    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery issues
    Scheduled Pinned Locked Moved Suunto 7
    4 Posts 3 Posters 378 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Hi, I started having battery issues recently. From time to time battery gets drained pretty fast - I usually charge it to 100% before going to sleep and in the morning it’s around ~90%, but when there are issues, it can get as low as 60-70%. Same goes throughout the day, it just drains faster (approximately double from usual).
      After restarting the watch, it is again fine for few days.
      I checked Battery stats in WearOS app and there are no apps which are draining it. Not sure if it is usual, but total % used of all apps listed there is lower than the % drained from battery. For example, now I have 55% left and listed apps used only 31%.
      Any ideas?
      BinoWorld UKB 1 Reply Last reply Reply Quote 0
      • ? Offline
        A Former User
        keep your phone close to the watch, maybe the s7 use less battery keeping bt conenction
        • BinoWorld UKB Offline
          BinoWorld UK Bronze Member @Guest
          @metalmi during sleep make sure that your screen is on theatre or cinema mode & Air plane mode
          Also, try restarting your phone and watch together.
          Sometimes the S7 give better battery performance when not fully charged. Unplugged at 80% and see how it behaves. If the drop is slower it might then need couple of charges between 30% and 80%
          Just try and report back.
          • ? Offline
            A Former User @Guest
            @r-s-0 said in Battery issues:
            99% of the time it’s <1m away
            @binoworld-uk said in Battery issues:
            Thanks, I will try, but like I said, even like this it is fine for few days before it starts to drain.
            • First post
              Last post
            Suunto Terms | Privacy Policy
