Pace field does not show when climb slower than 30min/km
I am using S9P with latest fw (2.19.42). When I do floor climb, if the pace is slower than 30min/km the pace data field on the watch does not show the pace. If I try to climb faster and the pace is under 30min/km, the pace value is display back.
Please help. -
It’s normal right?
GPS has the limitation,it cannot get you the true real time speed, -
@vietpq Have you tried the field “vertical speed” or suuntoplus CLIMB application? That would be more meaningful for the sport you are doing …
@vietpq that is correct speeds lower I think than 40mins/km are shown as –
@fluca for floor climb, vertical speed makes no sense because when climb up and down in a short time, the value is zero.
@dimitrios-kanellopoulos said in Pace field does not show when climb slower than 30min/km:
For me it shows as “–” when lower than 30mins/km. Thank you!
NGP (Normalized graded pace) would be a nice addition as a data field during an activity :-)) If this is even possible …
@simon said in Pace field does not show when climb slower than 30min/km:
You can get this if you use TrainingPeaks Run SuuntoPlus
Register Login
