    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak Pro: problem connecting to Phone Google Pixel 6
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    32 Posts 19 Posters 9.0k Views 17 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      Belodevici
      Good evening everyone. I bought the Suunto 9 Peak Pro today but I absolutely can’t pair it with my Google Pixel 6 phone. I’m going crazy. The recognition starts, the phone “sees” the Suunto, the pairing notification appears then everything stops. I’ve tried a million times. I contacted Suunto Support without success. Can anyone help me? Thank you very much.
      Alessandro De Bei
      Attach Screen
      sartoricS J Danny polegD 3 Replies Last reply Reply Quote 1
      • sartoricS Offline
        sartoric Moderator @Belodevici
        @Belodevici
        If you paired it with phone BT, unpair it and do everything from SA
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.8 beta
        Łukasz SzmigielŁ B 2 Replies Last reply Reply Quote 1
        • Łukasz SzmigielŁ Offline
          Łukasz Szmigiel @sartoric
          @sartoric this is the way.
          S9PP 2.50.28
          • B Offline
            Belodevici @sartoric
            @sartoric
            First of all, thank you for your reply I did the pairing via the Suunto App, not via BT. It doesn’t work! My question is: has anyone had problems pairing with the Google Pixel?
            Because I have redone the procedure 1,000 times without success. I refreshed the phone’s Bluetooth data, uninstalled and reinstalled the App… Nothing
            ? Łukasz SzmigielŁ Mff73M S Piotr GrygielP 5 Replies Last reply Reply Quote 0
            • ? Offline
              A Former User @Belodevici
              @Belodevici Works fine with Pixel 6a (after not being able to connect with a Nokia … similar to what you have with your Pixel).
                Łukasz Szmigiel @Belodevici
                @Belodevici remove the connection in the watch (if there’s any). Then, remove connection in the android. After that, try connecting in Suunto App.
                S9PP 2.50.28
                • Mff73M Online
                  Mff73 @Belodevici
                  @Belodevici
                  Reboot the phone after beeing sure to have unpaired from everywhere (watch, app, Bluetooth settings).
                  SSU (retired), SV1, SV2
                  Wife : S9PP
                  SA: Always the latest beta :)
                  Android + Galaxy S205G
                  • S Offline
                    Sascha Domres Bronze Member @Belodevici
                    @Belodevici hi, i also have a pixel 6 and fortunately no problems with the connection… latest version security update etc… maybe check if you have other devices connected (headphones etc.) I would turn them off. If your Vertical is already visible under Bluetooth devices… please delete it… Then restart your phone and try to pair the watch via the Suunto app… good luck…
                    • J Offline
                      jannis Bronze Member @Belodevici
                      @Belodevici I had the same problems and I tried like an hour (Redmi/Xiaomi phone). The only thing that helped was to connect the watch first via Bluetooth. I got finally the pin and then I opened the the app again and finally it was possible to connect the watch with the app.
                      Piotr GrygielP 1 Reply Last reply Reply Quote 0
                      • Piotr GrygielP Offline
                        Piotr Grygiel @Belodevici
                        @Belodevici I have the same problem with Google 7.
                        I paired with my wife’s (not Google’s) phone.
                        Suunto Race 2
                        Google Pixel 8 pro
                          Piotr Grygiel @jannis
                          @jannis said in Suunto 9 Peak Pro: problem connecting to Phone Google Pixel 6:
                          It does not work.
                          Suunto Race 2
                          Google Pixel 8 pro
                          freeheelerF 1 Reply Last reply Reply Quote 0
                          • freeheelerF Offline
                            freeheeler @Piotr Grygiel
                            @Piotr-Grygiel
                            might be a pixel issue, because we have this very similar thread.
                            https://forum.suunto.com/topic/9230/issue-pairing-baro-9-with-pixel-7/10
                            in my case it helped to clear cache and storage of SA and start pairing again. the correct way to connect is to let SA build the connection.
                            living sideways
                            • Jean-Pascal HoudeJ Offline
                              Jean-Pascal Houde
                              Same issue here connecting to a Pixel 7a.
                              I was able to pair it without any issue to my old OnePlus phone (just as a test, after hours of unsuccessful tries on my Pixel), but my the Pixel never gets to the scren that is supposed to ask the passcode. The watch doesn’t show any passcode either.
                              (I tried everything, unpair on phone, unpair on watch, restart watch/phone, reset watch, reset network settings on phone… the only thing I didn’t try yet is a full factory reset of the phone, and I hope I shouldn’t have to do that)
                              B 1 Reply Last reply Reply Quote 0
                              • isaziI Offline
                                isazi Moderator
                                There seems to be a pattern here, and it has been reported to Suunto internally already. I will forward this discussion to Suunto too, so they are aware there is something wrong with the App and Pixel phones.
                                Blog: isazi's home
                                B 1 Reply Last reply Reply Quote 2
                                • mattdM mattd referenced this topic on
                                • B Offline
                                  Belodevici @isazi
                                  @isazi Thank you. It would be a very welcome and useful thing.
                                  • B Offline
                                    Belodevici @Jean-Pascal Houde
                                    @Jean-Pascal-Houde I finally fixed it but I had to do a full factory reset of the Pixel 6. Something “disturbed” the pairing process, but it is difficult to say now what it was. I think it is appropriate to report it to Suunto…
                                    • H Offline
                                      holmercarl
                                      I’m having the same issue with a new 9 Peak Pro and Pixel 7 Pro, and i’ve tried all troubleshooting steps suggested in the thread. Please let us know if you manage to push a hotfix to the app for this issue. From what i can tell the problem seems to be that the app can’t/won’t trigger Android to show the window where you can enter the passcode from the watch. When trying to pair the watch as any other bluetooth device the window is shown normally and the watch provides a passcode.
                                      H 1 Reply Last reply Reply Quote 1
                                      • H Offline
                                        holmercarl @holmercarl
                                        @holmercarl
                                        I dug up my Samsung Galaxy S20 FE and tried pairing with the app and that worked flawlessly. Please let us know in this thread if you find a fix 🙂
                                        • Umer JavedU Offline
                                          Umer Javed
                                          I’m assuming this is likely not a simple issue as it’s happening to a number of users but just wanted to throw this out there: have you confirmed that your app is not denied any connectivity or location permissions?
                                          I’m using Pixel 6 Pro and the beta app. And no issues connecting 9PP and the A3P before it. I haven’t had to take any particular workarounds.
                                          • Danny polegD Offline
                                            Danny poleg Silver Members @Belodevici
                                            @Belodevici Today we sloved in the following way
                                            Split the phone screen into two screens at the top the Suunto app will appear in the pairing phase
                                            In the bottom screen bluetooth settings
                                            Pairing with the bluetooth and immediately clicking pairing in the Sunto app
                                            H Jean-Pascal HoudeJ mattdM Piotr GrygielP B 6 Replies Last reply Reply Quote 6
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
