    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Customize "Run with power"
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    12 Posts 5 Posters 1.0k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • renton82R Offline
      renton82 Platinum Member
      Is it possible to customize data pages of, for example, run with power activity? I can only create custom activity starting with base profile.
      Mff73M 1 Reply Last reply Reply Quote 0
      • Mff73M Offline
        Mff73 @renton82
        @renton82 said in Customize "Run with power":
        not starting from base profile itself : you can “only” create a fresh new own custom mode for one sport/activity. Then change whatever is by default to your own needs.
        Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
        Suunto Vertical all black
        Wife : S9PP
        SA: Always the latest beta :)
        Android 13, Galaxy S205G
        renton82R 1 Reply Last reply Reply Quote 1
        • renton82R Offline
          renton82 Platinum Member @Mff73
          @Mff73 So, if i select “running with power”, i can’t customize data pages…
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @renton82
            @renton82 you start with customizing running. What matters is the sport type, other than that you design the screen as you want (and the starting point is the same for all sports I believe, with the difference of being GPS or indoor sports).
            Watch: Suunto Vertical Ti
            Blog: isazi's home
            renton82R 1 Reply Last reply Reply Quote 0
            • renton82R Offline
              renton82 Platinum Member @isazi
              @isazi Ok, but if i customize “run” for example, i can’t have a page with Distance, heart rate, power and timer like if i would select “run with power” activity like this : IMG_20221108_102720.jpg
              • isaziI Offline
                @renton82 of course you can, go to SA and just create the customized sport you want. I just did the same.
                Blog: isazi's home
                • renton82R Offline
                  @isazi Which data field correspond to one in the middle? 3 sec? 10sec? Average lap power? max power? max lap power? average power?
                  • isaziI Offline
                    @renton82 what you prefer. I would use 3 sec power to have something that changes rapidly.
                    Blog: isazi's home
                    • renton82R Offline
                      @isazi Thank you! I thought that power data fields were for cycling purposes only… So i suppose that default power data field is of curse 3 sec, isn’t it?
                      Dimitrios KanellopoulosD Brad_OlwinB 2 Replies Last reply Reply Quote 0
                        Dimitrios Kanellopoulos Community Manager @renton82
                        @renton82 correct. 3S . Some people also prefer 10s though
                        Creator of Quantified-Self.io
                        youtube.com/c/dimitrioskanellopoulos
                        https://instagram.com/dimitrioskanellopoulos
                        https://www.strava.com/athletes/7586105
                        • renton82R Offline
                          renton82 Platinum Member @Dimitrios Kanellopoulos
                          @Dimitrios-Kanellopoulos Thank you!
                          • Brad_OlwinB Offline
                            Brad_Olwin Moderator @renton82
                            @renton82 You can even select Power as a graph, it works well.
                            Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
