    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 peak GPS accuracy with slow move
    Scheduled Pinned Locked Moved Suunto 9 Peak
    11 Posts 5 Posters 1.7k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • V Offline
      vietpq Bronze Member
      My S9 Peak GPS works fine on the road. But when I do trail running in the mountains (slow pace), the GPS seems inaccurate, my watch always has a longer number of kilometers than my companion. Last Sunday, my watch was 36.6km while my 2 friends’ watches were only 34km (they use Garmin 945). This problem always happen to my watch when I go for trail run
      FW: 2.20.30
      GPS system: GPS+QZSS + GLONASS
      The activity link: https://maps.suunto.com/move/vietpham70/62bfeb36e1e180504fcb201e
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @vietpq
        @vietpq You are selecting Run, not Trail Run as a sport mode. They are different for GPS and 3D distance. Which is correct? Why do you assume the 945 is accurate?
        Vector/T6c/Vertical 2 Ti
        V 1 Reply Last reply Reply Quote 1
        • V Offline
          vietpq Bronze Member @Brad_Olwin
          @brad_olwin I’m sure the 945 is more accurate because the tracklog is much smoother and snap to the road than my S9P
            @vietpq said in S9 peak GPS accuracy with slow move:
            That does not imply accuracy. Not so easy to measure and I doubt that smoothing enhances accuracy, likely the opposite. As I stated before, you should select Trail Run not Run for the trail, they are different.
            I have run many slow mountain events with the S9Peak and the Epix2 at the same time (which has much better GPS tracking than the 945 as it has a newer chip) and both agree nearly exactly on distance. This includes two ultra races. I can share data with you if you like.
            V 1 Reply Last reply Reply Quote 2
            • A Offline
              ActiveJiggy
              Roads are often in different places than the location shown on maps.
              • V Offline
                @brad_olwin said in S9 peak GPS accuracy with slow move:
                Thank you, next time I will try trail run mode instead of run mode. Do you know exactly what is difference between trail run and run mode?
                Mff73M 1 Reply Last reply Reply Quote 1
                • Mff73M Offline
                  Mff73 @vietpq
                  @vietpq
                  3D distance surely (hopefully ?) πŸ™‚
                  Meaning, if you climb/run a hill, distance is not just horizontal (pure position on map) but with ascent part. In a theorical 45Β° slope, distance really done is around 40% higher than just horizontal (it is a old greek knowledge from Pythagore) πŸ™‚
                  SSU (retired), SV1, SV2
                  Wife : S9PP
                  SA: Always the latest beta :)
                  Android + Galaxy S205G
                  Brad_OlwinB V 2 Replies Last reply Reply Quote 2
                    Brad_Olwin Moderator @Mff73
                    @mff73 said in S9 peak GPS accuracy with slow move:
                    @vietpq
                    Well stated!
                    • ? Offline
                      A Former User @ActiveJiggy
                      @activejiggy said in S9 peak GPS accuracy with slow move:
                      you may be affected by this https://www.dcrainmaker.com/2022/07/gps-accuracy-issue-impacted-garmin-suunto-and-polar-watches-over-past-week.html?fbclid=IwAR15NFpgy_4zo-yraZsk2J7elt62G5g9Bc-hOhTS1DksllUo0SlRt50oMZE
                      • V Offline
                        vietpq Bronze Member @Mff73
                        I have contacted to suunto and they said me:
                        β€œ1. When I run with my Suunto 9 Peak does it measure 3D or 2D distance?”
                        Answer: Our watches do calculate 3D distance outdoors based on altitude changes.
                        β€œ2. Is there a difference between trail run mode and run mode about the way the watch records GPS data?”
                        Answer: There is no difference in the GPS signal the watch sends and/or receives the same data
                        @vietpq
                        Brad_OlwinB 1 Reply Last reply Reply Quote 1
                          @vietpq Others can comment on this as something may have changed but, my understanding was trail run calculates 3D and running does not. I think hiking was not calculating 3D but believe that has been changed as well.
                          No matter, as I stated before I have 4 months of running mountains with Garmin Epix2 on one arm and a Suunto 9Peak on the other. You cannot tell the difference between them easily nor is there any statistical difference in the distance or elevation data.
                          With your input, this post could be even better πŸ’—
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
