S9Peak with Suunto HR SmartSensor Also Failed
@margusl said in S9Peak with Suunto HR SmartSensor Also Failed:
Whatever that issue was, seems that it started around 3.6km / minute 22 and looks like you also stopped there. Do you remember why or what did you do at that point? Added / removed layers, adjusted the HRM belt or something like that?
Thank you v much for taking a closer look at this
very much appreciated.
Looking at the map; at 22mins I stopped to cross a road, a small crossing so I don’t think I paused the watch (which I do if I am waiting for lights to alert me to cross), definitely no adjustments to belt or any layers added or removed, this activity was undertaken by using the Brand New Suunto SmartSensor Belt / Suunto 9 Peak combo.I have just done a run with H10 Belt and Suunto 9 Baro and from what I can see; no issues with Hr :
https://www.sports-tracker.com/workout/tonygray190/61d0645abc8b8b1fbd6fbd1f
I did however soak the strap in water before putting it on; wouldn’t want to do that in freezing conditions, but as it is record breaking temps here in UK I thought I may as well. it does add a couple of variables which doesn’t help with any comparisons.
I also have A3P and it is an amazing watch, one to keep.
If it helps we don’t process ibi / RR data
Also if it helps the S9s have the same software , however they have a different BT chip , faster on the s9p.
Register Login
