    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 Screen Burn-In
    Scheduled Pinned Locked Moved Suunto 7
    14 Posts 7 Posters 7.4k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Very noticeable ghosting issues on S7 in less than 14 months of use… 👎
      I almost not use with the screen on, when the screen is ON is always set to the Auto Min-Level.
      Anyone tried the “magic” apps from Google Play that promise reduce this?
      macdavM 1 Reply Last reply Reply Quote 1
      • macdavM Offline
        macdav Bronze Member @Guest
        @flypg had the same problem. Sent it to the shop and they changed the screen
        • ? Offline
          A Former User @macdav
          @macdav under warranty or at your cost?
          macdavM 1 Reply Last reply Reply Quote 0
          • macdavM Offline
            @flypg under warranty
            • T tonyg42 referenced this topic on
            • ? Offline
              A Former User
              On the S7 under Developer options > Wear developer options you can find a setting: Force display burn-in protection
              This comes disabled, I enabled, I don’t know how work but looks that this could help 🤞
              This setting change it again to “disabled” after next reboot.
              • cedric13C Offline
                cedric13
                Oh no my Suunto7 screen is totally burned !
                the 2 years of warranty are timeout !
                And the tips don’t work at all 😥
                • “Force display burn-in protection” in developer option
                • application “Wear LCD Ghost Remove” don’t do anything
                cedric13C ? Anthony Passafiume IIIA 3 Replies Last reply Reply Quote 1
                • cedric13C Offline
                  cedric13 @cedric13
                  Is someone know the price to repair it ?
                  • ? Offline
                    A Former User @cedric13
                    @cedric13 yes, the “force…” it’s for new displays and “maybe” helps. This is permanent and the only avaible fix is change the screen to get back this in… 2 years? Forget it and enjoy your S7 😁
                    No idea about price, but you can try sending a email to Suunto Support.
                    For me the main problem with this is that the SWA text contrast don’t help to mitigate the problem, because the for example the custom sport mode is light grey and be very difficult to read in some situations, more when we are on moving. On your case, Course à pied it’s not the more important info to select your activity, this is CAP, and is mixed with the ghosting background.
                    Some time ago I suggested this thread that could help a lot with this problem, only if inverting the colours of Sport Mode/Custom Sport Mode.
                    • macdavM Offline
                      @flypg had the same. Before 1 year changed me the screen, now the same problem - after waranty :-(.
                      I bought S9P
                      ? 1 Reply Last reply Reply Quote 1
                      • ? Offline
                        @macdav yes, sadly it’s normal. Also the SWA interface don’t helps to delay this because it’s too bright and white. Maybe a very dark interface could delay a lot this behavior.
                        • System referenced this topic on
                        • Anthony Passafiume IIIA Offline
                          Anthony Passafiume III @cedric13
                          @cedric13 said in Suunto 7 Screen Burn-In:
                          I have the same problem. Has anybody figured out how to fix it?
                          sartoricS 1 Reply Last reply Reply Quote 0
                          • sartoricS Offline
                            sartoric Moderator @Anthony Passafiume III
                            @Anthony-Passafiume-III
                            Contact Suunto support
                            SVTS - 2.50.28
                            SSSWHR BARO Amber - 2.8.32
                            Samsung A5 2016 - Android 7.0
                            Suunto App Android 6.7.12 beta
                            Suunto App IOs 3.8.0 (21526) beta on MBP M1 Max
                            D 1 Reply Last reply Reply Quote 1
                            • D Offline
                              digivon @sartoric
                              @sartoric This is the way. I cracked the crystal on my out of warranty watch and they replaced it for free.
                              David SilvertandD 1 Reply Last reply Reply Quote 1
                              • David SilvertandD Offline
                                David Silvertand @digivon
                                I had the same problem after approx 18 months of usage, screen burnt in and was getting hard to read out with white/light backgrounds. Like some other contributors, I do not use a lot the screen during my activities (screen off 95% of the time).
                                Suunto reparied/replaced the screen during warranty end of 2022.
                                However, the screen has again burnt in and again the watch starts to be quite unusefull… i think it’s more of a design problem and the choice of this amoled screen seems not to correspond to the high Suunto standards…(I own also a Suunto Core from the nineties…yes last millenium, which still operates perfectly).
                                I’m thinking chaning the watch, still I lost some confidence in Suunto flawless quality, and have some doubts on amoled technology.
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
