    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Batterie 9 peak
    Scheduled Pinned Locked Moved Suunto 9 Peak
    12 Posts 6 Posters 955 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Regis Letowski 0R Offline
      Regis Letowski 0
      Bonjour, moins 6℅ de batterie la nuit est ce normal ?
      Comment savoir si la ceinture est bien connecté ?
      Beaucoup de questions sur l’utilisation de cette montre…
      Merci
      surfboomerangS 1 Reply Last reply Reply Quote 0
      • surfboomerangS Online
        surfboomerang @Regis Letowski 0
        @Regis-Letowski-0 It depends…
        maybe give us some more information about the settings you enabled/disabled so we can better judge if the battery drain is normal.
        Also here is some more information about the watch. I think it answers some of your questions.
        https://www.suunto.com/Support/Product-support/suunto_9_peak/suunto_9_peak/
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        Regis Letowski 0R 1 Reply Last reply Reply Quote 1
          Regis Letowski 0 @surfboomerang
          @surfboomerang bonour, ceinture cardio super elle fonctionne
          cette nuit j’ai parametré economie dénergiedonc pas de consommations
          hier 1200 m de denivellé 5h de marche moins 15 % ce qui est normal mais moins 6% pour la nuit ???
          M 2 Replies Last reply Reply Quote 0
          • M Offline
            Mi_chael Bronze Member @Regis Letowski 0
            @Regis-Letowski-0
            Je n’ai jamais fait attention à la consommation durant la nuit.
            As tu activé la mesure de SpO2 ?
            Regis Letowski 0R 1 Reply Last reply Reply Quote 0
            • M Offline
              @Regis-Letowski-0
                surfboomerang
                6% during the night with Sleep, HR and SpO2 tracking enabled seems reasonable.
                Also keep in mind that the battery drain rate isn’t always linear.
                OnePlus Nord 4
                • SimonS Offline
                  Simon Bronze Member
                  Yeah, I would like to emphasize on what Mi_chael mentioned: The battery indicator is not linear. In my case, the drain seems slow from 100% to around 80% - and gets significantly faster then. Towards the end, it seems to be slower again, but I’m not sure about that bit.
                  S9P Ti - ex Altimax, A3P, SV Ti
                    Regis Letowski 0 @Mi_chael
                    @Mi_chael bonsoir et non je ne l’avais pas activé.
                    Je trouve le fonctionnement de cette montre compliqué,et pas trop d’aide de la part de suunto.
                    As tu un site ou autre pour m’aider à me familiariser ?
                    Merci
                    Cordialement
                    freeheelerF tazidenT 2 Replies Last reply Reply Quote 0
                    • freeheelerF Offline
                      freeheeler @Regis Letowski 0
                      @Regis-Letowski-0
                      try the manual 🙂
                      I’ve tested a polar recently and used a garmin for some years. Suunto watches are relatively easy to operate and getting used to, compared to other watches 🙂
                      I think the menu is clean and clear. if not, please ask, we can help 👍
                      https://www.suunto.com/fr-fr/Assistance/Assistance-produit/suunto_9_peak_pro/suunto_9_peak_pro/widgets/oxygene-sanguin/
                      living sideways
                      • tazidenT Offline
                        taziden Gold Members @Regis Letowski 0
                        @Regis-Letowski-0 bonjour Regis, il faut juger de l’usage de la batterie une fois qu’elle est bien calibrée (il y a besoin de le faire après l’achat, et après chaque mise à jour du logiciel interne, le firmware).
                        Pour ça, il suffit de la laisser se décharger complètement puis de la recharger à 100%.
                        Après ça, l’affichage sera déjà plus fiable. 6% pour la nuit, ça me parait beaucoup.
                        Tu parles aussi de ceinture, tu dors avec une ceinture cardio ou je comprends mal ?
                        S9PP
                          Regis Letowski 0 @freeheeler
                          @freeheeler Ok merci bonne journée
                            Regis Letowski 0
                            @taziden merci pour les conseils. Non je ne dors pas avec la ceinture. La ceinture fonctionne parfaitement. Bonne journée
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
