    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Treadmill Distance Accuracy
    Scheduled Pinned Locked Moved Suunto 7
    43 Posts 12 Posters 13.7k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • pilleusP Offline
      pilleus @pilleus
      @pilleus said in Treadmill Distance Accuracy:
      I hope NPE will answer my request in the way, that the SPD profile is also available via BLE to have all the data on Suunto watches too.
      Got an email from NPE today. The team will discuss it in the next meeting. šŸ’Ŗ
      https://www.instagram.com/moves.are.life/
      Suunto Vertical Black Lime
      Suunto 9 Peak Pro Black
      Suunto Spartan Ultra Stealth Titanium
      • Jamie BGJ Offline
        Jamie BG Bronze Member @Guest
        @lessthanmore
        The Garmin calibration is a little bit different in that it then uses that basis for your next run - so assuming your stride is reasonablly even the next run should be pretty close to what your treadmill determines as distance.
        Fortunately it does offer the option to recalibrate if it isn’t.
        Biggest issue with the calibration is you have to run over 1 mile.
        ? 1 Reply Last reply Reply Quote 1
        • ? Offline
          A Former User @Jamie BG
          @Jamie-BG Yes, you’re right. Tested it this morning.
          Treadmill: 6.26km
          Zwift + Garmin HRM Pro: 6.3km
          S9PP: 7.5km
          A bit annoying since I use the treadmill often.
          • quattrojamesQ Offline
            quattrojames
            I’m on week 4 of C25k now and am pleased with my progress.
            4k on the treadmill was reading 5.1k on my watch - I just adjust it after each run and it doesn’t worry me too much.
            If I get into treadmill running then I’ll invest in that Runn device which looks really clever, but as I use a shared treadmill I’ll wait till I become obsessive about it 😧
            Suunto Race
            Pixel 6 pro
            • KetoohsK Offline
              Ketoohs Silver Members
              Which pod is best performance to cost? I would only use it for treadmill accuracy, so I don’t need power or any advanced metrics.
              Can the zwift pod connect directly to Suunto?
              Tnx
              Karoo3 (2024)
              Vertical allBlack (2023)
              9 Peak Black (2022)
              Spartan WHR Black (2017)
              Ambit 2 Black (2013)
              S 1 Reply Last reply Reply Quote 0
              • S Offline
                Spree Bronze Member @Ketoohs
                @Ketoohs I would argue if you want to keep things cheap the Zwift POD is a good choice. Always worked fine for me, and it goes for 45 euros in most EU countries: I don’t know if anything cheaper exists, honestly. Before Zwift acquired it it was called Milestone, and you could get it for 20 - sadly, no longer the case.
                pilleusP Stas VarazhbitS 2 Replies Last reply Reply Quote 0
                • pilleusP Offline
                  pilleus @Spree
                  I recommend to use the Runn treadmill sensor. No foot pod can give these exact data. Pace, incline and cadence are precise measured by the Runn and the connection to Zwift or Suunto watch is possible. Just incline is missing on the Suunto watch, but may be there is a future S+ app.
                  The graph for the incline is showing the shock absorption because the Runn is very sensitive. But the advantage is to have the ascent of the training in meters.
                  Andi BuzerA 1 Reply Last reply Reply Quote 3
                  • Andi BuzerA Offline
                    Andi Buzer Bronze Member @pilleus
                    @pilleus I bought one today after having a treadmill workout last week, which tracked 12km despite treadmill displaying 11km. I hope it arrives quick, can’t wait to test it and I hope they add a s+ app for incline.
                    Watches:
                    Suunto 9
                    Suunto 9 Peak Titanium
                    • Stas VarazhbitS Offline
                      Stas Varazhbit @Spree
                      @Spree I have a ZWIFTpod and it is very unreliable. It constantly falls off the connection and the battery drains very quickly. I tried training with it in the arena and on the treadmill, but because of these problems I had to give up using it. Maybe it needs some kind of calibration or firmware, I don’t know.
