    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HR sensor accuracy
    Scheduled Pinned Locked Moved Suunto Race
    51 Posts 26 Posters 17.4k Views 25 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • DrSilverthornD Offline
      DrSilverthorn @David l
      @David-l I think the wrist OHR should work for steady state running workouts at least. I think Garmin and Polar (VV2, Grit, not VV3) work better in this regard. Wearing a strap all the time in the summer months can lead to chaffing issues, and sometimes one is traveling and it’s one less thing to think about.
      If you’re putting a OHR sensor on the watch, then the person buying it might reasonably expect it to work at least sometimes. The problem is that for many people it simply doesn’t work under anything but the most ideal conditions.
      IMO, if they could fix the heart rate sensor, they’d be addressing a major shortcoming that would make them more competitive in this space.
      Suunto Race Ti, Vertical Ti, Vertical 2 Ti, Garmin Enduro 1/2, Polar VV2
      David lD 1 Reply Last reply Reply Quote -1
      • ? Offline
        A Former User @JANTIKAINEN
        @JANTIKAINEN said in HR sensor accuracy:
        took his Race from his wrist and let me play with the watch
        At that point he could have left it to you as a gift 😊
        • David lD Offline
          David l @DrSilverthorn
          @DrSilverthorn with the exception of one blip at the beginning of one run, it’s worked perfectly fine for me. HR for similar runs using Fenix are very close to this (can’t completely compare due to weather/alcohol intake the previous night).
          • C Offline
            carlopievani
            ciao a tutti, qualche giorno fa ho provato a fare una comparativa fra garmin epix 2 pro e suunto race, il sensore hr di garmin era in linea con la fascia cardio facendo spinning… il suunto race era invece in grave difficolta’… poi sono un paio di giorni che mi alleno allacciando il suunto race sull’avambraccio e le cose sono sorprendentemente cambiate, in questa condizione riesce a tenere il passo con garmin… posso dirmi abbastanza soddisfatto
            vjakubV 1 Reply Last reply Reply Quote -1
            • vjakubV Offline
              vjakub @carlopievani
              @carlopievani Not even after translation I could help me understand what changed the accuracy for you 😕
              tiagoT 1 Reply Last reply Reply Quote 0
              • tiagoT Offline
                tiago Bronze Member @vjakub
                @vjakub he change the placement of the watch to forearm and the accuracy becomes better,in line with Garmin epix 2
                • Brad_OlwinB Offline
                  Brad_Olwin Moderator
                  This might interest those who think OHR is accurate.
                  https://the5krunner.com/2023/11/29/garmin-fenix-6-hrv-vs-polar-h10-hrv-study-shows-the-winner/
                  Vector/T6c/Vertical 2 Ti
                  • David lD Offline
                    David l @Brad_Olwin
                    @Brad_Olwin said in HR sensor accuracy:
                    Not really sure what this proves. We all know that chest straps are much more accurate that OHR. This is just some graphs an individual has put together. There’s no scientific input, no controls, and no peer review.
                    Different OHR sensors work differently for different people and are therefore usable only as a guide. Mine works great for me as a guide. I can certainly tell, without looking at my watch, if my HR is too high or isn’t high enough.
                    Arnaud LclrA 1 Reply Last reply Reply Quote 3
                    • Arnaud LclrA Offline
                      Arnaud Lclr Bronze Member @David l
                      @David-l Thanks @Brad_Olwin , and I don’t agree with you at all @David-l .
                      This study does have the capacity to easily illustrate the difference between a competition medical device, a heart rate belt recognised as the best on the market (H10) and an optical reader, the Fenix 6.
                      It’s much more scientific than a ‘youtuber’ review like DC Rainmaker, which does interesting practical tests but with a scientific veneer that makes the non-scientist think it’s very scientific and which is in any case incapable of remaining impartial !
                      I don’t think the point of talking about this article is to excuse the inaccurate measurement of Suunto’s optical readers, or those of any other brand.
                      If the article can make those on this forum understand that if you want the most reliable measurement possible to be able to interpret all the Suunto indicators, you need the most reliable measurement and that therefore: sport = heart rate belt, that’s already great…
                      And I think it’s time for brands to stop claiming too much about optical readers 😉
                      Or maybe for Suunto to come out with a heart rate monitor that’s even more accurate than the Polar H10.
                      After 8 years with Garmin and several watches in different ranges, I switched to Suunto in 2023, with the Race.
