    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Hotfix 2.23.24
    46 Posts 21 Posters 8.8k Views 19 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • isaziI Offline
      isazi Moderator
      If you had your watch crashing during activities without a clear pattern, go to Suuntolink and download the update that has been released today.
      Blog: isazi's home
      TieutieuT Andi BuzerA BeepiB 3 Replies Last reply Reply Quote 7
      • H Offline
        halajos Bronze Member
        Is this issue related? Or was that fixed already? I had it only once, long ago.
        isaziI 1 Reply Last reply Reply Quote 0
        • isaziI Offline
          isazi Moderator @halajos
          @halajos the fix should not be related to that.
          Blog: isazi's home
          • TieutieuT Offline
            Tieutieu Platinum Member @isazi
            @isazi said in Hotfix 2.23.24:
            Is there other things fixed (I think of Suunto apps that can’t be selected for example) ?
            Is this update recommended even if we don’t have the crash during exercises ?
            Best regards.
            Mathieu
            Suunto’s devices at home :
            Vertical titanium solar
            Suunto Race S
            S9pp titanium sand
            Suunto Wing & Spark
            S9B titanium Ambassador edition, A3P, X6
            isaziI 1 Reply Last reply Reply Quote 1
            • isaziI Offline
              isazi Moderator @Tieutieu
              @Tieutieu to the best of my knowledge, this update is made to fix a specific bug. I personally would install it anyway, even if the bug didn’t affect me so far, to avoid it happening in the future.
              Blog: isazi's home
              R TieutieuT 2 Replies Last reply Reply Quote 1
              • R Offline
                renandp11 @isazi
                @isazi Hi there! Sorry I’m 3 days new to Suunto. Is there a way to download latest hotfix? My Suunto link app is still trying to download v2.23.20 and my Suunto 9 Baro remains crashed with the downward arrow and second dost flashing. Tried soft reset but remains the same. Thanks for advicing!
                isaziI EgikaE 2 Replies Last reply Reply Quote 0
                • TieutieuT Offline
                  Thanks !
                  Suunto Race S
                  S9pp titanium sand
                  Suunto Wing & Spark
                  • isaziI Offline
                    isazi Moderator @renandp11
                    @renandp11 that should not happen. What operating system are you using? Which Suuntolink version?
                    Blog: isazi's home
                    • Andi BuzerA Offline
                      Andi Buzer Bronze Member @isazi
                      @isazi is there an ETA for this fix for the s9p? Mine crashed two to three times at every workout in the last week
                      Watches:
                      Suunto 9
                      Suunto 9 Peak Titanium
                      isaziI 1 Reply Last reply Reply Quote 2
                      • isaziI Offline
                        isazi Moderator @Andi Buzer
                        @Andi-Buzer I have no knowledge about that, will share updates if I do.
                        Blog: isazi's home
                        • EgikaE Online
                          Egika Platinum Member @renandp11
                          @renandp11 If Suuntolink does not find the update automatically, you can try this link to manually download the file (then drag the zip onto the watch in SuuntoLink)
                          https://devicefirmwares.blob.core.windows.net/firmwares/Ibiza-fw_2.23.24.1722-F.zip
                          • BeepiB Offline
                            Beepi @isazi
                            @isazi this patch didn’t solve the bug affecting the Suunto app loop:pace. I bet also other apps are involved, although I don’t use them. Just select the app and start the activity. The app will show once and then if you scroll/swipe the screens, it will freeze or disappear (black screen). Just try it out. This bug was reported months ago in the forum. Is disappointing you don’t hear.
                            N 1 Reply Last reply Reply Quote 0
                            • N Offline
                              nseslija Bronze Member @Beepi
                              @Beepi i have the same problem with the app loop speed. The workaround, while waiting for the fix from Suunto, is to remove all the apps from the watch , reset the watch and then add the apps back to the watch. The solution works for some time, and then all over again…
                              Ambit 2S
                              Ambit 3 Peak
                              Suunto 9 baro
                              Suunto Vertical Ti Solar
                              • isaziI Offline
                                isazi Moderator @nseslija
                                @nseslija a reset is needed? Just removing the S+ app from the watch and then add it again does not solve the issue?
                                I was not aware that the S+ loop app does not work, I use it with my S9P often.
                                Blog: isazi's home
                                N BeepiB 2 Replies Last reply Reply Quote 0
                                • N Offline
                                  nseslija Bronze Member @isazi
                                  @isazi I think that I tried without reset and it didn’t work…
                                  Ambit 2S
                                  Ambit 3 Peak
                                  Suunto 9 baro
                                  • BeepiB Offline
                                    Beepi @isazi
                                    @isazi I have tried it all: soft reset, hard reset, downgrading, removing-adding apps, but it’s always the same… I have the 9baro though…
                                    • N Offline
                                      @Beepi It worked for me…
                                      Ambit 2S
                                      Ambit 3 Peak
                                      Suunto 9 baro
                                      BeepiB 1 Reply Last reply Reply Quote 0
                                      • BeepiB Offline
                                        Beepi @nseslija
                                        @nseslija having to reset saggests that not the app is foulty but the integration of the app with some sport modes… I use it for example in connection with the sport mode for cross country skiing…
                                        • N Offline
                                          @Beepi I use it in custom cycling sport mode. I don’t think it is sport mode related, don’t sure… I noticed that it has stopped working after the SA update once …maybe just coincidence…
                                          Ambit 2S
                                          Ambit 3 Peak
                                          Suunto 9 baro
                                          • BeepiB Offline
                                            Beepi @nseslija
                                            @nseslija bug was introduced with the software version 2.20.30… I had no problems before…
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