                      @pilleus pace looks fantastic in the photo.
                      Suunto 9P
                      Suunto 9 no baro
                      Suunto Ambit3S
                      • S Offline
                        Spree Bronze Member @Stas Varazhbit
                        @Stas-Varazhbit I agree with the battery, it’s not great. I didn’t have connectivity problems though.
                          I received my Runn Sensor on Friday and did two runs with it over the last two days. It’s stunningly accurate, no big differences and kilometer vibration of the watch matches with display of the treadmill.
                          Watches:
                          Suunto 9
                          pilleusP 1 Reply Last reply Reply Quote 2
                          • pilleusP Offline
                            pilleus @Andi Buzer
                            @Andi-Buzer Did you increase the sensitivity of the Runn to obtain a correct cadence?
                            Andi BuzerA 1 Reply Last reply Reply Quote 0
                              @pilleus no not yet. I did the speed and incline calibration with the configurEZ app and nothing else.
                              I just compared it to the trackings before installing the runn sensor and it appears to have almost doubled for the same speed. 79 before installing to 155 after installing.
                              Watches:
                              Suunto 9
                              pilleusP 1 Reply Last reply Reply Quote 0
                              • pilleusP Offline
                                pilleus @Andi Buzer
                                @Andi-Buzer It’s another value. There is SPM and cadence. If I sync the activity to Strava I get the double value of the SPM, which is the (cadence * 4) … šŸ™„
                                And if you use the Runn without calibration, you will get the real speed and distance, which may differ from your treadmill. I just calibrated the incline and use the speed settings without calibration.
                                  @pilleus so just to make sure I got it right. Cadence is one leg, SPM both legs. And Strava misinterprets the value delivered by the runn and doubles it ?
                                  I guess I should reset the runn to factory calibration then šŸ¤”
                                  And now on German to eliminate the chances of me messing up translation:
                                  Also es ist ein Datenfeld, aber die Uhr berechnet den Wert anders als der Runn ? Und Strava geht von der Art und Weise aus wie die Uhr es berechnet und nimmt den Wert Mal 2 ?
                                  Watches:
                                  Suunto 9
                                  • pilleusP Offline
                                    pilleus @Andi Buzer
                                    @Andi-Buzer Garmin macht es korrekt, das Datenfeld stimmt, die Angaben auch.
                                    Suunto App zeigt z. B. 176 spm, Strava macht daraus beim Synchronisieren 352 S/min.
                                    Warum auch immer.
                                    For all: Garmin is okay, the data field is correct, the data too.
                                    Suunto app shows e. g. 176 spm, after the sync to Strava I get there 352 S/min.
                                    No idea why.
                                      Today I ran into a new problem. After having to reset my s9p because workouts weren’t synced to it anymore. I obviously had to pair my runn to my watch again, and now my watch does not use the pace values delivered by the runn. Do I have to do some outdoor runs to get the calibration off the watch to work and then accept the values of the runn ā€œfootpodā€ ?
                                      The problems which occur with my s9p in the last few weeks makes me really want to leave suunto…
                                      Watches:
                                      Suunto 9
                                      • pilleusP Offline
                                        pilleus @Andi Buzer
                                        @Andi-Buzer
                                        Did you pair the Runn as foot pod? The blue LED is on, when connected to the watch? And the Runn configuration is okay? The on/off switch is configurable to switch off both, BLE and ANT+. Just to be sure …
                                          @pilleus yeah it’s paired as footpod and I double checked configuration. It’s also displayed as connected when I start the workout.
                                          Watches:
                                          Suunto 9
                                          • pilleusP Offline
                                            pilleus @Andi Buzer
                                            @Andi-Buzer
                                            Okay, you can try to change the data field from pace to speed to check if this is the problem. The sticks on the treadmill floor are okay? Does the app Configurez show the speed and incline?
                                            With your input, this post could be even better šŸ’—
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
