    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Reverse direction during route navigation
    Scheduled Pinned Locked Moved Suunto Vertical
    21 Posts 14 Posters 3.2k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      It probably has been already discussed here, but I couldn’t find a post regarding this.
      I have had this already a few times and cannot figure out how go around it. When I create a route which is a straight line, not a loop, the watch or app (I don’t know) cannot figure out the correct direction. The elevation graph is not correct and it shows as if I would start from the opposite direction. Any advice how to avoid this? Thanks.
      P.s. I’ve put the start and end point deliberately further away just to test this… still didn’t work.
      P.s. 2 I once tested this behaviour against a Garmin and Coros and Garmin had no issues with figuring out the correct direction. Coros did struggle as well.
      This the start of the route:
      This is the route:
      L L arpoodleA Brad_OlwinB 4 Replies Last reply Reply Quote 0
      • L Offline
        lauser Bronze Member @Guest
        @tomasbartko Interestingly I had exact the opposite behaviour regarding Suunto Vertical and Garmin. The Lavaredo Ultra Trail has the same start- and finish-segment and the Garmin watch took several hours to catch the track and giving correct PacePro/ClimbPro advises. Suunto Vertical got the correct track from the beginning…
        But sadly this does not help you 😞
        • L Offline
          Likarnik Gold Members @Guest
          @tomasbartko I have same problem on out and back routes. It is especially annoying when having tbt enabled
          • arpoodleA Offline
            arpoodle @Guest
            @tomasbartko
            this may explain some odd behaviour I had on a route with a sort-of figure 8 with a small loop at one end. I ended up doing half my intended distance as it turned me at the crossing point rather than waiting till I’d completed that small loop and come back on myself.
            MdzOttM 1 Reply Last reply Reply Quote 0
            • babychaiB Offline
              babychai Silver Members
              i have this issue and it already happen many times for my SV. always show i’m start from opposite direction when the screen display elevation profile.
              also happen to my S9P but not so frequent.
              Suunto Vertical Titanium Solar Black
              Suunto 9 Peak All Black
              Suunto Spartan Trainer Wrist HR (Black)
              • MdzOttM Offline
                MdzOtt @arpoodle
                @arpoodle I think that this particular issue is discussed in the manual - the watch does not know (or does not understand) that you want to go through the extra loop; it directs you straight “home”.
                R2
                S9 Baro
                SA on Android
                Ambit 3 Peak
                Ambit 2 Sapphire
                • Łukasz SzmigielŁ Online
                  Łukasz Szmigiel
                  I don’t know how it’s implemented in Vertical but in Suunto watches, since S series, all routes are bidirectional.
                  If you start moving and the direction is wrong, the watch will notify you that you’re off the course and immidiately renotify that you’re back on course - but this time it’ll be adjusted to the direction you’re moving.
                  This means that if you’re not starting directly when the start point on your route is but you’re joining the route after some time - it can initially show you wrong way.
                  S9PP 2.50.28
                  Dimitrios KanellopoulosD Mff73M 2 Replies Last reply Reply Quote 1
                    Dimitrios Kanellopoulos Community Manager @Łukasz Szmigiel
                    @Łukasz-Szmigiel correct. It takes a couple of mins to detect that though.
                    Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                    • Mff73M Offline
                      Mff73 @Łukasz Szmigiel
                      @Łukasz-Szmigiel and @Dimitrios-Kanellopoulos
                      yes, it detects the direction, but, like the requester, i am wondering if the altitude graph is also reversing itself or graph stays the same and our position is placed on it from the end (theorical end, and not end of the direction we are travelling). What is the expected behaviour, please ?
