    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Reset while charging
    Scheduled Pinned Locked Moved Suunto Vertical
    36 Posts 14 Posters 7.7k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Kornel van DoornK Offline
      Kornel van Doorn
      Hi my Suunto vertical resets everytime I’m charging it. It goes completely dark and turns on after 5 minutes and lost on some pages historical data.
      ? LechamoixL ? 3 Replies Last reply Reply Quote 1
      • ? Offline
        A Former User @Kornel van Doorn
        @Kornel-van-Doorn going dark when charging is normal… not sure what you mean by “lost on some pages historical data”, please clarify.
        surfboomerangS 1 Reply Last reply Reply Quote 0
        • surfboomerangS Online
          surfboomerang @Guest
          @twekkel some data and graphs are reset when the watch reboots. Like solar graph, barometer etc…
          It looks like the watch is crashing / rebooting during charge
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          • LechamoixL Offline
            Lechamoix Bronze Member @Kornel van Doorn
            @Kornel-van-Doorn I’ve only had this problem once since the watch came out. Full charge, black screen and reboot. As @surfboomerang says, it’s normal for the fields to be empty after a reboot.
            GiPFELKiNDG W 2 Replies Last reply Reply Quote 1
            • GiPFELKiNDG Offline
              GiPFELKiND Silver Members @Lechamoix
              @Lechamoix yes understand, BUT WHY do the watch a reset by charging?!
              If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
              E 1 Reply Last reply Reply Quote 4
              • ? Offline
                @Kornel-van-Doorn I’m having the exact same issue. When charging the Vertical crashes, creates an error log message and restarts.
                Doing so, I lose all data and custom workouts. It requires me to reenter each one as I had before. Quite annoying!
                • E Offline
                  e6321 Bronze Member @GiPFELKiND
                  @GiPFELKiND I think there must be some kind of bug related to charging. Mine appeared to be bricked after I left it on the charger but came back after some button mashing.
                  Suspect a lot of the reports on the forum about dead verticals is the same issue.
                  An update any day now would be good Suunto…. Clearly not enough resources at the company to support the vertical and the upcoming release next month.
                  • jjpazJ Offline
                    jjpaz Bronze Member
                    Yesterday my Vertical crashed when connected to charger.
                    After a pair of minutes it showed this message in the screen: “The device is being restored to a safe state”:
                    After some minutes in a loop, watch started and showed these messages:
                    Error 1403.
                    I tried to connect again to the charger and same behavior after some minutes charging: “The device is being restored to a safe state”. I tried several times until charge was over 50% disconnected from charger and performed a factory reset.
                    After that I reconfigured the watch, charged full battery and downloaded maps without problems, only one watch reboot (watch rebooted itself while charging) as it’s said in this topic.
                    Today I’m going to try it outside in a running training. Hope it performs well…
                    SuperFlo75S 1 Reply Last reply Reply Quote 0
                    • jjpazJ Offline
                      jjpaz Bronze Member
                      This post is deleted!
                      • ? Offline
                        A Former User @jjpaz
                        @jjpaz I’ve seen the exact same thing when charging. Reboot and restore. Not sure why this is occurring as I’m using the factory cable and correct wattage charger. Never saw this before with my Peak
                          surfboomerang
                          Solar or non-solar version?
                          Could it be that the watch crashes on a pending map download? That is the only thing that starts after a while when connected to a wall charger (and WiFi) as far as I know.
                          OnePlus Nord 4
                          jjpazJ ? 2 Replies Last reply Reply Quote 1
                          • jjpazJ Offline
                            jjpaz Bronze Member @surfboomerang
                            @surfboomerang Non solar (All black model).
                            No, I wasn’t dowloading map, only my every 2 weeks ordinary battery charge because watch had 10% battery left. And watch is 4,5 months old, it’s been full charged several times since may and this is the first “charging issue”.
                            The curious thing was that I wasn’t be able to perform reset to factory settings until battery is at least at 40% of full charge so watch suffered at least 3 “reset to safe state” loops until reach 40% battery level.
                            • SuperFlo75S Offline
                              SuperFlo75 Silver Members Bronze Member @jjpaz
                              @jjpaz Did you send the log files to Suunto?
                              Suunto Vertical 2 Titanium Sage
                              Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                              Suunto Wing
                              Suunto 9 Peak Pro Titanium (owns my wife now)
                              Suunto Spartan Ultra
                              SA iOS 3.12.0 (22937)
                              Instagram @superflo75
                              jjpazJ 1 Reply Last reply Reply Quote 0
                              • jjpazJ Offline
                                jjpaz Bronze Member @SuperFlo75
                                @SuperFlo75 Nope… 🤷🏻‍♂️
                                pavel.samokhaP 1 Reply Last reply Reply Quote 0
                                  surfboomerang @jjpaz
                                  @jjpaz I guess it is “solved” for now.
                                  I am curious what happens if you disabled bluetooth on your phone before charging. Or unpair the watch at all from SA.
                                  OnePlus Nord 4
                                  • jjpazJ Offline
                                    jjpaz Bronze Member
                                    Logs sent to Suunto, 18:54 Madrid time.
                                    • ? Offline
                                      A Former User @surfboomerang
                                      @surfboomerang Mine is a solar; was connect to wifi to update maps and charging. Crash occurred while watch switched from the round charging display to the watch display with charging icon.
                                      Crashed at 97% charge and performed factory reset causing the data to be lost and having to manually change the settings on the watch (sex, height, weight, sounds, sleep tracking, sport mode, etc).
                                      What is strange is I do not see the option to send logs to Suunto on the app.
                                      jjpazJ pavel.samokhaP 2 Replies Last reply Reply Quote 0
                                      • jjpazJ Offline
                                        jjpaz Bronze Member @Guest
                                        @Todd-Danielczyk Same for me. Screen changed to watchface with time and charging icon instead of the round charging bar screen. I’ve never seen that screen before, always the new charging screen…
                                        • pavel.samokhaP Offline
                                          pavel.samokha @jjpaz
                                          @jjpaz please send logs and DM me email you use in Suunto App (and please don’t create duplicate posts/topics)
                                          Opinions expressed are solely my own and do not express the views or opinions of my employer
                                          jjpazJ 1 Reply Last reply Reply Quote 2
                                            pavel.samokha @Guest
                                            @Todd-Danielczyk Depending on the app version/platform feature to send logs is either in the end of the Settings or in the Watch menu
                                            ? 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
