    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Swiping left/right to access mulitple attached widgets?
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    44 Posts 19 Posters 12.5k Views 18 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Tobias LutheT Offline
      Tobias Luthe
      Hi. After the last update I cannot swipe left anymore, and to the right only for one next screen, I can only attach one widget to the right, but not more.
      Before it was possible to attach multiple widgets and swipe left or right to access them quickly.
      How can I re-activate the attaching of multiple widgets and accessing them by swiping left or right?
      Brad_OlwinB 1 Reply Last reply Reply Quote 2
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Tobias Luthe
        @Tobias-Luthe the new UI has changed this.
        Vector/T6c/Vertical 2 Ti
        • T Offline
          TimCooke777
          I have exactly the same problem. No longer can I swipe left. Please - what is the fix for this? I didn’t understand the reply ‘the new UI has changed this’.
          tazidenT zhang965Z 2 Replies Last reply Reply Quote 1
          • tazidenT Offline
            taziden Gold Members @TimCooke777
            @TimCooke777 said in Swiping left/right to access mulitple attached widgets?:
            There is no fix because it’s not a bug, this is how the user interface is now. It’s a feature, not a bug.
            S9PP
            T 1 Reply Last reply Reply Quote 0
            • zhang965Z Offline
              zhang965 @TimCooke777
              Calm down calm down, you need to understand it with your heart.
              Winners Wear Winners
              • T Offline
                TimCooke777 @taziden
                @taziden Sounds like a backward step. I can access one widget by swiping right, but no more, and nothing when you swipe left. Does one really have to go into the widget menu and scroll through them all to access the one you need?
                J zhang965Z EgikaE 3 Replies Last reply Reply Quote 1
                • J Offline
                  jw cou Silver Members @TimCooke777
                  @TimCooke777 you can remove / order the widgets that you get when scrolling up/down, so the only change is actually that it’s no longer left/right but up/down (and now you have an additional shortcut on top)
                  • zhang965Z Offline
                    No, there is no backwards steps from Suunto, they just go for another direction.
                    And the same, Suunto will define your need, so if there is only one widget attached, then it means you need only one.
                    EgikaE 1 Reply Last reply Reply Quote -7
                    • EgikaE Offline
                      Egika Platinum Member @TimCooke777
                      @TimCooke777 you can enable/disable all of them plus sort the widgets in the list according to your preference. Plus you have the pinned widget.
                      In my point of view this is a big advantage compared to the horizontal carousel before.
                      • EgikaE Offline
                        Egika Platinum Member @zhang965
                        @zhang965 said in Swiping left/right to access mulitple attached widgets?:
                        You are either trolling or did not get the concept that all the widgets are there (plus there are actually more than before all individually selectable).
                        Ars VitaeA 1 Reply Last reply Reply Quote 1
                        • Ars VitaeA Offline
                          Ars Vitae Silver Members @Egika
                          @Egika said in Swiping left/right to access mulitple attached widgets?:
                          But all widgets were also horizontally available in the previous version and you could change the order and decide which widgets to access. The only progress is that new ones have been added. Also I think it should be possible to pin more than one widget in horizontal access. I also don’t understand why criticising this modification is called “trolling” by many people. This is feedback from users who thought the previous idea was better. The fact that you like it does not mean that others do too. In my opinion, the previous version was more ergonomic, simply faster to use. I hope that at least the possibility of a second widget on the right side will be added. And let’s not forget another important aspect, for many it was probably the horizontal navigating through widgets that was the decisive factor in buying a new watch. How disappointed they must have been after the first update that changed this…
                          GiPFELKiNDG isaziI 2 Replies Last reply Reply Quote 1
                          • GiPFELKiNDG Offline
                            GiPFELKiND Silver Members @Ars Vitae
                            @Ars-Vitae it would be great to downgrade to the software before… Seems like more people want the old swiping to left and right back! So how to got the older firmware? In this forum Sometimes they are Posting software to download --> now you could do this please for all people wich wants the older design Back 👍
                            If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                            • isaziI Offline
                              isazi Moderator @Ars Vitae
                              @Ars-Vitae it was called trolling because it was a comment made by the resident troll of this forum, the one and only.
                              Blog: isazi's home
                              GiPFELKiNDG 1 Reply Last reply Reply Quote 1
                                GiPFELKiND Silver Members @isazi
                                Downgrade to another Software possible?
                                Brad_OlwinB 1 Reply Last reply Reply Quote -1
                                  Brad_Olwin Moderator @GiPFELKiND
                                  @GiPFELKiND it is and you can but you will miss out on bug fixes and improvements.
                                  • ? Offline
                                    A Former User @Brad_Olwin
                                    @Brad_Olwin for a change I’m with @GiPFELKiND. Often it is mentioned on this form “you shouldn’t buy a watch for features is might get in the future, but what it currently has”. Now the problem with Suunto is that “current functionality” is kind of a volatile concept… every new release for the past year had some new features, but also also (regression) bugs. I also dislike the new UI also and would like to go back, also because the OHR would turn off again when I say so. Loosing HRV is holding me back… for the moment
                                    Some older firmware:
                                    • https://forum.suunto.com/topic/6836/firmware-collection
                                    • https://forum.suunto.com/topic/9014/suunto-beta-release-for-suunto-9-peak-pro-suunto-9-peak-suunto-9-baro-suunto-9-and-suunto-5-peak
                                    zhang965Z Brad_OlwinB 2 Replies Last reply Reply Quote 5
                                    • zhang965Z Offline
                                      zhang965 @Guest
                                      @twekkel said in Swiping left/right to access mulitple attached widgets?:
                                      Brad_Olwin for a change I’m with GiPFELKiND. Often it is mentioned on this form “you shouldn’t buy a watch for features is might get in the future, but what it currently has”. Now the problem with Suunto is that “current functionality” is kind of a volatile concept… every new release for the past year had some new features, but also also (regression) bugs. I also dislike the new UI also and would like to go back, also because the OHR would turn off again when I say so. Loosing HRV is holding me back… for the moment
                                      Having memory is a dangerous signal on Suunto community forum.
                                      1 Reply Last reply Reply Quote -2
                                        Brad_Olwin Moderator @Guest
                                        @twekkel I understand and think if enough want changes in the UI set up a vote or a request and see if you can get back what you are missing.
                                        ? 1 Reply Last reply Reply Quote 1
                                        • ? Offline
                                          @Brad_Olwin here it is
                                            @twekkel I voted
                                            J 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
