    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Calories consumption
    Scheduled Pinned Locked Moved Suunto app and other software services
    31 Posts 11 Posters 3.7k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • K Offline
      konstantinos kex
      I have the suunto spartan wrist hr and i belive that something is going wrong with the calories consumption showed by the watch.For example after an hour of running the watch shows that I consupted 2000 calories!!!
      sartoricS SlaShS 2 Replies Last reply Reply Quote 1
      • sartoricS Offline
        sartoric Moderator @konstantinos kex
        @konstantinos-kex
        Tell me how !! 😁
        Jokes apart, have you set your personal profile correctly ?
        Do you have the same data in Movescount ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.8.9 beta
        • suzzloS Offline
          suzzlo Moderator
          Are your body data correct?
          This body measures, are used for calculate calories…
          Suunto: Race, S9Peak, Spartan Sport Wrist
          Garmin: FR745, Edge 530
          SA topics:
          • Guides - https://forum.suunto.com/tags/guides
          • Václav KrálV Offline
            Václav Král
            For me this works fine. In my opinion Suunto has better calories consumption counting than Polar. Please do not change anything on this.
            Polar A360, Polar M600, Polar M430
            Suunto Spartan Trainer, Suunto Spartan WHR Baro
            Suunto 9 Baro
            Coros Apex Pro
            Google Pixel 2
            • oeagleoO Offline
              oeagleo
              2000 calories for an hour run seems a bit high for me, I hardly get 1300 for an hour and a half bike ride, but then, as all of the above has said, insure your physical stats are correct in both the watch, and Movescount, and especially your activity level. When comparing my Suunto with “another brand”, I discovered this website that gives estimation of calorie count based upon your heart rate. I found Suunto’s calorie expenditure closest of the one’s I’ve checked.
              http://www.shapesense.com/fitness-exercise/calculators/heart-rate-based-calorie-burn-calculator.shtml
              'Life should not be a journey to the grave with the intention of arriving safely in a pretty … rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”.
              K 1 Reply Last reply Reply Quote 0
              • SlaShS Offline
                SlaSh Platinum Member @konstantinos kex
                @konstantinos-kex please share your move to see how HR graph looks like.
                • K Offline
                  konstantinos kex
                  Yes the data are the same:1.91.m tall,96 kilos 34 years old.
                  https://www.movescount.com/moves/move229229937
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                    Dimitrios Kanellopoulos Community Manager @konstantinos kex
                    I took a look and your HR was in Zone 5 (max zone) for quite a lot. You could maybe adjust your zones. Z5 for your age (mine as well) to be entering above 157 is not correct for sure I think.
                    Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                    • K Offline
                      konstantinos kex
                      What does this mean??how can i change it?my opinion is that something is going wrong.
                        @konstantinos-kex go to the watch and go to settings -> trainning -> Intensity Zones -> Default zones and adjust there the settings.
                        If you need help on how to set them up, mention me here.
                        • K Offline
                          konstantinos kex
                          I would like some help please
                            @konstantinos-kex ok.
                            The zones there should be:
                            z1-z2 -> 72%
                            z2-z3 -> 77%
                            z3-z4 -> 82%
                            z4-z5 -> 86%
                            I think there is a reset button there that can help as well.
                            Can you tell us what values you had there before btw?
                            • K Offline
                              konstantinos kex
                              If i could contact you by phone it would be much better.
                                @konstantinos-kex check your pm
                                • K Offline
                                  konstantinos kex
                                  https://www.movescount.com/moves/move230832028. Hallo again ,I ran 4 km just to test it after i made some changes and I think that 613 calories are still a lot from a normal situation.
                                  Mff73M Dimitrios KanellopoulosD SlaShS 3 Replies Last reply Reply Quote 1
                                  • Mff73M Offline
                                    Mff73 @konstantinos kex
                                    @konstantinos-kex
                                    Hello,
                                    For this move, your altitude profil is not flat (maybe GPS altitude and profil set to alti/auto instead of baro for this kind of move) but I guess your run was 🙂
                                    Maybe calories are added due to this few elevations meter.
                                    Just a clue, i am not aware of calories calculations.
                                    SSU (retired), SV1, SV2
                                    Wife : S9PP
                                    SA: Always the latest beta :)
                                    Android + Galaxy S205G
                                      @konstantinos-kex I think the reason is the high hr. You have even an hr of 183 which is about 3bpm below you max for the age.
                                      At that effort the consumptions rises.
                                      To my eyes running at 183 where max is 186 for you age can be the root cause of this.
                                      • SlaShS Offline
                                        @konstantinos-kex as Dimitrios mentioned HR is culprit for you as you are running at max HR how you feel after such workout? As you are at lactate zone.
                                        • K Offline
                                          konstantinos kex
                                          How should I feel?I feel little tired but ok.It was just a 25 minutes excercise.Most of the times I am very tired before the run because I usually go at nights when I find some free time.
                                            @konstantinos-kex I think really the issue is with hr being sooooook high.
                                            I have e the same hr values like you but I can almost never pass 180bpm !!!
                                            That means that your max hr should not be 186 for exmaple. It should be higher in my opinion.
                                            At a similar run with yours I can barely pass 170.
                                            According to how calories are deriving from hr you are running at v02max for a lot of time dramatically increasing the calories estimation.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
