    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Using Stryd when in endurance mode
    Scheduled Pinned Locked Moved Suunto 9 Peak
    3 Posts 2 Posters 552 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      loopylou72
      I have experimented with using Stryd when my Peak is in endurance mode assuming that if I have auto-calibration to Stryd OFF then my watch is using the Stryd for distance not GPS when it is only functioning as ‘good’ not excellent ie bypassing the less accurate GPS. However I still got data as if my watch was picking up GPS every minute. I thought Stryd would bypass this? I always use Stryd connected as a power pod to my watch with auto-calibrate off.
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @loopylou72
        @loopylou72 for distance you need Stryd connected as running pod, not power pod. Can you plot a distance graph and see how often distance is updating?
        The issue with battery modes is that endurance affects not only GPS, but other parameters as well, so it may be that everything is updated less often. You could try with a custom mode in which you just change GPS mode to see if there are differences.
        Blog: isazi's home
        L 1 Reply Last reply Reply Quote 0
        • L Offline
          loopylou72 @isazi
          @isazi thanks for this. I do have it connected as a footpod 🙂
          I wish Sunnto worked better with Stryd - any plans to improve?
          distance looks to be around every 180m but strangely not from the start? Pace and fastest pace was inaccurate on this chart.
          • First post
            Last post
          Suunto Terms | Privacy Policy
