    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Skitouring
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    22 Posts 11 Posters 4.5k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • isaziI Offline
      isazi Moderator
      From an idea of @Egika last year I implemented a skitouring app. Winter and snow are soon coming to the northern hemisphere and I think I’ll finish it (need to not register a lap when pressing the lower button to measure slopes). I’ll add screenshots after the holidays 🙂
      https://github.com/isazi/skitouring
      Blog: isazi's home
      sartoricS EgikaE Mauro Del RomanoM 3 Replies Last reply Reply Quote 9
      • Stefan KerstingS Offline
        Stefan Kersting Platinum Member
        Lokking forward to the app 😀 winter is coming soon, hear a picture from last weekend. Maybe I’ll start the season on Tuesday or next weekend 🥰
        Instagram: https://www.instagram.com/helgelandsbukken/
        https://www.instagram.com/suunto_adventures/
        IG: Helgelandsbukken, suunto_adventures
        Vimeo: vimeo.com/helgelandsbukken
        Blogg: https://turblogg.midnattsola.com
        Brad_OlwinB 1 Reply Last reply Reply Quote 6
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Stefan Kersting
          @Stefan-Kersting said in Skitouring:
          We are getting snow but not nearly enough to start ski touring…lucky you!
          Vector/T6c/Vertical 2 Ti
          Stefan KerstingS 1 Reply Last reply Reply Quote 3
            Stefan Kersting Platinum Member @Brad_Olwin
            @Brad_Olwin near the city it will take some weeks before we have good conditions. But about 2 hours driving we have a glaciers and there it’s possible to ski already 😀
            • sartoricS Offline
              sartoric Moderator @isazi
              @isazi
              I would prefer a switch instead of if/else if for currentmode check
                switch (currentMode) {
                  case 0:
                   // code here
                    break;
                  case 1:
                   // code here
                    break;
                  case 2:
                   // code here
                    break;
              It should be a bit faster
              You could also move the if
              if ( Math.abs(referenceAltitude - currentAltitude) > threshold ) {
              outside the switch (if I didn’t miss anything) to avoid useless operation
              … sorry … professional deformation 🙂
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.11.8 beta
              isaziI EzioAuditoreE 2 Replies Last reply Reply Quote 1
              • EgikaE Offline
                Egika Platinum Member @isazi
                @isazi said in Skitouring:
                The idea is, to have to have the following data ready:
                altitude
                vertical speed
                ETE based on remaining climb and distance, not on current speed (as there is a significant change in speed for ascent to descent)
                And - tadaa: the slope angle, measured by pressing the lower button while holding the watch against a pole or aiming up or downhill. Required for avalanche danger assessment.
                Plus a barometric indicator.
                It looks like this:
                  Stefan Kersting Platinum Member @Egika
                  @Egika that sounds interesting. Do have to take the watch off or can you have it around your wrist during measuring?
                  EgikaE 1 Reply Last reply Reply Quote 1
                  • EgikaE Offline
                    Egika Platinum Member @Stefan Kersting
                    You just press the lower button once to enable slope angle measurement, and you press it again to lock the current value.
                    Basically it measures the watch tilting angle by reading out the accelerometer data in 3D.
                    In which way you position your watch is up to you.
                    Stefan KerstingS 1 Reply Last reply Reply Quote 0
                      @Egika have you done some testing how precise the measurements is in ± degrees?
                      It would be nice to have a field when using backcountry ski mode that shows the slope in degrees and not in percent. Both when going up and running down
                      • SuperFlo75S Offline
                        SuperFlo75 Silver Members Bronze Member
                        And how can I use this on the watch? Looks nice, interesting and useful!
                        Suunto Vertical 2 Titanium Sage
                        Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                        Suunto Wing
                        Suunto 9 Peak Pro Titanium (owns my wife now)
                        Suunto Spartan Ultra
                        SA iOS 3.12.0 (22937)
                        Instagram @superflo75
                        • EgikaE Offline
                          Yes, precision is 0.1°
                          Just as mentioned, this is a separate measurement, not derived from altimeter and speed gradient while moving.
                          • isaziI Offline
                            isazi Moderator @sartoric
                            @sartoric will clean the code after the holidays
                            Blog: isazi's home
                            H sartoricS 2 Replies Last reply Reply Quote 0
                            • H Offline
                              halajos Bronze Member @isazi
                              Wow, I want S+ API access! 😊
                              • sartoricS Offline
                                @isazi
                                I can push a PR … 😁 😁
                                SVTS - 2.50.28
                                • EzioAuditoreE Offline
                                  EzioAuditore Gold Members @sartoric
                                  @sartoric if (or if else) is usually faster than switch. Some C banchmark here: https://www.ideone.com/GXKX3j
                                  Since this is JS though it must be “compiled” to something that the watch can run? So maybe under the hood it is translated to if else 🙂
                                  Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                                  Suunto Wing
                                  tazidenT 1 Reply Last reply Reply Quote 0
                                  • tazidenT Offline
                                    taziden Gold Members @EzioAuditore
                                    @EzioAuditore under the hood, it’s Duktape if I’m not mistaken https://duktape.org/
                                    S9PP
                                    isaziI 1 Reply Last reply Reply Quote 1
                                    • isaziI Offline
                                      isazi Moderator @taziden
                                      @taziden I think you’re right
                                      Blog: isazi's home
                                      • Mauro Del RomanoM Offline
                                        Mauro Del Romano @isazi
                                        @isazi Hi, when ski touring sport app will be available for s9baro? thanks!
                                        I’m sorry but is it possible on this watch to track automatically or manually hill descent switching at the end of climbing?
                                        DMytroD 1 Reply Last reply Reply Quote 0
                                        • DMytroD Offline
                                          DMytro @Mauro Del Romano
                                          @Mauro-Del-Romano with hill climber app?
                                          Mauro Del RomanoM 1 Reply Last reply Reply Quote 0
                                            Mauro Del Romano @DMytro
                                            @DMytro exactly! I looked into it and that’s the answer, thanks. Do you maybe know if is it possible to add gps coordinates as parameters on sports screens?
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
