    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Wrist Running Power
    Scheduled Pinned Locked Moved Suunto 9 Peak
    16 Posts 10 Posters 2.4k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Andi BuzerA Offline
      Andi Buzer Bronze Member
      From what I have read here running power for the s9pp gets calculated from GPS and Baro data. Is there any other hardware that’s new to the s9pp which is used or can we have hope to get the pleasure of running power on the s9p too ?
      Watches:
      Suunto 9
      Suunto 9 Peak Titanium
      DMytroD isaziI 2 Replies Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @Andi Buzer
        @Andi-Buzer I guess it’s the new baro hardware, that is exclusive to s9pp.
        • isaziI Offline
          isazi Moderator @Andi Buzer
          @Andi-Buzer running power, to my knowledge, is not coming to the S9P.
          Blog: isazi's home
          • Łukasz SzmigielŁ Offline
            Łukasz Szmigiel
            I was always thinking that wrist-based running power is using a combination of GPS and hand movement (acceleration) to calculate the power (and baro for uphill, downhill). Is it just GPS and baro?
            S9PP 2.50.28
            • EgikaE Offline
              Egika Platinum Member @Łukasz Szmigiel
              @Łukasz-Szmigiel there is quite a few variables going into the calculation.
              As power is the effort needed to move your body along the road or up a hill, at least speed, altitude change, weight will go into the equation.
              Plus there is acceleration and deceleration und possibly efficiency (guesstimate from arm movement).
              What it cannot take into account is head or tailwind though…
              Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 1
                Łukasz Szmigiel @Egika
                @Egika lack of wind in calculation is a bummer. Also - changing of effort due to ground surface change.
                S9PP 2.50.28
                Brad_OlwinB 1 Reply Last reply Reply Quote 2
                • Brad_OlwinB Offline
                  Brad_Olwin Moderator @Łukasz Szmigiel
                  @Łukasz-Szmigiel said in Wrist Running Power:
                  The wind adds or detracts very little to power unless the wind is very strong and would affect HR as well. This is true from Stryd’s pod. I am not sure wind is worth it. Instantaneous power IMHO is not very useful, but the zones definitely are. Changes in your direction vs. wind would have to be near instantaneous.
                  Vector/T6c/Vertical 2 Ti
                    Łukasz Szmigiel @Brad_Olwin
                    @Brad_Olwin well, this is the case. I’m not thinking about a lil windy, but mouthful of wind. I usually run through the fields, and there are hardly any trees, and it’s flat as a pancake. I can easily go +/- 20 HR if I’m with or against the wind. But the power stays the same. Just curious - would Stryd pick it up?
                    S9PP 2.50.28
                    suzzloS 1 Reply Last reply Reply Quote 0
                    • BulkanB Offline
                      Bulkan Moderator
                      In my experience wind added more noise and inconsistency during runnings when is a wind from one side… I’m not a huge fan of wind stride pod for that reason and the valued added is not so important.
                      Yes wind exists and it is there but I don’t find it useful.
                      Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                        Łukasz Szmigiel
                        I think that we need new sensor for wind.
                        S9PP 2.50.28
                        1 Reply Last reply Reply Quote 7
                        • suzzloS Offline
                          suzzlo Moderator @Łukasz Szmigiel
                          https://blog.stryd.com/2019/06/27/announcing-the-new-stryd/
                          Suunto: Race, S9Peak, Spartan Sport Wrist
                          Garmin: FR745, Edge 530
                          SA topics:
                          • Guides - https://forum.suunto.com/tags/guides
                            Łukasz Szmigiel @suzzlo
                            @suzzlo interesting, do you have any insights how it compares to wrist based power?
                            S9PP 2.50.28
                            Brad_OlwinB 1 Reply Last reply Reply Quote 1
                              I have done a lot of testing with 9PeakPro with the Stryd Pod (generation prior to wind). They are very similar. The major differences I saw were on very hard VO2 Max intervals the Stryd had higher max power and slightly higher avg power. Not enough to change the Critical Power calculations. Wrist-based power is much more convenient and always there. I did not like having to deal with the pod all the time.
                              zhang965Z 1 Reply Last reply Reply Quote 1
                              • zhang965Z Offline
                                zhang965 @Brad_Olwin
                                Brad_Olwin said in Wrist Running Power:
                                I have done a lot of testing with 9Peak and 9PeakPro with the Stryd Pod (generation prior to wind). They are very similar. The major differences I saw were on very hard VO2 Max intervals the Stryd had higher max power and slightly higher avg power. Not enough to change the Critical Power calculations. Wrist-based power is much more convenient and always there. I did not like having to deal with the pod all the time.
                                WOW, s9peak has wrist power. I see I see.
                                Winners Wear Winners
                                • herlasH Offline
                                  herlas Silver Members
                                  Yesterday had a very windy first part of my easy run, this was well captured by my Stryd pod, as you can see 6% of my total power output was added by wind resistance
                                  I’d say if you’re just getting started with running power and don’t have a Stryd pod, the wrist based power is a good start 😉
                                  SRS Ti
                                  SRun (primarily road runner so testing SRun is a must ;))
                                  1 Reply Last reply Reply Quote 3
                                    Brad_Olwin Moderator @zhang965
                                    @zhang965 Sorry about that, they look the same and I can forget which one I have on my wrist. Thanks for the correction. I fixed the post.
                                    Register Login
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