                      David lD D 2 Replies Last reply Reply Quote 2
                      • David lD Offline
                        David l @Arnaud Lclr
                        @Arnaud-Lclr said in HR sensor accuracy:
                        Absolutely agree with this point! Just use OHR as a guide 👍
                        • D Offline
                          duffman19 @Arnaud Lclr
                          @Arnaud-Lclr I’m not sure anyone would consider the5krunner more reliable than someone like @dcrainmaker. Yes, the source of the graphs appears to be from a scientific paper, but there is no direct access to it and little to no context given. If you read the comments, it appears the5krunner didn’t even realize the results were taken while exercising. I think t5k went back and edited the (very short) article to clarify this. He/they even added that "we can’t infer the performance of RR recording at lower levels from thse [sic] results.”
                          I agree with @David-l that we’re all well aware that OHR, specifically at the wrist, is less reliable than an electrical chest monitor. No news here.
                          Vertical Ti / S9PP Ti / S9P Ti
                          Jean LamyJ Brad_OlwinB 2 Replies Last reply Reply Quote 1
                          • Jean LamyJ Offline
                            Jean Lamy @duffman19
                            Hi guys,
                            Very interesting readings here. Helps a bit understand my “bad HR sensor” impression since wearing the Race (titanium).
                            Here are 2 photos taken from the same exercice (small fitness) wearing Race versus good old Suunto 5.
                            I think I’ll try moving the watch up + resetting and I’ll see.
                            HR sensor is not 100% a major issue for me but when you put a lot of money on a watch that is supposed to work (and be better than the previous one) you expect something better.
                              Brad_Olwin Moderator @duffman19
                              @duffman19 I can upload the manuscript if you wish. I have access.
                              • Kurt68K Offline
                                Kurt68
                                Garmin with chest strap suunto on the wrist no major abnormalities. 🤷‍♂️
                                1 Reply Last reply Reply Quote 5
                                • A Offline
                                  AnnaBi
                                  Have my Suunto Peak Pro 9 since January 2024. Almost ever since the beginning, once every couple of workouts (very randomly) I have been experiencing horrible HR sensor accuracy. Let’s say I go for a run - I tend to have very high HR during cardio workouts, so my HR will usually be around 160 or more. Then, all of the sudden, my Suunto will start showing something completely false like 90 or 100. It makes the watch absolutely unreliable.
                                  Below is my Strava screenshot from 25 km nordic skiing competition I participated in recently - it was very heavy workout for me, as you can see from the first couple of kilometeres… and then the HR sensor went down to 80 or 90. sn’t HR measurement one of most important things that a sport watch should do?
                                  It happens repeatedly, randomly and makes the HR measurement, which is a really crucial feature for me, completely unreliable.
                                  I have sent the watch to Suunto service - they said that they ran all the tests and everything works fine, so I should consider buying the Suunto chest strap (!!).
                                  My boyfriend has a Garmin of comparable class and the HR works fine for him. I am extremely disappointed with both the product and the service - this is certainly not the quality I had expected from the brand Suunto. I am definitely not getting another Suunto watch ever again.
                                  • ? Offline
                                    A Former User @AnnaBi
                                    @AnnaBi If HR is crucial, you need to use a chest strap. Wrist-based monitoring is garbage for sports, regardless of the brand. (It may seem to work at times, but the values are inaccurate, even if some models appear to perform better than others). The wrist-based heart rate sensor is simply not suited for sports but rather for daily tracking.
                                    2 1 Reply Last reply Reply Quote 1
                                    • 2 Offline
                                      2b2bff Gold Members @Guest
                                      @Ghost as this is true for Suunto, it isn’t for all watches on all brands.
                                      My Epix Pro has really great HR accuracy, unless the software bug hits that prevents it from being. There is almost nothing to gain with a chest strap. I could show you examples, as Garmin records both external and wrist heart rate in the FIT file.
                                      Suunto Race S
                                      Garmin Epix Pro
                                      SODIUMS ? 2 Replies Last reply Reply Quote 0
                                      • SODIUMS Offline
                                        SODIUM @2b2bff
                                        @2b2bff I think the reality is that the Optical heart rate sensor on watches in the world is not accurate enough to be comparable to a chest strap with a medical ECG cable.
                                        2 1 Reply Last reply Reply Quote 0
                                        • 2 Offline
                                          2b2bff Gold Members @SODIUM
                                          @SODIUM identical - no. Comparable and perfectly usable if you don’t need the last beat? Yes.
                                          As an example: Threshold Run - Epix Pro against HRM-DUAL.
                                          Suunto Race S
                                          Garmin Epix Pro
                                          M 1 Reply Last reply Reply Quote 1
                                          • M Offline
                                            Matúš Bronze Member @2b2bff
                                            @2b2bff said in HR sensor accuracy:
                                            Activity type?
                                            Suunto 9 Peak Pro Ti Slate
                                            Suunto Spartan Sport
                                            #swatt
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
