    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Increased battery drain
    Scheduled Pinned Locked Moved Suunto 7
    49 Posts 8 Posters 6.9k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • quattrojamesQ Offline
      quattrojames
      Following on from the discussion in this thread: https://forum.suunto.com/topic/8024/suunto-7-sleep-not-synching-to-suunto-app/14
      I’m suffering much increased battery drain both overnight and during the day, reportedly this is due to the latest Wear update. I’m seeing massive drain from the Wear OS in the battery stats, see below.
      Anyone got any ideas how to resolve this? I’m told you can uninstall the latest update but I don’t know how.
      Suunto Race
      Pixel 6 pro
      BinoWorld UKB pilleusP 2 Replies Last reply Reply Quote 0
      • BinoWorld UKB Offline
        BinoWorld UK Bronze Member @quattrojames
        @James-Howes fully reset the watch that should clear the issue.
        • K Offline
          Kramble
          Like I said in the linked thread, the reboot doesn’t do anything for me.
          The drain comes from the last wear os update, like you can see on your chart.
          Uninstall wear os (it just uninstalled the update) solved the issue on my watch.
          You will probably need to reset cache from your wear os mobile app too in doing this.
          To keep things like this after that I disabled auto update from watch mobile Google play app.
          Ambit 3 peak saphir
          Spartan Ultra (sold)
          S7 graphite copper
          S9 peak all black
          Vertical titanium green forest
          Wings
          • J Offline
            judnoe
            Good morning.
            I restored the S7 and improved the battery, but it was updated and I have a high consumption again.
            I have removed the latest update with Wear OS, now I have version 2.46.0365651031.u, delete cache and restart, but consumption is still high.
            The version that appears on Google Play is 4.3 to update.
            With a 91% battery gives me for 9 hours according to the Wear Os app of the mobile. And the Wear Os has 4% consumed.
            Any suggestions?
            • J Offline
              judnoe
              In the end I disabled Google Fit. I hope it gets better. Installed version is the previous one, 2.58.13.230
              K 1 Reply Last reply Reply Quote 0
              • K Offline
                Kramble @judnoe
                @judnoe Now I have the same Wear Os version than you and Google Fit and Wallet are disactived (but I always do that) and I have no battery drain issue anymore.
                Maybe I did a reboot (not reset) of the watch after uninstalled the last update of wear os…
                Ambit 3 peak saphir
                S7 graphite copper
                S9 peak all black
                Wings
                  quattrojames
                  I’m running 2.59.0.476 on the phone and:
                  2.59.0.471 on my watch.
                  I uninstalled it off the phone but it just reinstalls the same version again I’ve found.
                  Interestingly on the watch I have a “Remove Upgrades” option but its greyed out. I’ve cleared the cache and data.
                  @Kramble said in Increased battery drain:
                  When you said this, do you mean uninstall from the watch or the phone? I’m not sure I have an uninstall option on the watch.
                  hard reset is my last resort as it’s such a pain, plus if its a WearOS issue I can’t see that making a difference.
                  Wear OS is currently showing a battery drain at 5% which is a bit more realistic.
                  Suunto Race
                  Pixel 6 pro
                  • K Offline
                    Kramble @quattrojames
                    @James-Howes From the watch
                    Ambit 3 peak saphir
                    S7 graphite copper
                    S9 peak all black
                    Wings
                    quattrojamesQ 1 Reply Last reply Reply Quote 1
                    • J Offline
                      judnoe
                      You uninstall from the watch, but what it does is remove the latest update from Google play
                      • pilleusP Online
                        pilleus @quattrojames
                        @James-Howes
                        https://www.facebook.com/groups/2952679438107711/permalink/8447345481974385/
                        https://www.instagram.com/moves.are.life/
                        Suunto Vertical Black Lime
                        Suunto 9 Peak Pro Black
                        Suunto Spartan Ultra Stealth Titanium
                        quattrojamesQ 1 Reply Last reply Reply Quote 0
                          quattrojames @pilleus
                          @pilleus Thanks, I can’t read it so I’ve submitted a join request.
                          Suunto Race
                          Pixel 6 pro
                            quattrojames @Kramble
                            I’ve uninstalled WearOS from the watch and its reverted back to the previous version. I’ve also turned auto-updates off.
                            The battery drain over the last few hours is showing as 1% for WearOS so I hope this has fixed it.
                            Suunto Race
                            Pixel 6 pro
                            pilleusP 1 Reply Last reply Reply Quote 0
                            • pilleusP Online
                              @James-Howes Mobvoi announced that the last WearOS update via Google is the issue for the battery drain (Wear OS version 2.59.0.471251175 is the one having the battery issue). Disable the auto-update function of WearOS in Play Store after downgrading oder resetting the watch.
                                quattrojames
                                I woke up this morning and the WearOS drain is back up to 41%!
                                I checked the watch version is still 2.46.0.365 so I’ve no idea what is going on now.
                                I’ve just charged it and I’ll keep an eye on it today, if needs be I’ll do a reset later but I hate the hassles of doing that.
                                Suunto Race
                                Pixel 6 pro
                                • K Offline
                                  @James-Howes what can we try ?
                                  On your watch : clear cache on app wear os ? reboot watch ? deactivate Google Fit or Wallet ?
                                  On your phone : clear cache on wear os ?
                                  Did you desactivate auto update (two stuffs to do I think) on your watch in the play store ?
                                  Ambit 3 peak saphir
                                  S7 graphite copper
                                  S9 peak all black
                                  Wings
                                    @Kramble Thank you.
                                    I think I cleared the cache on the watch when I uninstalled WearOS yesterday but I can’t remember so I’ve done it again. And I’ve rebooted the watch again.
                                    I hadn’t cleared the app cache on the phone so I’ve done that.
                                    I’ll deactivate Google Wallet, I’ll keep Fit for now as I use that and see if any of these other steps help first.
                                    I had already deactivated auto-updates on the watch, I did this through the settings on the play store and it’s showing me a new WearOS update is available for download so I presume its worked, watch is still running the previous version anyway. Is there a further setting I need to de-activate?
                                    Suunto Race
                                    Pixel 6 pro
                                      @pilleus said in Increased battery drain:
                                      Looks like they’re all moaning about the lack of WearOS 3 being released! If this latest update is anything to go by then I’m glad we’re not getting it!
                                      Suunto Race
                                      Pixel 6 pro
                                      • J Offline
                                        judnoe
                                        Good afternoon.
                                        Yesterday I charged the clock at 13:01 and today at 13:00, with an exercise of 1:20, I still have 49% battery left.
                                        Restore to factory, remove automatic updates, disable google Fit.
                                        Version of Wear OS installed on the watch: 2.46.0.365651031.u
                                        The version of Wear Os to update from Google Play is 2.59.0.471251175, supposedly the one that discharges the battery.
                                        • ? Offline
                                          A Former User @judnoe
                                          Strange, I have in use this version and not noted any anormal behavior. I will put a double eye on it after next re-charge, thank you.
                                          isaziI 1 Reply Last reply Reply Quote 1
                                          • isaziI Offline
                                            isazi Moderator @Guest
                                            @flypg same for me, same battery use as with previous versions.
                                            Blog: isazi's home
                                            BinoWorld UKB 1 Reply Last reply Reply Quote 0
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
