    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Calories consumption
    Scheduled Pinned Locked Moved Suunto app and other software services
    31 Posts 11 Posters 4.0k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • K Offline
      Kretsu @oeagleo
      @oeagleo said in Calories consumption:
      2000 calories for an hour run seems a bit high for me, I hardly get 1300 for an hour and a half bike ride, but then, as all of the above has said, insure your physical stats are correct in both the watch, and Movescount, and especially your activity level. When comparing my Suunto with “another brand”, I discovered this website that gives estimation of calorie count based upon your heart rate. I found Suunto’s calorie expenditure closest of the one’s I’ve checked.
      http://www.shapesense.com/fitness-exercise/calculators/heart-rate-based-calorie-burn-calculator.shtml
      I think he just ran with 200km/h speed 😄
      • K Offline
        konstantinos kex
        I do not know .I have just made the test from your link and it showed 1444 cal. There is a lot of distance to 1991 cal.
        sartoricS 1 Reply Last reply Reply Quote 1
        • sartoricS Offline
          sartoric Moderator @konstantinos kex
          @konstantinos-kex
          Consider that the website calculation is based on average HR only, while the watch (maybe, as we do not know the algorithm) uses all the live data.
          That said … it could be wrong as already happens for other metrics 🙂 but it’s just an estimate
          SVTS - 2.50.28
          SSSWHR BARO Amber - 2.8.32
          Samsung A5 2016 - Android 7.0
          Suunto App Android 6.10.7 beta
          • K Offline
            konstantinos kex
            So, what should I do?
            SlaShS 1 Reply Last reply Reply Quote 1
            • SlaShS Offline
              SlaSh Platinum Member @konstantinos kex
              @konstantinos-kex show your HR zones in the watch.
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                Dimitrios Kanellopoulos Community Manager @SlaSh
                I’ll check with @konstantinos-kex as we did change his zones. I needed to call him , as he is Greek and I am in Greece ATM, and setup his zones like mine as having the same age.
                However as said bifre he runs in a high heart rate. That is not bad or alarming but it’s iether a belt problem either his hr is way higher.
                @konstantinos-kex in short with this hugh hr and your height / kilos sounds normal. But maybe the hr belt here is the problem.
                Let’s have a call at Monday, as I just return from.weekend.
                Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                • K Offline
                  konstantinos kex
                  Thanks a lot to everyone!! Dimitris call me whenever you want!!
                  • Kurt68K Offline
                    Kurt68
                    the maximum heart rate by age has no value. As my trainer always says, if you did not test your maximum heart rate with a test, I was left alone with workout after heart rate.
                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                      Dimitrios Kanellopoulos Community Manager @Kurt68
                      @kurt68 either this or the belt.
                      • Kurt68K Offline
                        Kurt68
                        this can be tested quickly
                        https://youtu.be/QXJ0spt9A1E
                        • B Offline
                          blfrun
                          I need some help:
                          I train with my Ambit3 Sport. But I cannot find out if the calorie count in my Spinning mode has my basic metabolism included in the calorie count or not.
                          Here is an example:
                          1 hour pretty intense bike ride on a stationary bike with watt measurement. The bike says 280w avg and 1060 cal burned (deduct the BMR leaves me with approx. 930 cal burned for the ride). Suunto also tells me that I have burned 930 cal. If Suunto does NOT take into account that I would have burned 130 cal/h anyway by doing nothing then everything matches up.
                          But can I be sure, that I should NOT deduct 130 cal from the Suunto number?
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
