    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Activity abortion
    activity abortion
    31 Posts 9 Posters 4.2k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Mitch9M Away
      Mitch9 Silver Members
      Now it happens unfortunately the second time: The activity aborts without any reasons and my Suunto 9 Baro shows the standard screen. The good thing is that the activity is saved until the stop but not nice anyway.
      Any ideas, solutions or anything else?
      Watch: Suunto Vertical Titanium Solar (Sand)
      SA: Android (beta)
      HRS: Polar H10
      freeheelerF inkognitoI 2 Replies Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @Mitch9
        @Mitch9
        you can always try a soft reset. It happened to me, too. it’s very rare. a firmware update is due, I guess this will solve it.
        but in general, crashes can always happen. We’re lucky that they happen with Suunto very rarely 🙂
        living sideways
        • inkognitoI Offline
          inkognito Platinum Member @Mitch9
          @Mitch9 It happened to me several times, in all those cases I used Route navigation together with some SuuntoPlus app. I truly hope new firmware fixes this…
          SV: fingers crossed :D
          S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
          Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
          Despite some pretty bad luck, I still love Suunto!
          Mitch9M 1 Reply Last reply Reply Quote 2
          • Mitch9M Away
            Mitch9 Silver Members @inkognito
            @inkognito said in Activity abortion:
            Thanks for this hint! In both cases I had the same situation.
            In future I use for important activities not both possibilities and hope for the update.
            SA: Android (beta)
            HRS: Polar H10
            Ivan De RasisI 1 Reply Last reply Reply Quote 1
            • Ivan De RasisI Offline
              Ivan De Rasis @Mitch9
              @Mitch9 mi è accaduto un paio di volte mentre utilizzavo la navigazione e la modalita attiva del controllo della musica…Disabilitando la funzio0ne musica dal 9Baro non ho avuto più arresti
              Suunto 9 Baro
              Suunto Vertical
              Ivan De RasisI Mitch9M 2 Replies Last reply Reply Quote 0
                Ivan De Rasis @Ivan De Rasis
                @Ivan-De-Rasis said in Activity abortion:
                Restiamo sempre in fermento per il nuovo aggiornamento firmware, qualora ci fosse!!!
                Suunto 9 Baro
                Suunto Vertical
                • Mitch9M Away
                  Mitch9 Silver Members @Ivan De Rasis
                  @Ivan-De-Rasis No, the music control is disabled on my watch.
                  SA: Android (beta)
                  HRS: Polar H10
                  • isaziI Offline
                    isazi Moderator
                    If someone reproduces this and send me logs, I’ll open a bug with Suunto.
                    Blog: isazi's home
                    Mitch9M 1 Reply Last reply Reply Quote 0
                    • Mitch9M Away
                      Mitch9 Silver Members @isazi
                      @isazi said in Activity abortion:
                      Reproducing is hard. The first time it happened after 2.2 km, the second time (12 days later) it happens after 25.2 km. Both were running activities. In future I don’t want to loose the data and so don’t activate routing and SuuntoPlus.
                      SA: Android (beta)
                      HRS: Polar H10
                      freeheelerF 1 Reply Last reply Reply Quote 0
                        freeheeler @Mitch9
                        @Mitch9
                        ok, I sacrifice, I’ll do it…
                        any S+, plus route navigation and a bit of bad luck?
                        anything else?
