Reboot when checking alti/,baro?
@isazi Thank you! If you’d like, I can send the log from my wife’s S9P too. Unfortunately, the problem only happens sometimes. As I tried over and over again, the watch restarted about 4 times. The fifth reset was already hard and the watch reset to factory settings. Then it seemed fine for a while. But after a few tries, the watch got stuck again.
@Pavlas no more logs should be necessary for this. As for the hard reset, I think that if the watch detects a series of soft resets it assumes something is wrong with the firmware and performs a hard reset.
@isazi I have suffered that issue some times, it’s very reproducible (S9P).
The issue happens when you switch from the watch screen to the alti-baro screen very fast touching the down buttom switching screens.
It seems like if you don’t let the heartrate screen and data appear comepletely and switch to another screen very fast the watch get stuck and reboots (soft reboot but you lose alti/barometer and heartrate info graphs) -
@jjpaz there should be a fix for that in next firmware, thanks to people that sent logs.
Register Login
