    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS problem
    Scheduled Pinned Locked Moved Suunto 5
    6 Posts 4 Posters 917 Views
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Y Offline
      ylwendy
      I’ve done settings on navigation n there is no issue in locating my current location… However when I started my activities like walking or hiking, there is no gps found. What should I do?
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @ylwendy
        @ylwendy check AGPS in about menu. Is there a file present and is the file current?
        Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing
        • Catoer WibowoC Offline
          Catoer Wibowo
          hi all, i have problem with GPS today. the day is bright, sky is clear, power saving is off, but the watch could not lock even after i ignore and start running. i dont know why this happened. please let me know what to do or check?
          Suunto Spartan Trainer Wrist HR (traded in with S5)
          Suunto 5
          freeheelerF 1 Reply Last reply Reply Quote 0
          • freeheelerF Offline
            freeheeler @Catoer Wibowo
            @catoer-wibowo
            I assume you checked the AGPS file according to Brad’s suggestion?
            It helps when this is relatively up to date, afair not older than 5 days (!?)…
            my impression is: ignoring and start running makes it even harder for the watch to lock satellites, when it already struggles… but I could be wrong
            living sideways
            Brad_OlwinB 1 Reply Last reply Reply Quote 1
              Brad_Olwin Moderator @freeheeler
              @freeheeler said in GPS problem:
              @catoer-wibowo
              You are correct, without a lock it can take a long time to get the GPS fix while running…tested that.
                Catoer Wibowo
                thank you all, i finally restarted the watch by pressing the two upper buttons for about 12 seconds. the watch restarted and after that, the GPS works perfectly and I feel that it is even a bit more accurate i.e. from cold start when you are doing the workout. anyway, thanks for the suggestions. cheers
                Suunto 5
                • First post
                  Last post
                Suunto Terms | Privacy Policy
