    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 - Battery issue (not a drain problem)
    Scheduled Pinned Locked Moved Suunto 7
    batterybattery replacementsuunto 7
    5 Posts 4 Posters 1.5k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ricdelorenziR Offline
      ricdelorenzi
      Hello everyone!
      As I say on topic title this is not a drain problem, in fact I’m able to track more than 6 hours of outdoor activities.
      I bought my Suunto 7 one year ago and I usually charge it every night, so I’m not used to fully drain it’s battery. Circa five months ago I fully drained it, it wasn’t the first time, and then it didn’t turn on anymore. I tested different chargers (2A, as they suggest), different cables and nothing worked. I guessed I was unlucky and I sent it back using warranty. They changed my battery and everything was fine again.
      On Wednesday I went skiing, I tracked 6h30’ activity and still had 30% of battery. While driving back home it turned off because battery dropped at 0% and then it happened again: my Suunto don’t want to start again.
      I read on Reddit it happens to few user, someone talk about it as a bug. I just find it unacceptable since this is the second time in a year.
      Any suggestion?
      (Yes, I’m using charger with more than 1A, I press more than 30sec the turn on button. Screen just keep on sending life signs)
      • ? Offline
        A Former User @ricdelorenzi
        @ricdelorenzi said in Suunto 7 - Battery issue (not a drain problem):
        I would try a battery calibration. Discharge completely the battery and make a full charge
        C 1 Reply Last reply Reply Quote 0
        • C Offline
          cicciorunning @Guest
          @g-q The same thing happened to me a few months ago even if in a different context … S7 blocked that didn’t want to reboot … I was about to send it to assistance, but then I left it all one day attached to recharge et voilà, magically he recovered … never had the same problem again …
            ricdelorenzi
            A friend of mine was able to bring it back to life with a 5A charger. Still kinda shocked someone needs to use such a horse kick once it run out of battery
            • EgikaE Offline
              Egika Platinum Member
              Usually it is not necessary to use a high amp charger as the charging circuit in the watch will never allow high currents anyway.
              If the battery is in deep discharge then a state of the art charging circuit will trickle charge it until it can come back to a normal charge.
              This is why it can take a long time on the charger until he device comes back to life.
              Thus the recommendation for deep discharged devices is: leave it on the charger for a longer time. I would only call it defective if it does not come back after a day or so.
              This does not solve the initial high discharge though…
              t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
              • First post
                Last post
              Suunto Terms | Privacy Policy
