    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak maximum battery life
    Scheduled Pinned Locked Moved Suunto 9 Peak
    54 Posts 13 Posters 11.1k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      loopylou72 @Brad_Olwin
      @Brad_Olwin
      Hi can you set a custom battery mode on the Peak 9? The manual says you can but I read somewhere else that you can only do it on the 9 and I can’t see an option in the app. Thanks!
      surfboomerangS Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @loopylou72
        @loopylou72
        There’s no need to add multiple replies, to quote multiple people
        @loopylou72 said in Suunto 9 Peak maximum battery life:
        It’s your best friend, so, if it says you can … I bet you can 😁
        https://www.suunto.com/Support/Product-support/suunto_9_peak/suunto_9_peak/features/recording-an-exercise/#1.4
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.7.12 beta
        L 1 Reply Last reply Reply Quote 0
        • surfboomerangS Offline
          surfboomerang @loopylou72
          @loopylou72 I can confirm that this is possible. Same options as for the S9B.
          Custom battery mode is set in the watch. Not in the app.
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          • L Offline
            loopylou72 @sartoric
            @sartoric
            yep I replied to the wrong person but couldn’t delete my first comment as I am a ‘new user’
            • L Offline
              loopylou72 @surfboomerang
              @surfboomerang thanks I found it 🙂
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @loopylou72
                @loopylou72 Sorry, I was out using my Suunto and had no internet access for a couple days.
                Vector/T6c/Vertical 2 Ti
                L 1 Reply Last reply Reply Quote 3
                • L Offline
                  @Brad_Olwin looks nice! My watch died on my 30hr run. I had changed the settings but still had the best GPS. For future reference, if using the ‘good’ GPS what is the impact of this on distance/pace accuracy?
                  babychaiB 1 Reply Last reply Reply Quote 0
                  • babychaiB Offline
                    babychai Silver Members @loopylou72
                    @loopylou72 are you using Best GPS to achieve 30 hours? What is your watch settings?
                    Suunto Vertical Black Ruby (S/S)
                    S̶u̶u̶n̶t̶o̶ ̶V̶e̶r̶t̶i̶c̶a̶l̶ ̶A̶l̶l̶ ̶B̶l̶a̶c̶k̶
                    Suunto 9 Peak All Black
                    Suunto Spartan Trainer Wrist HR (Black)
                    • L Offline
                      loopylou72 @babychai
                      @babychai
                      Yes best gps
                      Screen saver on
                      Screen brightness low
                      I had turned autolap off but in the race it was on, I think because I changed the settings in the normal battery mode and later switched to manual battery to enable the screen saver/screen time-out not realising this would affect the general settings I’d set up so this may have drained more battery… the watch suggested switching to endurance mode as it ran low but still died. If I’d just used endurance mode I was worried it would affect my other data ie pace, distance, elevation?
                      babychaiB Brad_OlwinB 2 Replies Last reply Reply Quote 0
                      • babychaiB Offline
                        @loopylou72 not sure about the elevation but the distance will show much much longer distance
                          @loopylou72 Endurance mode affects pace a bit but not enough to worry about in a 30h race. Autolap definitely reduces battery life. I doubt I can get 30h in Performance mode even using the custom settings you did. I would switch to Endurance mode or start out that way. I have a ~30h race coming up and I will use Endurance mode on the S9P. Endurance will not affect distance much if at all due to FusedTrack, which is amazing.
                          L 2 Replies Last reply Reply Quote 1
                          • L Offline
                            @Brad_Olwin I got 30hrs with my suunto 9 baro in a different race but slightly different settings, could turn screen save on in the activity abd auto laps off. Adding a lot of extra distance does make a difference if you are aiming for a particular average pace… I’ll try endurance mode in training and see how much it affects other data!
                            • L Offline
                              @Brad_Olwin I ran 5km with endurance mode and the GPS line on strava cut all the curves and gave me PRs I hadn’t run. I wouldn’t want this in a race! However the overall distance/time seemed correct… needs more testing on longer runs I have done before ot compare.
                              babychaiB 1 Reply Last reply Reply Quote 1
                              • babychaiB Offline
                                @loopylou72 Thanks for sharing your result. I think this is Opportunity Cost that we need to expect when we choose lesser accuracy mode. If still able to maintain distance, elevation and pace similar with Performance mode this is really super amazing in my opinion.
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