                        if you specify your settings I can set it up as similar as possible. sport mode customization? gnss systems, sensors etc… I think all this can have an affect
                        living sideways
                        inkognitoI 1 Reply Last reply Reply Quote 1
                          inkognito Platinum Member @freeheeler
                          @freeheeler
                          I am sacrificing most of the time. But it usually happens when I am in the middle of 20+ km long route somewhere in the forrests with weak cellphone signal… So I cannot send logs at those moments and I am affraid that logs will be rewritten once I start a new excercise (which I need to do as I do not want to get lost 😄 )
                          I would preferably choose those SuuntoPlus apps that create autolaps (like Climb, it seems to crash more often). But it also crashed with Burner…
                          I only use custom sport modes, it happened during running and hiking. I use fields like distance to the end of route, ETA, ETE…
                          I used GPS + BEIDOU, external HR sensor
                          I don’t think some of these things really matter… I just think that in some rare cases heavier computations coincide (like navigation + suunto plus) and the old S9 processor cannot deal with that… My friends with newer and faster S9P never had these problems with similar setup…
                          I also think that we should probably wait for the new firmware where some SuuntoPlus-related tweaks are expected. That might solve it and we don’t need to struggle 😄
                          freeheelerF EgikaE 3 Replies Last reply Reply Quote 1
                            freeheeler @inkognito
                            @inkognito
                            actually all the same setup like mine… except that I don’t use beidou, I’m on galileo.
                            I’ll check with my next activity, most likely on saturday
                            living sideways
                            • EgikaE Offline
                              Egika Platinum Member @inkognito
                              @inkognito logs don’t need to be sent at the instant of a problem. You can do so a couple of hours later. Just finish your run and when you get back to your home, bike or car, send the logs. They will have everything needed for the engineers to find out what happened in the previous hours.
                              Edit: plus inform someone in Suunto or of the field testers in this forum about the issue and time and account you sent the logs from.
                                @inkognito
                                I didn’t manage yet to crash my waych with S+, turn by turn navigation and external HR connected.
                                living sideways
                                  @freeheeler Well, I use S+ together with navigation several times a week. And I remember like 3-4 crashes out of 100+ activities… That makes it quite rare and hard to reproduce…
                                  freeheelerF 1 Reply Last reply Reply Quote 2
                                    @inkognito
                                    ok, I rarely use navigation… actually only when I do activities where I don’t know the area or when I want to try something new
                                    living sideways
                                    • J Offline
                                      jussim Bronze Member
                                      What a relief to know that I’m not the only who’s had this problem. I was first thinking it might be hardware failing… Good call on it being linked to SuuntoPlus and limited processing power, that just might be it. First I was thinking it might be related to memory storage getting full mid activity (watch somehow failing to delete older activies).
                                      This happened several times to me this summer. I did hard reset and all seemed fine until again couple of weeks ago. Now I have done a soft reset weekly or so and the problem hasn’t reoccurred again. Good to know that there’s the option to send logs in case it happens again.
                                      Waiting for firmware upgrade!
                                      9PP since 09-2025.
                                      J 1 Reply Last reply Reply Quote 0
                                      • J Offline
                                        jussim Bronze Member @jussim
                                        Two km into workout I didn’t hear beep for a lap where I expected it and fucking hell, I was greeted with a dreaded arrow pointing down. At least I managed to reset the device. Seems like rebooting the watch three days ago didn’t do anything to prevent this from happening. I did change from GPS+BeiDou to GPS+GLONASS some weeks ago, could it have anything to do with it? Also SuuntoPlus Burner was in use. Maybe I’ll stop using SuuntoPlus functionalities next and see what happens.
                                        Is the debug data lost when you start a new activity? I’ve sent log 1121341147474400 in any case.
                                        9PP since 09-2025.
                                        isaziI J 2 Replies Last reply Reply Quote 1
                                        • isaziI Offline
                                          isazi Moderator @jussim
                                          @jussim the watch getting into such issues during activity is quite unexpected though, if your watch is still under warranty I would contact support.
                                          Blog: isazi's home
                                          • J Offline
                                            jussim Bronze Member @isazi
                                            @isazi I did just that the last summer after this happened more than once. It was all kinds of useless endeavour, when all they had to offer was to advice to restore firmware to factory defaults.
                                            Maybe I should contact them again about servicing, but I’d rather give the new firmware a chance. It’s just too much of a hassle to get the watch sent for inspection, not to mention being without it for a while.
                                            9PP since 09-2025.
                                            isaziI 1 Reply Last reply Reply Quote 0
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
