    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Proposal to change UI for Suunto Race
    Scheduled Pinned Locked Moved Suunto Race
    raceusabilityuser interfaceuserexperience
    50 Posts 24 Posters 14.4k Views 21 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager @Olaf Gottschalk
      @Olaf-Gottschalk same here with Strava. Xxx farted for 2 mins. That’s why I don’t use it anymore.
      Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
      • J Offline
        Johann
        For me, I come from Garmin env. and “End” = Nothing.
        You should rename it by “Save”.
        Add an option to enable Hold feature on “End” and Discard" choices to prevent mistake as you have set this function on a crown button.
        And add a second option to select how many sec do you want to hold them, 1-3-5 sec.
        I would like to be able to set 1sec for “End/Save” and 3sec for “Discard”.
        Arnaud LclrA 1 Reply Last reply Reply Quote 0
        • MiniForkliftM Offline
          MiniForklift Platinum Member
          I do like the ide of renaming End to Save
          SV Titanium Solar Forest
          Olaf GottschalkO 1 Reply Last reply Reply Quote 1
          • Olaf GottschalkO Offline
            Olaf Gottschalk Bronze Member @MiniForklift
            @MiniForklift compared to the other ideas and my original idea to reorder to make End easier and safer to reach, I couldn’t care less about the actual name of the option… 🫣
            • Arnaud LclrA Offline
              Arnaud Lclr Bronze Member @Johann
              @Johann It’s funny how everyone’s got their own ideas…
              I’m 2000% in favour of moving the End/Save to the end of the list as proposed by @Olaf-Gottschalk and I really hope that this will be the subject of a firmware update.
              But I also hope that Suunto never injects configurations with 10000 parameters like Garmin, so the “choice of the number of seconds to Hold each menu function”… never please. Honestly never ! Never ! 😉
              I want to spend time running or doing sport. Not setting my watch or finding out how to set my watch on the sofa.
              After 8 years with Garmin and several watches in different ranges, I switched to Suunto in 2023, with the Race.
              MiniForkliftM J 2 Replies Last reply Reply Quote 12
                MiniForklift Platinum Member @Arnaud Lclr
                @Arnaud-Lclr I agree. Garmin is probably a good option if you’re an overthinker! There were some things I liked on the Enduro, but in general there was just too much going on and the Suunto app, IU and user experience is simply better IMO. But I do understand the struggle people would have if they’ve come to Suunto after years of using Garmin
                • J Offline
                  Johann @Arnaud Lclr
                  @Arnaud-Lclr I’m trying to understand your point of view.
                  What makes you enjoy it when someone proposes an idea?
                  Is there a rule that prevents us from sharing our opinions in the Suunto community?
                  What is the problem with having an extra option that you don’t want to use? (even though they probably won’t add it anyway)
                  It doesn’t mean that nobody needs a certain feature just because you don’t.
                  I just found out that there is another screen for confirmation after the Discard option, which is fine by me.
                  However, the question remains for End/Save.
                  And I’m like you, at least in one aspect, I want to focus on my sport (trail), and not on worrying about whether I’m going to press the right option with the right key after several hours of activity when my brain is tired.
                  • P Offline
                    paranoidrunner @Olaf Gottschalk
                    @Olaf-Gottschalk i like the discard option , as i have had a scenario multiple times which i shall outline…
                    I started a walk session and forgot to put it to pause as i reached my train station and got in… and then in-between the journey I saw the session was still on and calculating even though I was motionless (but I guess since gps tracking was enabled the watch might have thought I was moving at super-speed) !! the discard option being there allowed me to discard the activity.
                    ? 1 Reply Last reply Reply Quote 1
                    • ? Offline
                      A Former User @paranoidrunner
                      @paranoidrunner I have also used the discard function gazillion of times and tbh do not see the need to get rid of it. Imho the UI is perfectly fine as it is. Also it doesn’t bother me that the End option is where it is 🙂
                      MiniForkliftM 1 Reply Last reply Reply Quote 2
                        MiniForklift Platinum Member @Guest
                        @tomasbartko said in Proposal to change UI for Suunto Race:
                        FWIW after hundreds of activities I have never accidentally discarded one or pressed it by mistake. And as also mentioned you get a second screen to confirm that you do want to discard it
                        Often I’ll start an activity when checking screens if I load new data fields, so it’s useful (not to mention easier and faster) to be able to discard it there and then rather than have to end/save it and then have to go back and manually delete it
                        Olaf GottschalkO 1 Reply Last reply Reply Quote 0
                          @MiniForklift I don’t know how many times I need to repeat this…
                          It is not about the presence of Discard - it’s about the problematic position in comparison to End, unarguably the more useful option.
                          And your “use case” is simply just a work around for another poor point: designing screens is cumbersome and wild. Nothing I really like and enjoy. But I get your point. If I wanted to do this (maybe once …) I’d start the activities and afterwards just delete the useless recordings. I would not need discard at all and would not miss it.
