    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HR sensor on watch and external at the same time
    Scheduled Pinned Locked Moved Suunto 5
    11 Posts 2 Posters 1.1k Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • matt-rM Offline
      matt-r
      Hi,
      I have an external HR sensor and everything is ok, gives measurements etc.
      In the watch itself, in the options for a particular exercise I have an option such as disable HR monitoring from the watch.
      What is the relationship during exercise - measurement from the external sensor and leaving this option enabled in the watch?
      HR is measured from both sensors?
      Matt
      DMytroD 1 Reply Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @matt-r
        @matt-r nope, if the watch connects to the sensor, it uses just that automatically. No need to toggle watch HR off every time.
        matt-rM 1 Reply Last reply Reply Quote 0
        • matt-rM Offline
          matt-r @DMytro
          @DMytro Ok, that’s generally what I thought 🙂
          By the way - is the possible lack of VO2max measurement affected by turning off the heart rate on the watch?
          I bet not, but… After disabling this option - with today’s 8km run, 45 min normal pace. I got no such measurement - hence my interest in this duplicate option.
          • DMytroD Offline
            DMytro @matt-r
            @matt-r if HR was measured my HR strap, VO2Max shouldn’t disappear.
            • matt-rM Offline
              matt-r @DMytro
              @DMytro Ok - another thing I reasonably expected 😉
              Then I am now curious why there was no measurement of VO2max 😕
              • DMytroD Offline
                DMytro @matt-r
                @matt-r did you have vO2 before? Or did you reset your watch recently?
                • matt-rM Offline
                  matt-r @DMytro
                  @DMytro Yes, I was doing a hard reset - I had a problem with the update.
                  However, I thought that the VO2max measurement should be read - as it is written in the instructions - even after the first exercise, but lasting a minimum of 15 min 🙄
                  • DMytroD Offline
                    DMytro @matt-r
                    @matt-r sometimes 1 exercises is not enough. Do a couple more and everything will be ok
                    matt-rM 1 Reply Last reply Reply Quote 2
                    • matt-rM Offline
                      matt-r @DMytro
                      @DMytro Sure, that’s probably how it will be.
                      But strange, because I remember exactly that after an identical first run I immediately got a VO2max sample and now I don’t 🤔
                      • DMytroD Offline
                        DMytro @matt-r
                        @matt-r the firstbeat vo2max algo has some filtering process, which throws away portions of data if it thinks they are faulty/not accurate enough. Since it’s colder now, maybe it impacted the quality of the data and algorithm decided the data wasn’t enough to give you a reliable value.
                        matt-rM 1 Reply Last reply Reply Quote 1
                        • matt-rM Offline
                          matt-r @DMytro
                          @DMytro oooo! that’s an interesting observation, I hadn’t thought of that 😄
                          Cool tip - such for general understanding of Suunto ecosystem 🙂
                          thanks!
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
