    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Wrong heart rate ohr
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    29 Posts 16 Posters 5.2k Views 17 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • mikekoski490M Offline
      mikekoski490 Bronze Member @SuperD
      @SuperD I’ve worn a Garmin F6X solar and a Coros Vertix 2 prior to Suunto 9PP then Vertical. From that experience 9PP was the best OHR probably because it was the lightest. Garmin was about the same as Vertical, and Coros was terrible.
      Garmin forums complained a lot about OHR when I had it, and posters just said get a heart rate belt lol.
      Please post a screenshot of a race you did when you were using your Garmin 945 - I think that would be more meaningful than just saying ‘My Garmin was better.’ Would be VERY interested to see an actual OHR comparison shot given the same conditions - as you said “going uphill I used my hands on my legs”) as this would normally be not something OHR is good at. That way people on here wanting to rely on OHR to race could then choose a Garmin 945 (lighter than Vertical because its plastic case?) and not make the mistake you did. Thanks!
      Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
      Current: Suunto Race Ti
      Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
      Suunto App running on Google Pixel 8/Android 14
      vincent mayousseV 1 Reply Last reply Reply Quote 3
      • vincent mayousseV Offline
        vincent mayousse @mikekoski490
        Hello
        I uptade this topic, as sometimes, I have the impression that my S9PP gives really weird HR measurements…
        Last exemple a couple of weeks ago, during a “cool run”, it indicated as max HR: 210 bpm !!! I was running quite slowly for me (10-11 kph). Is-it possible that the 9PP HR sensor OVER-estimates the HR to this extent ?
        Or maybe I was really tired this day, and my HR elevated as high as 210bpm this day…😂
        Thanks for your opinion of this subject.
        Regards
        Łukasz SzmigielŁ Brad_OlwinB 2 Replies Last reply Reply Quote 0
        • Łukasz SzmigielŁ Offline
          Łukasz Szmigiel @vincent mayousse
          @vincent-mayousse your watch may be too loose, or you may have a specific skin pigmentation or tattoos that interfere with the readings. Have you tried a different hand or putting the watch higher up?
          S9PP 2.50.28
          vincent mayousseV 1 Reply Last reply Reply Quote 0
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @vincent mayousse
            @vincent-mayousse OHR on any wrist device is not accurate when exercising IMHO. I use a belt.
            Vector/T6c/Vertical 2 Ti
              vincent mayousse @Łukasz Szmigiel
              @Łukasz-Szmigiel hello, no particular skin color or tattoo where I wear the watch. And I know OHR is not the best as is moves when running.
              In general I tighten it before an exercise.
              My second question/remark was also : can the optic sensor OVERestimate the HR? Cause if it does not, it means I was actually at 210bpm at this precise moment (therefore it becomes my max HR and it changes all my training zones ! 😂)
              Thanks
              Łukasz SzmigielŁ Stefano M64S 2 Replies Last reply Reply Quote 0
                @vincent-mayousse cadence lock is pretty common, but also 210 is a very high cadence.
                If you want to be serious about heart rate, use the belt. OHR is fine for walks or some easy runs, but if you’re pushing, it’ll likely fail.
                Also, if you’re using belt - Suunto will calculate your aerobic and anaerobic threshold, which is a bonus.
                S9PP 2.50.28
                • Stefano M64S Offline
                  Stefano M64 Silver Members @vincent mayousse
                  @vincent-mayousse said in Wrong heart rate ohr:
                  @ I know OHR is not the best as is moves when running.
                  I guess that during any kind of activity where the arms swing rhythmically, because of the centrifugal acceleration the blood is pushed toward the hands, and that superimposes to the real heart beats, messing up the OHR detection. Likely a more refined analysis using also the accelerometer data should be able decouple the two signals by mean of Fourier Transformation (frequency analysis), but that depends also on the quality of the data (errors and sampling rates)
                  Suunto Vector . Vector HR . Core . Race & Race S
                  vincent mayousseV 1 Reply Last reply Reply Quote 2
                    vincent mayousse @Stefano M64
                    @Stefano-M64 said in Wrong heart rate ohr:
                    Very interesting insight, thanks 👍
                    So maybe with an OHR on the arm/biceps (like the Polar one), it reduces this effect, as le swing is less pronounced at this level of the arm…
                    Stefano M64S 1 Reply Last reply Reply Quote 0
                      right, with a larger strap to wear the watch on the biceps the effect should be eliminated, but the watch itself would be hard to read,
                      an HR belt is definitely the best choice.
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
