Weather widget bug!
I can confirm in my case, for my location that only temperature is working properly. The type of weather, conditions is always ‘broken clouds’. It never changes nor in forecast nor in description. Right now it’s crystal clear also forecast for all day is clear sky. Race shows ‘broken clouds’ all the time. Since i got it as brand new 2 days ago!! And the symbol of weather condition is missing of course. Any other can confirm this, or it’s only in my case?
@ppresing missing big symbol of current condition is known.
The conditions themselves for me are showing “snow” right now and it is snowing like crazy outide
Also the forecast for the day is varying. -
@Egika ok. Not in my case. In past 2 days weather condition and hourly forecast didn’t change from ‘Broken clouds’. We had rain, showers and now clear sky. Only the temperature has changed, and at least it’s correct. Let’s wait for update.
I also found that the weather icons for the overnight forecast show the sun instead of the moon.
@ppresing Coming from the Garmin Galaxy, I’ve personally discovered a much more accurate weather forecast. Whether we’re talking about temperature or other elements.
Garmin seems to control everything in relation to the airports that it is used to mastering perfectly.
Suunto seems to manage its weather differently because it’s really night and day since I switched to Suunto ! -
@Arnaud-LECLÈRE I checked between my Fênix 7 solar and Suunto Race weather widget and same predictions,same temperature each hour and rain prediction. So that bug probably doesn’t affect everyone
@tiago if I’m right about my airport thing. It’s potentially increasingly untrue the further you get from the airports.
Register Login
