    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Reboot when checking alti/,baro?
    Scheduled Pinned Locked Moved Suunto 9 Peak
    24 Posts 10 Posters 2.9k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • mikekoski490M Offline
      mikekoski490 Bronze Member
      Just bought a new SP9 and every time I scroll to check the baro graph the screen goes blank and the watch reboots. I’ve only had it 2 days and it’s wiped my sleep and recovery data both times to 'no information ’ basically. Should I return it?
      Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
      Current: Suunto Race Ti
      Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
      Suunto App running on Google Pixel 8/Android 14
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @mikekoski490
        @mikekoski490 I assume you have updated to the latest firmware and had a GPS fix?
        Vector/T6c/Vertical 2 Ti
        mikekoski490M 2 Replies Last reply Reply Quote 0
          mikekoski490 Bronze Member @Brad_Olwin
          @brad_olwin Yes. All updated to most current. Suunto support said to do a hard reset, which I did. Worked ok checking a few times, and now just tried it again and screen went blank and it deleted the alti/baro history graphs.
            @brad_olwin Yes. All updated to most current. Suunto support said to do a hard reset, which I did. Worked ok checking a few times, and now just tried it again and screen went blank and it deleted the alti/baro history graphs. It’s when I’m scrolling right. As I continue scrolling past baro to get to the alti screen again, watch goes blank and reboots.
              @mikekoski490 I would contact support again, there is something wrong with the watch.
              • babychaiB Offline
                babychai Silver Members
                Sometimes happened to my watch S9P too. watch will reboot when see Baro graph
                Suunto Vertical Black Ruby (S/S)
                S̶u̶u̶n̶t̶o̶ ̶V̶e̶r̶t̶i̶c̶a̶l̶ ̶A̶l̶l̶ ̶B̶l̶a̶c̶k̶
                Suunto 9 Peak All Black
                Suunto Spartan Trainer Wrist HR (Black)
                thanasisT PavlasP D 3 Replies Last reply Reply Quote 0
                • thanasisT Offline
                  thanasis Bronze Member @babychai
                  @babychai the bar graph indeed does that to me also
                  . Another similar thing that happens to my watch is the following:
                  1. setting the watch in energy saving mode
                  2. move the screens to altimeter/barometer
                  3. set-correct the altitude manually
                  the watch reboots
                  • isaziI Offline
                    isazi Moderator
                    This should not happen (it happened at some point during testing and was fixed). If it happens, can you please sync your watch (immediately after) and send logs? And then send me a message?
                    In this way we can send it to the developers.
                    It never happened to me on my production watch.
                    Blog: isazi's home
                    mikekoski490M babychaiB L jjpazJ 4 Replies Last reply Reply Quote 0
                    • PavlasP Offline
                      Pavlas @babychai
                      @babychai My wife has the same problem with the S9P. Sometimes.
                      🔺Vertical All Black
                      ex:
                      Ambit2 Black
                      Ambit3 Peak Sapphire
                      Spartan Ultra Stealth Titanium
                      S9B All Black
                      Ocean All Black (for testing only)
                      >>> YouTube Channel <<<
                        mikekoski490 Bronze Member @isazi
                        @isazi Sure. Let me know how I can do that lol.
                        freeheelerF 1 Reply Last reply Reply Quote 0
                        • freeheelerF Offline
                          freeheeler @mikekoski490
                          @mikekoski490
                          sync immediately is self explanatory 😉
                          for android (?): after sync, go to the watch icon in SA, press the 3 dots and then select “send logs to Suunto”… then private message with your email adress mentioned that is connected to SA account and the time (and timezone) your logs have been sent 👍 🙂
                          living sideways
                          • D Offline
                            DF130 Bronze Member @babychai
                            @babychai My S9P has become moody as well recently, crashed twice in the middle of a run (had done a soft reset after the first time), then one day (or night rather 😳) when looking at resources - but that was exactly at midnight, so maybe a bit of a corner case…
                            • babychaiB Offline
                              babychai Silver Members @isazi
                              @isazi Hi, please check your message. My S9P reboot again just now. thanks.
                              • L Offline
                                LaurA 0 @isazi
                                @isazi I have exactly the same issue. New watch that unfortunately reboots on various occasions. Also sleep tracking is not working so my guess is that the watch also reboots at some point during the night?
                                isaziI 1 Reply Last reply Reply Quote 1
                                • isaziI Offline
                                  isazi Moderator @LaurA 0
                                  @LaurA-0 it could be, but if your watch reboots this often it is a good idea to call support, because there may be something wrong with the watch itself. Mine never rebooted.
                                  Blog: isazi's home
                                  mikekoski490M 1 Reply Last reply Reply Quote 0
                                    @isazi I talked to Suunto Support. They told me to either return it or send to Suunto for repairs with about a 3-4 week turn around. 😞
                                    PavlasP 1 Reply Last reply Reply Quote 0
                                    • PavlasP Offline
                                      Pavlas @mikekoski490
                                      @mikekoski490 I’m convinced it’s a software bug. When I get back from vacation, I’ll write the details 😄
                                      🔺Vertical All Black
                                      ex:
                                      Ambit2 Black
                                      S9B All Black
                                      >>> YouTube Channel <<<
                                        Brad_Olwin Moderator @Pavlas
                                        @Pavlas said in Reboot when checking alti/,baro?:
                                        Except that I have two S9P models and never had this happen. It may require something unusual to be set in the watch.
                                        • PavlasP Offline
                                          Pavlas @Brad_Olwin
                                          @Brad_Olwin I tried it on my wife’s S9P and this is what I noticed:
                                          I have the watch on my wrist, the HR sensor is active.
                                          1. I scroll down to the altitude screen.
                                          2. I switch to the next screen with an altitude graph
                                          3. I switch to the next screen with the pressure graph
                                          4. I switch to the first altitude screen and this is where the watch gets stuck. A soft reset takes place.
                                          If I put the watch on the table and the HR sensor is not active, the watch is not stuck.
                                          Unfortunately even so the watch freezes not every time.
                                          🔺Vertical All Black
                                          ex:
                                          Ambit2 Black
                                          S9B All Black
                                          >>> YouTube Channel <<<
                                          isaziI 1 Reply Last reply Reply Quote 0
                                          • isaziI Offline
                                            isazi Moderator @Pavlas
                                            @Pavlas I reported this to Suunto, thanks to all people that sent logs, and a fix is planned. Still, it never happened to me, so it may be something that affects some watches (or watch configurations) and not others.
                                            Blog: isazi's home
                                            PavlasP 1 Reply Last reply Reply Quote 1
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
