    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Download offline map problem
    Scheduled Pinned Locked Moved Suunto 7
    29 Posts 9 Posters 4.0k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Just recently, my S7 started to behave oddly. As soon as I select an offline local map area, it starts downloading while charging and when it reaches 100% it starts again. Moreover after quite a while it stops with the warning that it stopped because there was no connection (there was, of course). Any idea what’s going on?
      ? ? 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @Guest
        I don’t have this behavior with the maps but yes with the connection. A lot of times the S7 tell me that don’t have connection to update maps, apps, etc, but is already connected via BT to the SA correctly and I can sync and edit Sport Modes normally. These behaviors are not solved restaring the S7, but after a while (maybe few hours) comes to work normally. Even in some rare cases the S7 tell me that is not connected via BT when it’s already connected to the SA via BT and working normally, but for the S7 no connection is active.
        olymayO 1 Reply Last reply Reply Quote 0
        • olymayO Offline
          olymay Gold Members @Guest
          @flypg said in Download offline map problem:
          My understanding is the S7 will only update maps etc when connected to WiFi. Putting it on charge is the easiest way to force it into WiFi and this is when it typically does it’s downloads and updates etc.
          As for the issue that @G-Q is having, that is not something I have seen. I have only used custom map areas a couple of times (I normally use the default map area and it is plenty big enough) but when I did it worked fine.
          Maybe a restart? Or even a full reset?
          Suunto 7 Graphite Copper
          Suunto App Beta (Android - Pixel 6 Pro)
          • ? Offline
            A Former User @olymay
            @olymay My understanding is the S7 will only update maps etc when connected to WiFi. Putting it on charge is the easiest way to force it into WiFi and this is when it typically does it’s downloads and updates etc.
            No, you can connect via BT to your mobile and the mobile connected to the WiFi. I do on this way because I have only available 5Ghz connection at office. Also the behavior that I detailled is with the WiFi OFF and BT ON connected to the mobile.
            • ? Offline
              @olymay said in Download offline map problem:
              both already tried with no luck 😞
              • olymayO Offline
                I didn’t know that. My S7 only downloads maps when on charge and connected to WiFi, it has never done so when connected to my phone.
                • ? Offline
                  @olymay You can try, yes, you need to put the S7 to charge, but with only connected via BT to your mobile and your mobile via WiFi it’s OK for maps update and others (Google Play apps updates, etc), this mean, you don’t need to connect the S7 directly to WiFi.
                  • olymayO Offline
                    Ah, ok, so the watch still needs to go on charge.
                    But if the watch is on charge and connected via Bluetooth to the phone which is in turn connected to the WiFi, why not just connect the watch directly to the WiFi?
                    Bluetooth is fine for notifications etc, but is painfully slow for actual data transfer. A WiFi connection would be significantly faster and isn’t any more power hungry (moot point anyway as the watch is on it’s charger).
                    • ? Offline
                      @olymay why not just connect the watch directly to the WiFi?
                      Mainly, as I mentioned above, because I not have available 2.4Ghz WiFi. Even WiFi drain more battery and update speed is not matter during charge process because take few seconds only for maps and no more than 3 minutes when also apps are updated. The S7 is plugged to the charger for a minimum of 20-30’, what no represent a problem.
                      • olymayO Offline
                        @flypg Fair enough, each to their own.
                        One potential issue with using Bluetooth instead of WiFi whilst charging is that the pone must stay near the watch whilst updates take place. Map files are pretty speedy, apps are getting more bloated and take longer and longer all the time. However if you were to do a system update this way you could be waiting a considerable amount of time (although sadly I don’t think will be a problem any longer as I believe the S7 has been dropped).
                        But each to their own 🙂
                        • ? Offline
                          Yes, logically each one depends on its own range of use. For FW updates or big Playlist of music I connect to WiFi.
                          @olymay (although sadly I don’t think will be a problem any longer as I believe the S7 has been dropped)
                          I hope you’re wrong! 😥 😂
                          • ? Offline
                            @g-q mine stops at 45% downloading. Almost a week now cant get maps into watch.
                            • ? Offline
                              @r-s-0 yes, even on Reddit there are users who complain about it. I just hope Suunto doesn’t leave this watch at the mercy of our wrists.
                              • ? Offline
                                @r-s-0 said in Download offline map problem:
                                I had the same problem few weeks back. I solved by shutting down S7 and mobile, turned on again and worked. You tried this?
                                ? Piotr PientkaP 2 Replies Last reply Reply Quote 0
                                • ? Offline
                                  @flypg will try! thanks. btw I can scroll from my city to another city on the S7 and see every street on the map while having the watch offline. Is this why downloads takes so long time? It’s supposed to be an area of no more than 30km I think. I have hundreds of kms
                                  • isaziI Offline
                                    isazi Moderator
                                    Suunto is investigating the issue.
                                    Blog: isazi's home
                                    ? 1 Reply Last reply Reply Quote 3
                                    • ? Offline
                                      A Former User @isazi
                                      @isazi good news, tx!
                                      • T Offline
                                        tonyg42
                                        Same problem for me. Watch is in charge and connected to Wi-Fi, and since week, maps download is interrupted without any reason.
                                        • olymayO Offline
                                          olymay Gold Members
                                          Maybe try a smaller map size to see if that makes a difference?
                                          I have left mine on the default size and do not have any custom map areas and it downloads just fine.
                                          Maybe larger map files are having issues?
                                          • ? Offline
                                            alas nope
                                            probably but who knows
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