                          I don’t really get all the fuzz here.
                          Having a crown you can easily turn till the virtual “end” of a list of options makes the very last and the very first options the “prime options” with the easiest reachable positions of all.
                          As a UX designer it is easy to deduct from this that clearly the most common options need to be placed exactly here: top and end. Not somewhere in the middle.
                          And for your last point “the discard even has a confirm question”: I also found that rather strange: why is Discard the only one to have that question?!? End is also dangerous if you do not want to end but select the options.
                          All in all: Suunto as propagating very good usability should try harder to convince me they have UX designers working for them… 😉🤷🏻‍♂️
                          • EgikaE Offline
                            Egika Platinum Member @Olaf Gottschalk
                            @Olaf-Gottschalk look.
                            Suunto is not there to follow each and every individuals proposals.
                            It is also not there to convince you of anything. It is there to meet the demands of as many possible customers. Your view on the world is not exclusive. Other’s have different views.
                            It makes sense to respect this.
                            If you want your statement to reach Suunto exclusively, better write them an Email. By posting in this forum you start a discussion. I don’t understand the idea behind posting “This I what I think it should be. Please don’t comment otherwise, I want this to tell Suunto only”.
                            Apart from this, I am with you that “Discard” is not really a must-have, and that “End” could be at the end of the list.
                            W 1 Reply Last reply Reply Quote 5
                            • ? Offline
                              A Former User
                              @Olaf-Gottschalk you literately wrote in your initial post:
                              “B) I simply do not understand at all who wanted a Discard option in the first place. From support staff I learned it was recently added. But WHY??”
                              And then pople commented why they like the discard option, and you called it fuzz. This a forum where pople share their experience and discuss, what did you expect?
                              1 Reply Last reply Reply Quote 11
                              • W Offline
                                wakarimasen Gold Members @Egika
                                @Egika said in Proposal to change UI for Suunto Race:
                                +1
                                Suunto Race Titanium
                                Suunto Ambit3 Peak
                                Polar H10
                                Polar OH1
                                • herlasH Offline
                                  herlas Silver Members
                                  S9PP and SV share menu layouts as SR but they don’t have the crown, coming back to this “old” conversation on where END should be, just realised that maybe the design decision to put END higher on the list to avoid having those users needing an extra button press to get to the last option,especially for END option that’ll be used a lot more than DISCARD 🙂
                                  In my opinion, having END at the bottom makes sense for RACE but it’s not the best UX for the other two ✌️ watches ⌚.
                                  SRS Ti
                                  SRun (primarily road runner so testing SRun is a must ;))
                                  Olaf GottschalkO 1 Reply Last reply Reply Quote 4
                                    Olaf Gottschalk Bronze Member @herlas
                                    @herlas you’re right. My proposal is for Race only for that exact reason.
                                    I expect Suunto to be able to ship different menu ordering on different models.
                                    It’s not the customer who should have to suffer for the wrong choice of architecture.
                                    MiniForkliftM ? 2 Replies Last reply Reply Quote 0
                                      MiniForklift Platinum Member @Olaf Gottschalk
                                      @Olaf-Gottschalk said in Proposal to change UI for Suunto Race:
                                      Are you actually serious? Different models should be given different menu layouts? Sorry but that is ridiculous
                                      That’s just your opinion. There are many people on here that are happy, and I for one have stuck with Suunto because of their architecture. If there’s something that’s glaringly wrong and a large percentage of people make it known it’s generally been rectified in a future update
                                      • ? Offline
                                        A Former User @Olaf Gottschalk
                                        I can say from a business standpoint this is exactly what YOU DON’T DO. You create a bunch of unnecessary complexity and dilute your resources. From a product management standpoint it becomes unwieldy. You want business simplification in all areas.
                                        Putting as many of your products on a single focused architecture is what all businesses strive for.
                                        Olaf GottschalkO 1 Reply Last reply Reply Quote 2
                                        • AudaxjoeA Offline
                                          Audaxjoe
                                          I certainly don’t feel I am “suffering” with Suunto. I can’t get over just how good the Vertical is. An amazing bit of kit. Others may prefer Garmin or other brands, the choice we have are fantastic.
                                          As a 57 year old who can still remember map, compass and handheld barometer and purchased the first Suunto Barometer watch (Vector?) I have to pinch myself at the tools we have available and just how good they are.
                                          I’m certainly a long way from suffering.
                                          Suunto Vertical
                                          Suunto 9 BARO
                                          Garmin Fenix 3, 5
                                          Suunto Vector
                                          1 Reply Last reply Reply Quote 9
                                          • babychaiB Online
                                            babychai Silver Members
                                            @Olaf-Gottschalk is actually looking for custom made smart+sport watch for himself
                                            Suunto Vertical Titanium Solar Black
                                            Suunto 9 Peak All Black
                                            Suunto Spartan Trainer Wrist HR (Black)
                                            M Olaf GottschalkO 2 Replies Last reply Reply Quote -3
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
