    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Calories very low during workouts
    28 Posts 7 Posters 3.7k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      be1t0n Bronze Member
      My Suunto 9 Baro has started acting strangely when calculating calories, and only registering around 1/3 of what it used to. As an example today I tracked a workout on Zwift for 30 mins whilst tracking HR using a wahoo Tickr 2 linked to my watch and to the wahoo app.
      Wahoo app = 346 cals (consistent with previous workouts)
      Suunto 9 = 96 cals
      I also tried a workout using the strap linked to wahoo and wrist HR on the watch and had a big difference between results again.
      I’ve tried a soft reset on the watch and it’s not made a difference.
      Does anyone have any suggestions?
      • Brad_OlwinB Offline
        Brad_Olwin Moderator
        @be1t0n Check the zones settings and if using OHR make sure it is realistic. It seems the HR values may be off.
        Vector/T6c/Vertical 2 Ti
        B 1 Reply Last reply Reply Quote 0
        • B Offline
          be1t0n Bronze Member @Brad_Olwin
          @brad_olwin Bingo. For some reason my resting heart rate and zone values had changed from where they were set previously. Resting heart rate was set to 155bpm
          Brad_OlwinB ? 2 Replies Last reply Reply Quote 1
            Brad_Olwin Moderator @be1t0n
            @be1t0n said in Calories very low during workouts:
            Glad it is not that high! Good that it is fixed too,
            • ? Offline
              A Former User @be1t0n
              I guess you’re a little agitated…
              • Piotr GrygielP Offline
                Piotr Grygiel
                No comment…Przechwytywanie zawartości sieci Web_27-5-2022_85739_quantified-self.io.jpeg
                Suunto Race 2
                Google Pixel 8 pro
                freeheelerF 1 Reply Last reply Reply Quote 0
                • freeheelerF Offline
                  freeheeler @Piotr Grygiel
                  @piotr-grygiel
                  what type of HR measurement device did you use?
                  living sideways
                  Piotr GrygielP 1 Reply Last reply Reply Quote 0
                    Piotr Grygiel @freeheeler
                    @freeheeler SUUNTO SMART HEART RATE BELT
                    Suunto Race 2
                    Google Pixel 8 pro
                      @piotr-grygiel
                      could you please share the HR graph and some more info, too? this could help to find the issue
                      living sideways
                        Suunto Race 2
                        Google Pixel 8 pro
                          @piotr-grygiel
                          looks a bit noisy at first but 0% in any zone… are your previous records of swimming similar?
                          living sideways
                            @freeheeler 2022-05-18:
                            2022-06-01:
                            Suunto Race 2
                            Google Pixel 8 pro
                            freeheelerF Brad_OlwinB 2 Replies Last reply Reply Quote 0
                              @piotr-grygiel
                              did you try a soft reset on the watch already?
                              living sideways
                                Brad_Olwin Moderator @Piotr Grygiel
                                @piotr-grygiel What are the HR zone settings on your watch and what are the max and min HR?
                                  freeheeler @Brad_Olwin
                                  @brad_olwin
                                  I’m wondering if the weight has shifted for some reason. If settings are maybe on ultra light, the consumed energy could be that low… but this wouldn’t explain the empty bar graphic
                                  living sideways
                                    @freeheeler Yes. I am going to do hard reset.
                                    It is not easy without a backup of your training settings.😠
                                    Suunto Race 2
                                    Google Pixel 8 pro
                                      @piotr-grygiel
                                      I know, setting up sport modes can be a pain…
                                      before you do a hard reset, could you please try a soft reset and check your settings?
                                      my wife recently had problems getting HR values with her S7, but a restart of the watch solved it.
                                      living sideways
                                        @freeheeler I did this. No effect…
                                        Suunto Race 2
                                        Google Pixel 8 pro
                                          @piotr-grygiel Can you answer my questions about how you have HR zones set in the watch? I don’t want you to hard reset until you have to. Do you have specialized zones set up for running and cycling? Do you have zones set up for general? All of this is in the watch not the app.
                                          Piotr GrygielP 1 Reply Last reply Reply Quote 1
                                            Piotr Grygiel @Brad_Olwin
                                            @brad_olwin HR zones: 170-148-139-131-122
                                            Hard reset done. On Monday I’m going for a swim and see if the reset has helped.
                                            Suunto Race 2
                                            Google Pixel 8 pro
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
