    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Missing power and cadence
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    14 Posts 7 Posters 1.9k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Francesco PaganoF Offline
      Francesco Pagano Silver Members Bronze Member
      I just upgraded to S9PP, mostly I wanted to test running training with power from wrist.
      I customised a Run sport mode to include a Power 3s field, and it displayed no value throughout the entire run. No data about power in SA or intervals.icu either 🤷 Also cadence is missing from the watch face during activity and from the apps, while I get it when I do Walk instead.
      Am I doing something wrong with the sport mode?
      S9PP
      S5
      Brad_OlwinB zhang965Z 2 Replies Last reply Reply Quote 0
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Francesco Pagano
        @Francesco-Pagano That is bizarre! I use custom sport modes with power and they work. Your sport mode could be corrupted. Try 1. Short test with Standard power spor mode to make sure power is working.
        2. If yes recreate the sport mode and do a short test.
        Finally, have you set your power zones in
        Settings/Training/Intensity Zones/Advanced Zones? If nothing is set the power might be in no zone and possibly not show properly but I wouldn’t know why
        Vector/T6c/Vertical 2 Ti
        Francesco PaganoF 2 Replies Last reply Reply Quote 1
        • zhang965Z Offline
          zhang965 @Francesco Pagano
          @Francesco-Pagano said in Missing power and cadence:
          Hello,
          Just in case, are you sure it’s a suunto 9 peak pro?
          Because we saw once, even Suunto’s tester cannot figure out which model has wrist power.
          Winners Wear Winners
          sartoricS freeheelerF 2 Replies Last reply Reply Quote -7
          • sartoricS Offline
            sartoric Moderator @zhang965
            @zhang965
            šŸ‘ šŸ‘
            SVTS - 2.50.28
            SSSWHR BARO Amber - 2.8.32
            Samsung A5 2016 - Android 7.0
            Suunto App Android 6.8.9 beta
            1 Reply Last reply Reply Quote -2
              Francesco Pagano Silver Members Bronze Member @Brad_Olwin
              @Brad_Olwin thanks, I’ll try setting up power zones and test the same sport mode again. I understand from your message and all documentation around that I should see some standard (non-custom) running and cycling with power sport modes, but I can’t see these on the watch nor on SA
              S9PP
              S5
              • freeheelerF Offline
                freeheeler @zhang965
                @zhang965
                living sideways
                1 Reply Last reply Reply Quote 8
                  @Brad_Olwin creating a new custom sport mode worked, I got both power and cadence. What I didn’t get was the ā€œpowerā€ display instead, which was not there on the previous sport mode, either.
                  There seeems to be an issue with sport modes because this is maybe the third one that doesn’t reflect what I set up on SA (I’m on beta 4.73.6 - Android)
                  S9PP
                  S5
                    I did some research on the forum and the issue seems similar to what reported here:
                    https://forum.suunto.com/topic/3556/running-power-missing-on-s9-baro-with-2-9-42/20
                    https://forum.suunto.com/topic/6581/no-hr-displayed-in-custom-run-with-power-mode
                    In my case, some fields (power and cadence) and some displays (power, power without distance) are empty/missing during the activity.
                    However my starting point is customising Running; I don’t understand how you customise Run with power because I don’t see this as a sport mode.
                    Suunto 9 Peak Pro - Software 2.27.8
                    Suunto App - Android 4.73.6 (beta)
                    S9PP
                    S5
                    sartoricS 1 Reply Last reply Reply Quote 0
                    • sartoricS Offline
                      sartoric Moderator @Francesco Pagano
                      Do you mean that you don’t see Running in the list when you click ā€œcreate sport modeā€ ?
                      SVTS - 2.50.28
                      Francesco PaganoF 1 Reply Last reply Reply Quote 0
                        Francesco Pagano Silver Members Bronze Member @sartoric
                        @sartoric I do see Running. Am I supposed to see also something like Running power? That’s what I understand from @Brad_Olwin 's message ā€œStandard power spor modeā€ and from Suunto’s article:
                        https://www.suunto.com/sports/News-Articles-container-page/run-with-power/
                        ā€œTo see your power during your run, select a sport mode that shows running power on your screen. You can use for example sport modes like Trail running power or Running power.ā€
                        S9PP
                        S5
                        isaziI Mff73M 2 Replies Last reply Reply Quote 0
                        • isaziI Offline
                          isazi Moderator @Francesco Pagano
                          @Francesco-Pagano no, running with power is a specialization (i.e. a custom mode from Suunto) so you cannot customize it further. The basic mode is running. I use a custom running mode (although on Vertical, not S9P) and see my current power on the guide I am using.
                          Blog: isazi's home
                          • Mff73M Offline
                            Mff73 @Francesco Pagano
                            @Francesco-Pagano
                            Here are photos from vertical, but I checked also the same from S9PP of my wife.
                            Running standard sport mode
                            And then you can choose option for power
                            Don’t you have these?
                            SSU (retired), SV1, SV2
                            Wife : S9PP
                            SA: Always the latest beta :)
                            Android + Galaxy S205G
                            Francesco PaganoF 1 Reply Last reply Reply Quote 1
                              Francesco Pagano Silver Members Bronze Member @Mff73
                              @Mff73 thanks! I would probably never find these šŸ˜„
                              There’s still some issue to discover with custom sport modes, for which I’ll provide more details. For now I have what I needed.
                              S9PP
                              S5
                              Mff73M 1 Reply Last reply Reply Quote 2
                              • Mff73M Offline
                                @Francesco-Pagano
                                sometime pictures gives more explanations that words šŸ˜‰
                                Wife : S9PP
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