                      SSU (retired), SV1, SV2
                      Wife : S9PP
                      SA: Always the latest beta :)
                      Android + Galaxy S205G
                      sartoricS 1 Reply Last reply Reply Quote 0
                      • sartoricS Offline
                        sartoric Moderator @Mff73
                        @Mff73
                        afair the graph is reversed too
                        SVTS - 2.50.28
                        SSSWHR BARO Amber - 2.8.32
                        Samsung A5 2016 - Android 7.0
                        Suunto App Android 6.11.8 beta
                        • ? Offline
                          A Former User
                          Thanks all for the replies. Just to clarify, the navigation itself is ok. It shows the correct direction (most of the time), however the altitude graph is the problem. It displays the opposite direction even if the navigation shows a correct direction - if it makes sense.
                          P.s. On this particular route the graph never reversed itself, it stayed like in the photo.
                          Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                            Łukasz Szmigiel @Guest
                            @tomasbartko I think that it doesn’t reverse. It’s always A to B. So when going backwards on the route, it should mark your location on the right side.
                            Also, will it get updated someday and be zoomable and with the possibility to turn off entirely? I’d love that.
                            S9PP 2.50.28
                            • babychaiB Offline
                              For my case the graph doesn’t reverse. so i wonder the the remaining Ascent/Descent value shown at the bottom of the graph is still from point A to point B or point B to point A? 🤔
                              • isaziI Offline
                                isazi Moderator
                                The navigation, with the track and the directional arrows on the track, will be reversed when you go from B to A, the altitude graph will show itself as the original, so with A on the left and B on the right, but the data shown is from B to A, and your “dot” will move from right to left.
                                Blog: isazi's home
                                1 Reply Last reply Reply Quote 4
                                • inkognitoI Offline
                                  inkognito Platinum Member
                                  Just noticed one additional thing that my S9 had and SV doesn’t.
                                  When you follow your route in the opposite direction, you still have the ↗️ arrow for remaining ascent value and ↘️ for remaining descent.
                                  Here I just started my activity and I am running in opposite direction, so I am following the curve from right to left.
                                  In this case, S9 showed flipped arrows, which made sense… So the symbols were:
                                  ↗️ remaining ascent (original direction)
                                  ↘️ remaining descent (original direction)
                                  ↖️ remaining ascent (opposite direction, you are moving from right to left on the chart)
                                  ↙️ remaining descent (opposite direction)
                                  SV shows just ↗️ or ↘️ regardless of the direction…
                                  SV: fingers crossed :D
                                  S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
                                  Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
                                  Despite some pretty bad luck, I still love Suunto!
                                  • sartoricS Offline
                                    sartoric Moderator @inkognito
                                    @inkognito
                                    afair SV should flip the ascent graph
                                    SVTS - 2.50.28
                                    inkognitoI 1 Reply Last reply Reply Quote 0
                                      inkognito Platinum Member @sartoric
                                      @sartoric Mine definitely doesn’t. And I tried this with several routes…
                                      AudaxjoeA 1 Reply Last reply Reply Quote 0
                                      • AudaxjoeA Offline
                                        Audaxjoe @inkognito
                                        @inkognito I’m 99% sure mine doesn’t either. The route reverse but not the profile. It been like this since the 9baro.
                                        Suunto Vertical
                                        Suunto 9 BARO
                                        Garmin Fenix 3, 5
                                        Suunto Vector
                                        • Brad_OlwinB Offline
                                          Brad_Olwin Moderator @Guest
                                          I have tested this several times on the most recent test firmware and it is working as expected for me. I am fairly certain it is working on production firmware as well. Sometimes the route will start out as visualized here but will correct. I cannot test production firmware as I am away from home the rest of this week.
                                          Vector/T6c/Vertical 2 Ti
                                            inkognito Platinum Member @Brad_Olwin
                                            @Brad_Olwin I tried with production firmware again and during the whole excercise (more than one hour long) I followed the altitude profile from right to left with misleading ↗️ arrow (instead of ↖️ which S9 would show). Graph did not flip.
                                            But it is very good to hear that there is therefore probably some work being done here in firmware development… Let’s just hope it does not end with correct direction only… “Adventure watch for outdoor expeditions and training…” indeed needs much more (like zoomable altitude profile, info on following waypoints etc.) 🤗
                                            Brad_OlwinB 1 Reply Last reply Reply Quote 2
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
