    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Units as nmi and kts if it is metric
    Scheduled Pinned Locked Moved Suunto 5
    25 Posts 4 Posters 4.3k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      dahab
      Hello,
      now my Suuonto displays the speed in kN and the distince in nmi instead of km/h and km (meters)…
      why that - I have set the units in metrics?
      robert
      freeheelerF 2 Replies Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @dahab
        @dahab
        that’s default for nautical sports (SUP excluded afaik)
        living sideways
        D 1 Reply Last reply Reply Quote 0
        • D Offline
          dahab @freeheeler
          @freeheeler
          • D Offline
            dahab @dahab
            @dahab said in Units as nmi and kts if it is metric:
            @freeheeler
            I don’t want to have it - how to change this?
            a few months ago it worked as expected - seems to be an update caused that 😞
            robert
            surfboomerangS 1 Reply Last reply Reply Quote 0
            • surfboomerangS Online
              surfboomerang @dahab
              @dahab true… and already fixed in the latest beta. Just wait a little longer.
              Suunto Vertical Titanium Solar
              OnePlus Nord 4
              D 1 Reply Last reply Reply Quote 1
              • D Offline
                dahab @surfboomerang
                @surfboomerang OK thanks
                freeheelerF 1 Reply Last reply Reply Quote 0
                  freeheeler @dahab
                  @dahab
                  on the watch you can always create your own sport mode and set units as you want
                  living sideways
                  • D Offline
                    dahab @freeheeler
                    @freeheeler Ok but how about an existing custom sport mode?
                    I cannot find unit settings for that
                      freeheeler @dahab
                      @dahab
                      if you have your custom sport mode created in metric, it should remain metric (unless I’m wrong). the data that’s shown in SA was changed to nautical and since recently both units are displayed to serve both flavors.
                      edit:
                      ok, it doesn’t show units, neither in the setup on the phone nor in the datafield in the watch… so I can’t say for 100% for now
                      living sideways
                        surfboomerang @freeheeler
                        @freeheeler The watch has two fields for speed and two for distance
                        • Speed: depending on the watch unit setting
                        • Nautical speed: Speed in kts. Independent of the unit setting in the watch
                        • Distance: depending on the watch unit setting
                        • Nautical distance: Distance in nautical miles. Independent of the unit setting in the watch
                        The app shows both in the activity summary
                        OnePlus Nord 4
                        freeheelerF 1 Reply Last reply Reply Quote 3
                          freeheeler @surfboomerang
                          @surfboomerang
                          I just checked and can not say that I undoubtedly see which is which… I also checked in custom sport mode.
                          I for one am missing units
                          living sideways
                            @freeheeler It depends on the field settings.
                            WIth 3 fields I see the unit behind the value. On a 5 field screen I only see the icons so I am unable to distinguish the difference.
                            OnePlus Nord 4
                            freeheelerF 1 Reply Last reply Reply Quote 1
                              @surfboomerang
                              it would be cool to see the unit here 🙂
                              living sideways
                              isaziI surfboomerangS 2 Replies Last reply Reply Quote 0
                              • isaziI Offline
                                isazi Moderator @freeheeler
                                @freeheeler in this case it is not necessary, “Distance” and “Nautical distance” are different, and distance will be in km/h or m/h depending on settings.
                                Blog: isazi's home
                                surfboomerangS 1 Reply Last reply Reply Quote 1
                                  @freeheeler Yes, but then the unit setting in the watch must be made available in the app.
                                  The only fields in SA that show unit settings are vertical speed fields. But the fact that they are described as “m/h (ft/h)” indicates no unit information is synced from the watch to SA. It only indicates how vertical speed is measured
                                  OnePlus Nord 4
                                    surfboomerang @isazi
                                    @isazi said in Units as nmi and kts if it is metric:
                                    And this
                                    OnePlus Nord 4
                                      @surfboomerang
                                      @isazi
                                      maybe I miss something here… ml and cl are different, too, but in order to use the correct amount, I need to know the unit?
                                      living sideways
                                        freeheeler @dahab
                                        @dahab
                                        I’ve tried and I am confused now…
                                        SA shows both units on the phone. but I can see only metric units on my custom sport mode (kitesurfing)
                                        living sideways
                                          @freeheeler How is your custom profile configured?
                                          OnePlus Nord 4
                                            @surfboomerang
                                            there’s not so much to configure in terms of units
                                            living sideways
                                            isaziI 1 Reply Last reply Reply Quote 0
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
