    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Blood oxygen
    Scheduled Pinned Locked Moved Suunto 7
    22 Posts 9 Posters 3.0k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Stylianos KalintzisS Offline
      Stylianos Kalintzis
      Season’s Greetings to all.
      Now it time for blood oxygen, what do you think?
      freeheelerF 1 Reply Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @Stylianos Kalintzis
        @stylianos-kalintzis
        https://youtu.be/IXA89hcmHKM
        living sideways
        Stylianos KalintzisS 1 Reply Last reply Reply Quote 0
          Stylianos Kalintzis @freeheeler
          @freeheeler said in Blood oxygen:
          Thanks for your reply, my watch is suunto 7.
          surfboomerangS 1 Reply Last reply Reply Quote 0
          • surfboomerangS Offline
            surfboomerang @Stylianos Kalintzis
            @stylianos-kalintzis The Suunto 7 has no blood oxygen sensor.
            Suunto Vertical Titanium Solar
            OnePlus Nord 4
            freeheelerF 1 Reply Last reply Reply Quote 1
            • isaziI isazi moved this topic from Feature Suggestions on
              freeheeler @surfboomerang
              @surfboomerang
              and if I’m not mistaken, it will never have blood oxygen, same as my S9B, since the sensor is not made for it.
              …hmm… I really would like to see something like S9P XL some day 😀
              living sideways
                surfboomerang @freeheeler
                @freeheeler It is indeed a different sensor so it won’t come to the S9B.
                To be honest, I don’t use it very often on my S9P. Somehow the sensor has a lot of trouble measuring my blood oxygen level. A lot of times I get the error that it can’t measure it correctly. If it gets a reading after several tries, I have doubts about the accuracy.
                Because if I have to try 5 times to get a value, how accurate is that value then?
                OnePlus Nord 4
                freeheelerF Brad_OlwinB 2 Replies Last reply Reply Quote 3
                  @surfboomerang
                  room for improvement and time to sort it out until S9P XL 😉
                  seriously, I hope they have a solution for it. I think other watch makers can show the saturation pretty reliably already
                  living sideways
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @surfboomerang
                    @surfboomerang Improvements will come, I don’t think the sensor and underlying firmware was developed without plans to provide implementation beyond a manual reading of SpO2.
                    Vector/T6c/Vertical 2 Ti
                    Jamie BGJ 1 Reply Last reply Reply Quote 2
                    • isaziI Offline
                      isazi Moderator
                      It very depends on the person, I get good results but obviously I don’t need this feature most of the year, I only need it for few weeks when I’m at altitude.
                      Blog: isazi's home
                      • Jamie BGJ Offline
                        Jamie BG Bronze Member @Brad_Olwin
                        @brad_olwin
                        The battery drain on a 24/7 SPO2 readings is massive, which is partially why most make it spot readings, with continuous for sleep only. Plus doesn’t help that it can’t take a decent reading when you are active, so sort of make its pointless for 24/7 reading (and that doesn’t even take accuracy into account).
                        Even with a heavy duty battery like the F6xP - you drop from 21 days to 14 with it on for sleep tracking. Difficult to tell when 24/7 as it does dynamic readings between 5 - 15 mins as depends on activity levels.
                          freeheeler @Jamie BG
                          @jamie-bg
                          for my use case I would use it for single measurements only… when I feel that inhalation is due I could start the measurement and check if it already has an impact on the saturation…
                          but since I’m waiting for an XL version I have to be patient for this feature anyway 😉
                          living sideways
                          Mff73M ? 2 Replies Last reply Reply Quote 0
                          • Mff73M Offline
                            Mff73 @freeheeler
                            @freeheeler
                            i had an S9P during one month, and never managed to have a saturation that i trusted EACH time.
                            what about a value that is not trustable ? and what about a value if one must know beforehand what the real value should be 🙂
                            SSU (retired), SV1, SV2
                            Wife : S9PP
                            SA: Always the latest beta :)
                            Android + Galaxy S205G
                            surfboomerangS 1 Reply Last reply Reply Quote 1
                              surfboomerang @Mff73
                              @mff73 said in Blood oxygen:
                              @freeheeler
                              This…
                              For example I did 6 measurements in a row and this is the outcome:
                              1: “Blood oxygen levels can’t be measured…” notification
                              2: “Blood oxygen levels can’t be measured…” notification
                              3: 76%
                              4: 100%
                              5: “Blood oxygen levels can’t be measured…” notification
                              6: 96%
                              OnePlus Nord 4
                                @surfboomerang
                                @Mff73
                                maybe Suunto improves this feature in parallel to an XL development 😀
                                living sideways
                                • ? Offline
                                  A Former User @freeheeler
                                  @freeheeler I have on my SMG S10 and I used only to contain my breath when I’m boring or to share with some paranoid friend about C19 😂
                                    freeheeler @Guest
                                    @flypg
                                    😂 when the watch detects C19 it’s far progressed I guess 🙊
                                    living sideways
                                    ? Fenr1rF 2 Replies Last reply Reply Quote 0
                                    • ? Offline
                                      @freeheeler Nice for features suggestion… 😂
                                        freeheeler @Guest
                                        @flypg
                                        isn’t the apple watch detecting heart issues in some cases?
                                        living sideways
                                        Jamie BGJ 1 Reply Last reply Reply Quote 0
                                        • Fenr1rF Offline
                                          Fenr1r @freeheeler
                                          @freeheeler That will be the Omega variant (if Swatch so wishes).
                                            freeheeler @Fenr1r
                                            @fenr1r
                                            that will take some more cycles… I hope we’re not going to see Omega at all 😦
                                            living sideways
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
