    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Crazy Altitude
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    14 Posts 6 Posters 1.7k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • zhang965Z Offline
      zhang965
      Hello,
      I noticed the altitude in the sleep log is changed .
      Normally it’s about 62m for awhile, and one day it becomes negative, (-12) then keeping it until now
      I sleep in the same place…
      And my watch altitude shows the negative value as well
      Screenshot_2023-01-12-21-51-33-73_7a4090f09f6554852d748ee9fd6f40d3.jpg Screenshot_2023-01-12-21-51-52-19_7a4090f09f6554852d748ee9fd6f40d3.jpg
      If you notice the same behavior, please report.
      Thanks
      Winners Wear Winners
      freeheelerF 2 Replies Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @zhang965
        @zhang965
        maybe related to this one? https://forum.suunto.com/topic/8430/incorrect-sleep-spo2-elevation-on-watch
        living sideways
        zhang965Z 1 Reply Last reply Reply Quote 0
        • zhang965Z Offline
          zhang965 @freeheeler
          @freeheeler said in Crazy Altitude:
          @zhang965
          Nope, I don’t think so, I sleep in the same place.
          Umer JavedU 1 Reply Last reply Reply Quote 0
            @zhang965 said in Crazy Altitude:
            with that info added it is indeed different to the other topic.
            I think it’s more the question why the altitude was so low and did you notice before and after?
            something must have been different that day
            living sideways
            • Umer JavedU Offline
              Umer Javed @zhang965
              @zhang965 right. In my case it’s just the watch that showed incorrectly but the app showed correctly. And it’s apparently been solved in the next build.
              • babychaiB Online
                babychai Silver Members
                happened to my watch many times. it will become negative. i think because of the weather changes it will affect the altitude. Usually after turn on my GPS for outdoor exercise it will fix this issue. Or you can adjust it at the Outdoor setting there to correct it.
                Suunto Vertical Titanium Solar Black
                Suunto 9 Peak All Black
                Suunto Spartan Trainer Wrist HR (Black)
                zhang965Z 1 Reply Last reply Reply Quote 1
                • zhang965Z Offline
                  zhang965 @babychai
                  @babychai said in Crazy Altitude:
                  Jaja, today is a sunny day and I wake up with -30m altitude.
                  Damn, I thought someone buried me last night, -30m! It’s a lot of work.
                  freeheelerF 1 Reply Last reply Reply Quote 1
                    @zhang965
                    just to be sure. this is the altitude you also see when you flip to the altitude widget?
                    it is not only shown in the oxygen widget?
                    living sideways
                    • zhang965Z Offline
                      @zhang965
                      My bad I shouldn’t listen it…
                        @zhang965
                        see, you have been warned 😉
                        looks like altitude is shifting excessively on your watch. you’re experienced and I assume you’ve already checked if the sensor is free and clean?
                        living sideways
                        • Łukasz SzmigielŁ Offline
                          Łukasz Szmigiel
                          I see it that dramatic only for a while when the sensor is soaked in water, eg. when taking a shower. Never had a subterranean barometric reading (but GPS is a whole other story! 😉 )
                          S9PP 2.50.28
                          • zhang965Z Offline
                            zhang965
                            After listening to stairway to heaven, It shows 86m now,
                            D 1 Reply Last reply Reply Quote 4
                            • D Offline
                              DF130 Bronze Member @zhang965
                              @zhang965 I am close to sea level but on the 5th floor of a building and my S9P (not PP) shows -1m. Has been pulling those stunts all along (and I think my S9B as well, but would have to check). Might be that whenever you are “broadly“ stationary but not from the watch‘s perspective (b/c you eg took a shower, walked the stairs etc), subsequent changes in pressure then get interpreted as changes in altitude w/o any GPS correction as long as you do not start an exercise…
                              • zhang965Z Offline
                                zhang965 @DF130
                                @DF130 said in Crazy Altitude:
                                Ja, I know, but I’m concerning during first 2weeks it shows 60m, and then it turned to -12m
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
