    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Pas de son avec la montre
    Scheduled Pinned Locked Moved Suunto 7
    19 Posts 5 Posters 1.9k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Poppy GuyP Offline
      Poppy Guy
      Bonjour,
      Quand je démarre une activité, je n’ai pas de son, et aussi à chaque km non plus.
      Que faut-il faire ?
      Jamie BGJ freeheelerF 2 Replies Last reply Reply Quote 0
      • Jamie BGJ Offline
        Jamie BG Bronze Member @Poppy Guy
        @poppy-guy said in Pas de son avec la montre:
        Que faut-il faire ?
        What do you mean? No beep? Are you expecting the watch to say something as it has no speaker - you would have to connect a bluetooth headset? A little bit more detail would be appreciated to understand exactly what the issue is.
        • freeheelerF Offline
          freeheeler @Poppy Guy
          @poppy-guy
          maybe do not disturb is activated or system sounds are off?
          living sideways
          Poppy GuyP 1 Reply Last reply Reply Quote 0
            Poppy Guy @freeheeler
            @freeheeler
            Si le son système est désactivé, comment l’activé ?
            E 1 Reply Last reply Reply Quote 1
            • E Offline
              el2thek Bronze Member @Poppy Guy
              @poppy-guy https://www.suunto.com/fy-nl/Support/Product-support/suunto_7/suunto_7/sports-by-suunto/exercise-options/
              Poppy GuyP 1 Reply Last reply Reply Quote 1
                Poppy Guy @el2thek
                @el2thek
                freeheelerF 1 Reply Last reply Reply Quote 0
                  @poppy-guy
                  that’s the manual to explain how to setup notification sounds 🙂
                  living sideways
                    @freeheeler
                    Désolé, mais je ne vois pas 😞
                      @poppy-guy
                      dans l’horologe ou ici?
                      living sideways
                        @freeheeler
                        Tout est grisé, et pourtant, je n’ai pas activé “ne pas dérangé”
                          @poppy-guy
                          living sideways
                            @freeheeler
                            text alternatif
                            text alternatif
                            KajkomK 1 Reply Last reply Reply Quote 0
                            • KajkomK Offline
                              Kajkom @Poppy Guy
                              @poppy-guy
                              Hello
                              it is similar for me, but it applies to laps entered manually with the LAB button.
                              I will pick up my thread as a common interest
                              error!
                              https://forum.suunto.com/topic/7952/manual-constraints-no-sound/2?_=1657275002425
                                Poppy Guy @Kajkom
                                Je pense que je vais réinitialiser ma montre ?
                                  Poppy Guy @Poppy Guy
                                  @poppy-guy
                                  Après avoir réinitialisé ma montre, les indications ne sont plus grisées, et ça fonctionne.
                                  Par contre je ne peux pas avoir l’application “Sunnto” sur mon téléphone “LG g3” apparemment, il n’est pas compatible, je suis sous Android 5.0
                                  • KajkomK Offline
                                    Kajkom @Poppy Guy
                                    @poppy-guy did I do a soft or hard reset?
                                      Poppy Guy @Kajkom
                                      @kajkom
                                      Je ne sais pas si c’est soft ou hard, j’ai tout simplement remis ma montre aux réglages d’origine d’usine.
                                      freeheelerF 1 Reply Last reply Reply Quote 1
                                        @poppy-guy
                                        c’est une hard reset…
                                        hope it doesn’t happen again ✊
                                        living sideways
                                          @freeheeler
                                          Merci pour toutes ces réponses qui mon bien aidées👍
                                          Register Login
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
