    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto plus burner bug
    Scheduled Pinned Locked Moved Suunto 9 Peak
    8 Posts 2 Posters 1.1k Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • U Offline
      uranfl
      After half an hour rest.
      Numbers were even bigger before I managed to make a foto.
      I am using Polar H10.
      suzzloS 1 Reply Last reply Reply Quote 0
      • suzzloS Offline
        suzzlo Moderator @uranfl
        @uranfl wrong configuration? Did you setup correctly your body parameters?
        BR
        Suunto: Race, S9Peak, Spartan Sport Wrist
        Garmin: FR745, Edge 530
        SA topics:
        • Guides - https://forum.suunto.com/tags/guides
        U 1 Reply Last reply Reply Quote 0
        • U Offline
          uranfl @suzzlo
          @suzzlo yes, body parameters are OK. The Suunto plus Burner works fine during workout. This anomaly occurs only after resuming activity and after a while the numbers return to expected values.
          • suzzloS Offline
            @uranfl resuming activity?
            SA topics:
            • U Offline
              uranfl @suzzlo
              @suzzlo pause and then after half an hour resume…
              • suzzloS Offline
                @uranfl could if be that the watch has record any wrong HR during this pause, and then this ends in a bad calories calculation?
                BR
                SA topics:
                • U Offline
                  uranfl @suzzlo
                  @suzzlo I will check at next similar activity
                  • U Offline
                    uranfl @uranfl
                    @uranfl I think I found the cause of the problem. While the activity is paused, the watch still measures burned calories, but does not add them to the total. As the activity continues, the algorithm adds up the calories burned while pausing the activity shortly after pressing the resume button. This rapid jump in calories burned then confuses the Burner algorithm, which then malfunctions for a while.
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
