    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Sensor damage
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    9 Posts 8 Posters 1.3k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • K Online
      krakra Bronze Member
      Hi!
      Not sure how this happened but i got suunto 9 peak pro sensor damage as show in picture.
      How to check if everything is still ok?
      What are these sensor even for? 🙂
      Images: https://imgur.com/a/iDrOBmP
      Thanks
      • ? Offline
        A Former User @krakra
        @krakra if I’m correct, those are not sensors, but connectors for support to read out the device. So you are lucky, until a repair is needed.
        DMytroD 1 Reply Last reply Reply Quote 2
        • DMytroD Offline
          DMytro @Guest
          @twekkel but those are just contact pins, so a few scratches shouldn’t affect it’s working capability.
          • ADidierA Offline
            ADidier
            These are the depth meter sensors. To check that they are not damaged, the watch must be plunged into the water to a certain depth. Normally there is a specific screen when this function is activated it seems to me.
            tazidenT mikekoski490M 2 Replies Last reply Reply Quote 0
            • tazidenT Offline
              taziden Gold Members @ADidier
              @ADidier said in Sensor damage:
              Source?
              S9PP
              ADidierA 1 Reply Last reply Reply Quote 1
              • ADidierA Offline
                ADidier @taziden
                @taziden https://www.journaldutrail.com/test-de-la-suunto-9-peak-pro-complet.html
                surfboomerangS 1 Reply Last reply Reply Quote -1
                • surfboomerangS Online
                  surfboomerang @ADidier
                  @ADidier I think you could better stick to this source:
                  @isazi said in S9PP internals:
                  What @aroo7 said is the truth. Those are connecting ports that are used by Suunto customer service to fix your watch if it’s bricked and you send it to repair. You know, there is no other way than Bluetooth to communicate with the watch, so if you brick you watch service needs a way to fix it, e.g. reupload the firmware, without Bluetooth working.
                  Suunto Vertical Titanium Solar
                  OnePlus Nord 4
                  1 Reply Last reply Reply Quote 4
                  • mikekoski490M Offline
                    mikekoski490 Bronze Member @ADidier
                    @ADidier Air pressure and depth pressure are the same sensor. Makes sense right? The decades old Suunto Core also does air and depth ‘pressure’ same way, and of course no metal pins on back.
                    Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
                    Current: Suunto Race Ti
                    Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
                    Suunto App running on Google Pixel 8/Android 14
                    • isaziI Offline
                      isazi Moderator
                      Those are not depth sensors, depth and altitude come from the same sensor. Those are service pins, let’s try to not spread fake news here.
                      @krakra if you have a damage of any kind, ask support if they can help. A damaged watch is usually your fault, so you may have to pay for service, but they can probably fix your watch.
                      Blog: isazi's home
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
