    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS recording rate
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    10 Posts 4 Posters 1.4k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • renton82R Offline
      renton82 Platinum Member
      I can’t find any informations about GPS recording rate.
      How GOOD and OTIMUM mode work? And how about PERFORMANCE, RESISTENCE and TOUR mode?
      I also don’t see any reference to Fused Track mode.
      Łukasz SzmigielŁ inkognitoI 2 Replies Last reply Reply Quote 0
      • Łukasz SzmigielŁ Offline
        Łukasz Szmigiel @renton82
        @renton82 every mode but tour is using 1s rate. Tour is 1h or when custom lap is pressed. There’s no FusedTrack as endurance now has 1s rate (it’s using fewer satellites compared to performance).
        S9PP 2.50.28
        renton82R 1 Reply Last reply Reply Quote 0
        • renton82R Offline
          renton82 Platinum Member @Łukasz Szmigiel
          So i imagine that “Good” vs “Optimum” in custom GPS mode means “less than 32” vs 32 satellites.
          So, basically, performance uses 32 satellites, 1s, optimum GPS mode, endurance uses “x satellites”, 1s, good GPS mode, and tour uses “x satellites”, 1h, good GPS mode.
          • inkognitoI Offline
            inkognito Platinum Member @renton82
            @renton82 https://www.suunto.com/sports/News-Articles-container-page/why-navigating-with-a-suunto-has-never-been-better/
            @Łukasz-Szmigiel Is it really fewer satellites? Because that site says that endurance uses duty cycle (chip works for half a second and then it is idle for the other half). It doesn’t say anything about decreased number of satellites…
            SV: fingers crossed :D
            S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
            Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
            Despite some pretty bad luck, I still love Suunto!
            renton82R Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 0
            • renton82R Offline
              renton82 Platinum Member @inkognito
              I also read that it can use maximum of 4 GNSS at time, not 5 like i read here https://www.suunto.com/it-it/sports/News-Articles-container-page/why-navigating-with-a-suunto-has-never-been-better/
              isaziI 1 Reply Last reply Reply Quote 0
              • isaziI Online
                isazi Moderator @renton82
                @renton82 it’s 5: GPS, QZSS, Galileo, Glonass, Beidou
                Blog: isazi's home
                  Łukasz Szmigiel @inkognito
                  @inkognito I don’t know. I’m repeating what I’ve learned on this forum. I think that one of the testers mentioned that on endurance it’s using less satellites.
                  Edit
                  This article clearly states that the chip works on half second indeed. And also - it powers on for 2 mins every half hour on tour mode. Interesting.
                  S9PP 2.50.28
                  • renton82R Offline
                    renton82 Platinum Member @isazi
                    @isazi Ok, but I read here https://www.suunto.com/en-us/Products/Sports-Watches/suunto-9-peak-pro/suunto-9-peak-pro-all-black/
                    that it can uses only 4 constellations at time
                    inkognitoI 1 Reply Last reply Reply Quote 1
                      @renton82 Yes, sometimes GPS and QZSS are considered as one system as they are automatically compatible… So, you have GPS+QZSS, GALILEO, GLONASS and BEIDOU which makes 4 or 5 systems depending on your nomenclature…
                      renton82R 1 Reply Last reply Reply Quote 4
                      • renton82R Offline
                        @inkognito Ok, understood!
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
