    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 App won't stay running.
    Scheduled Pinned Locked Moved Suunto 7
    12 Posts 3 Posters 1.2k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • R Offline
      rickmcmullen
      For some reason I can no longer get the App to stay running. It attempts to start and then shuts down after about 15 seconds. I’ve both restarted, and shut down my watch. I disassociated my watch from my phone and now I can’t reconnect it. When I try the app says it’s reconnected, but them goes back to the beginning prompting me to reconnect. The watch shows it as connected in the Blue Tooth settings. I initiated a Bug Report, but I don’t know where to send it.
      sartoricS 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @rickmcmullen
        @rickmcmullen
        Did you unpair the watch from wearos or just bt ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.10.7 beta
        R 1 Reply Last reply Reply Quote 0
        • R Offline
          rickmcmullen @sartoric
          @sartoric
          Just bt. If I unpair it from WearOS is will do a factory reset.
          pilleusP 1 Reply Last reply Reply Quote 0
          • pilleusP Offline
            pilleus @rickmcmullen
            @rickmcmullen said in Suunto 7 App won't stay running.:
            @sartoric
            You can do it without resetting the watch, just search for ADB and the needed commands.
            https://www.instagram.com/moves.are.life/
            Suunto Vertical Black Lime
            Suunto 9 Peak Pro Black
            Suunto Spartan Ultra Stealth Titanium
            • R Offline
              rickmcmullen @pilleus
              @pilleus
              Necessary commands to do what exactly? Unpair from WearOS? What will that do, and what is the next step should I be able to do it?
              • R Offline
                rickmcmullen
                Just to clarify, this issue is affecting the App on my Watch, not the App on my phone. Will disconnecting/unpairing resolve the problem or have any effect on the App running on my Watch?
                • pilleusP Offline
                  @rickmcmullen Try to delete the cache or even all data of the Suunto app on the watch and force the app to stop. Then start the app again and maybe it will work again.
                  Settings - apps and info - system apps
                  • R Offline
                    @pilleus
                    I tried clearing the cache (which doesn’t actually clear it…there’s still data in the cache…it doesn’t go to zero) and it didn’t work. Clearing the data will essentially perform a factory reset which I’m trying to avoid if at all possible.
                    • pilleusP Offline
                      reset the settings in the Suunto app on the watch, nothing else. Custom profiles and so on. It doesn’t affect the WearOS settings or other apps or the watch face or general watch settings.
                      I assume that you are in the settings of the Suunto app in the section system apps!
                      • R Offline
                        @pilleus
                        I cleared the data and now when I try to go through the Setup it bombs after the 2nd screen where I need to select Gender.
                        • pilleusP Offline
                          @rickmcmullen Okay, then the app is corrupted and must be restored by a factory reset. I think there is no other way for you to fix it.
                          I personally would activate the developer mode and then would deactivate the Suunto app via ADB, reboot the watch and activate it again. But it needs some experience with ADB and the command line to send the needed code.
                          Did you reboot the watch after deleting the data? Give it a try.
                          • R Offline
                            @pilleus
                            Yes, I rebooted the watch after deleting the data. I just went forward with the factory reset. That seems to have fixed it…this time!
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
