite abrupt, not because the UX changed (differing also from as it described in the manual), but because the changed UI exhibits illogical behavior, some of it being:
                                            a) The user can pin a widget, but not unpin. (Isn’t the logic of pinning that you can unpin whatever you pinned? Otherwise it would rather be two “screens/slots” to be filled.)
                                            b) The user can only pin one widget, but not none, two, or more. (Why is ONE the right number of pin slots? If you can have one, it seems at least you should be able to have zero or better even also more than one.)
                                            c) Widgets that are deactivated on the watch and/or in the smartphone app can still be pinned. (Why would a deactivated widget be “pinnable” at all, and appear when I scroll right, also after I deactived the widget (on the watch and/or the smartphone)? A deactivated widget should not be able to be pinned, leading back to the issues (a) and (b).)
                                            d) Instead of scrolling through the widgets, in the “new UI” (speaking of 2.33.12) one can only scroll through the inventory of the widgets, only after “opening” the widgets does the relevant information become visible. (Why hiding functionality/information in more click depth, when it can be made directly available? The point has been made about gloves and water on the touchscreen etc…)
                                            So, I find the question “old vs. new UI” (as suggested in the poll) is not what the (heated) discussion was or should be about. Also, it’s not a matter of preference or opinion, but logic, intuition, and accessibility (for non Suunto fans). The question would then rather be “how to address the unintuitive UX in the newer versions of the watch UX?”.
                                            A simple solution could be to rename the “pinning” function. This might solve some irritation evoked by the term (esp. against (a) and (b)). However, point © and (d) remain unresolved.
                                            Addressing (a), (b) and/or © would could solve the terminological confusion as well as it would address the disregarded user needs from those “preferring the old UI”. Think about it: unpinning the ONE would show me all widgest horizontally, or I could pin just all widgets I like to browse through horizontally. Deactivating a widget would unpin it, leaving me with none (or all?) widgest accessible horizontally…
                                            Besides your personal preference (you prefer the “new UI” over the old one, according to the “divisively” formulated poll question), what do you think about the factual arguments on the reservations about the new UX, i.e., the vertical/horizontal arragement and the “depth” of clicks of the widget information?
                                            Anthony GuillemetteA Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
