    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery life suddenly bad
    Scheduled Pinned Locked Moved Suunto 9 Peak
    3 Posts 3 Posters 1.0k Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      Bitstreams
      I’ve had my 9 Peak for a couple of months, but suddenly it’s not holding charge for a day and I’m having to charge it much more often.
      Am I the only one? It’s running 2.26.8
      inkognitoI 1 Reply Last reply Reply Quote 0
      • inkognitoI Offline
        inkognito Platinum Member @Bitstreams
        @Bitstreams Can you long-press the middle button and make sure that Backlight toggle is off?
        SV: fingers crossed :D
        S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
        Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
        Despite some pretty bad luck, I still love Suunto!
        B 1 Reply Last reply Reply Quote 1
        • B Offline
          Bradleyd Bronze Member @inkognito
          @Bitstreams, if you have enabled Activity 24/7 wrist HR tracking and toggle the general setting for Power Saving On and Off, you may be hitting a settings bug where the wrist HR lighting is on at the same time power saving is on. This will definitely consume some extra battery over a week.
          For me, the scenario is:
          1. 24/7 wrist HR tracking ON
          2. Power Saving ON
          3. start a training exercise using HR belt with wrist HR disabled
          4. On completion of training and return to clock mode, view backside of watch to see wrist HR lights flickering
          If I go to Settings/General after 4) and turn off Power Saving, wrist HR will then be recorded, turning Power Saving back on will stop the flickering. If I don’t change the Power Saving setting, the wrist HR lights will continue flickering, but the HR value is not recorded in the HR widget time series nor will it be shared to SA daily summary.
          Agree with @inkognito that the screen backlight is a more likely culprit for a faster discharge, but an increase to 5 to 10% battery consumption per day may just be the wrist HR unexpectedly running.
          • First post
            Last post
          Suunto Terms | Privacy Policy
